Ribble CGR Ti, with carbon forks
Hi, I am starting a bike build and I trying to find a compatible headset. I have the Ribble CGR Ti frame, which came with the Ribble carbon forks. The headset that came with it is a Level 44 Headset With Top Cap & Bolt Black 44m. I would like to change to a Chris King, but I have no idea on the correct type. Any idea on how to go about checking?
Thanks
Thanks
Thread Killer
Quoted: 3200 Post(s)
Liked 1,735 Times
Asking Ribble seems the obvious answer, but did you try that already?
Bikes: Space Horse Disc, Domane SL5 Disc
Quoted: 65 Post(s)
Liked 29 Times
I just found this listing where someone is selling the old Ribble headset off the same bike. They listed the specs so maybe that will help you narrow down the headset you need. This seller also mentions they replaced their headset with a CK one.
Specifications
- EC34/EC44 to fit tapered 1 1/8" to 1 1/2" forks
- Durable and corrosion-resistant anodised 6061-T6 alloy cups
- Sealed cartridge bearings resist corrosion
- Upper bearing: 41x30.2x6mm 36°x45°
- Lower Bearing: 52x40x8mm 45°x45°
- Laser-etched LEVEL logo
