Necessity for Headtube Reaming & Facing on Bikes that have Existing Headsets
I need to do some pressed headset work and have been contemplating acquiring some tools for that. One of the things that is holding me back is the necessity for reaming and facing headtubes as part of the headset installation process and the cost of the tools that I'd want for that.
Is reaming and facing something that is only required on new frames that haven't yet had headsets installed? Or is it it something that should be anticipated for the replacement of existing headsets as well?
Thanks for your help.
Quoted: 4853 Post(s)
Liked 3,990 Times
Basically, any frame that has not has it done will benefit. Not all new bikes have had the reaming and facing done properly. That said, buying the tools for one or two bikes is usually not worth the cost if there is a bike shop nearby. They have the tools and the job takes minutes.
Likes For 79pmooney:
aka: Dr. Cannondale
Quoted: 2162 Post(s)
Liked 3,478 Times
I’ve never, ever, had to have a head tube faced and that’s counting easily over a hundred bike frames.
Based on the quality of bikes in your sig, not likely that anything in that league would require such work.
Unless you were trying to install a different sized crown race or cups than the frame was previously prepped for.
Likes For rccardr:
Quoted: 5895 Post(s)
Liked 2,758 Times
Reaming and facing is a one and done job. Once a frame has been cut to spec. there's nothing to be gained by doing it again, and may even be counter-productive.
The ONLY reasons I consider repeating the job, if I suspected it wasn't done the first time, or if I were changing to a different headset with different specs. ie. changing from an JIS 30.0 headset to an ISO 30.2mm headset.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Expired Member
Quoted: 3753 Post(s)
Liked 5,682 Times
Aren't those less commonly needed with cartridge headsets?
Liked 2,758 Times
Actually more important, but generally done by the builder, or pre-machined into the head tube.
As I said earlier reaming/facing is one and done, so no need to consider unless there was a searing problem with the prior headset.
FB
Chain-L site
FB
Chain-L site
Likes For FBinNY:
Clark W. Griswold
Quoted: 4445 Post(s)
Liked 4,102 Times
Those are tools I wouldn't buy there are so many other tools I would rather have. As others have said it is a one and done situation and I would have my local frame builder or shop do it if it wasn't already done. If you are getting a custom frame it is likely already done and probably most modern production frames are set up already or are carbon and not something you want to face and ream.
Quoted: 101 Post(s)
Liked 49 Times
I've built bikes both with and without the face and ream job and one before and after. It can definitely make it easier to get the cups fully and squarely seated. I'd say rarely necessary but often beneficial it only needs to be done once, it's just good practice.
Unless something makes it impractical, just do it.
Supports and helps build a relationship with you local shop for not a lot of money.
I'm even more strongly in favor of chase and face for the bottom bracket. That's another topic.
Quoted: 4549 Post(s)
Liked 1,694 Times
If I had a bike where the headset wore out prematurely, I would face the head tube before I put a new one in. Otherwise, I would not.
But on a virgin steel frame, I would definitely ream and face. Like a new Surly. I have never encountered an aluminum frame that needed it, and you can't ream or face Ti.
Quoted: 1869 Post(s)
Liked 666 Times
Why can’t you ream and face Ti?
Liked 1,694 Times
Old fart
Quoted: 3615 Post(s)
Liked 3,446 Times
Quoted: 402 Post(s)
Liked 587 Times
It's been my unfortunate experience that lbs seldom have the tools OR someone who actually knows how to use them. And as was already mentioned it is a one and done thing and if it is screwed up it is not un-screwable
Likes For Steel Charlie:
Liked 1,694 Times
And you can re-face bad work. You generally only remove half a mm. I'm not sure how you could screw up reaming bad enough to matter.
