BDop DIY Kinlin wheelset or Shimano 6800 wheelset?
Location: take your time, enjoy the scenery, it will be there when you get to it
Bikes: 07 IRO BFGB fixed-gear, 07 Pedal Force RS
Both are about the same price, and close in weight, but which would you prefer?
The BDop wheels are slightly wider(1mm inner width), but the Shimano wheels are tubeless.
I'm doing it wrong.
Bikes: Rivendell Appaloosa, Rivendell Frank Jones Sr., Trek Fuel EX9, Kona Jake the Snake CR, Niner Sir9
Quoted: 9742 Post(s)
Liked 2,812 Times
What kind of hubs on the BDop wheels?
I really like Shimano hubs, so I would be leaning that direction.
Bikes: Habanero Titanium Team Nuevo
Quoted: 399 Post(s)
Liked 185 Times
Get those Bdop they are great 2500 miles on mine roll well. I built them
and can so that makes it easy. Not even touched them up still true. Weight is good I think 1660 24/28.
As do I for the ability to overhaul the cup & ball systems and set bearing loads precisely myself as well as the quiet sturdy freehubs design.
Not RS6800 but I've been riding the heavier RS30 set for two seasons now and find them reliable and don't doubt the aero efficiency of 16/20 bladed spoke config with a moderately deep rim that doesn't feel affected by crosswinds.
For a lighter climbing set I've been eyeing the RS81-C35 set myself.
Speechless
Bikes: Felt Brougham, Lotus Prestige, Cinelli Xperience,
Quoted: 163 Post(s)
Liked 39 Times
Vote for BDop for the following reasons:
1. He maintains all the hub component parts on his website, so you have access to anything if ever needed.
2. You already build your own wheels, so you will know the quality of the build.
3. BDop is active on the board, responsive to e-mails and issues, and a general good egg. Eggs are good.
L-I-V-I-N
Would you build the Bdop set yourself? If I had the skills, I'd go that route. Otherwise 6800 or Fulcrum Racing 5.
"The older you do get, the more rules they're gonna try to get you to follow. You just gotta keep livin', man, L-I-V-I-N." - Wooderson
'14 carbon Synapse - '12 CAAD 10 5 - '99 Gary Fisher Big Sur
Mostly Harmless
Bikes: Have two wheels
Quoted: 13694 Post(s)
Liked 4,520 Times
I have no doubt that they are fine wheels, but there's something cool about those 6800 wheels. The only thing that bothers me are the spokes. I wonder if the are proprietary straight pull Shimano spokes, or would Sapim/DT spokes work fine in a pinch.
L-I-V-I-N
Fulcrum made the Racing 5 'LG' slightly wider compared to last year (16c internal). You might at least check that price at Ribble before grabbing the bdop kit. I'd bet the spokes are proprietary as well though.
Quoted: 20808 Post(s)
Liked 9,450 Times
Liked 9,450 Times
I hope he chimes in with wheel weights.
Mostly Harmless
Liked 4,520 Times
Quoted: 2432 Post(s)
Liked 638 Times
Same price and similar weight I would get the Ultegra's. Already built and tubeless ready if one wants to try that in the future would be the best deal.
I have some Stan's hoops that are tubeless, but I use tubes and Michelin Pro4 tires because I get them cheap(and the ride is phenomenal). Tubeless tires are expensive.
