Bike Computer Wheel Diameter
Oooooooofffff SALESMAN!
I have a bike computer and I'm having trouble setting up the correct wheel diameter for an accurate mph speed. My wheel is 700C with a 38mm tire. On the bike computer there is no 700C setting, only 6-34.
I'm trying to decide if a 700C wheel is closer in size to a 27 or 28. I'm thinking 27 but I have read that a 700C 32mm or wider is bigger than 27 and so has to be 28.
What do you think?
What do you think?
Let your bike be the tool
Bikes: '66 Raleigh Carlton, '70 Ron Cooper, '95 Bianchi CD'I, Zonal Frame with Xenon gruppo, Carbon Frame with Record Gruppo, Columbia Twosome, Terry Classic, Bianchi SX, Gravity SS/FG
Quoted: 340 Post(s)
Liked 316 Times
Might be helpful if you identify the brand and model of the computer.
Never try to teach a pig to sing...
Likes For cranky old road:
Quoted: 4305 Post(s)
Liked 1,383 Times
If it shows a list of wheel sizes, it’s making unknown assumptions about the tire size.
This is kind of a dumb way to set this up.
Cycle computers usually let you specify the radius, diameter, or circumference (basically interchangeable) of the whee/tire combination.
This lets you do a “roll out” that will take into account the wheel and tire size, what ever pressure you use, and the load (the total weight).
What you could do is compare the speed reading from the computer against a phone and pick the next higher or lower setting. (Be careful doing that.)
That's actually a great idea, I also have a Garmin Edge Explore 2 GPS, I can just compare the two and increase or decrease the input number.
Likes For The Big Wheel:
Quoted: 6313 Post(s)
Liked 4,904 Times
If the setting is by the circumference, then you can estimate it by adding twice the tire width to the BSD of the wheel and multiplying by 3.14. Tire height on the rim is roughly equal to it's width. A 700C wheel will always have a BSD of 622mm.
So that'd give you a circumference of 2191.72. So use 2192. If you find that is doesn't come up true when you ride a measured distance, you can adjust that number to match by just using simple math to figure out the difference.
Since you are using a really wide tire on that 700C rim, you might find your answer in the tables for a 29er or 29" tire which also will always have the same 622mm BSD. Up until recently, 700C tires where typically less than 30 mm. So a lot of tables for wheel size on bike computers never went larger.
You can also measure it by doing a roll out. Put a piece of tape on the ground and then put the valve stem of the wheel over it. With your weight on the bike, roll the tire one revolution and then measure the distance between in millimeters. Or roll several times keeping track of the number of turns and then measure and divide.
Clark W. Griswold
Quoted: 4445 Post(s)
Liked 4,102 Times
You might ask to get this moved to the E-bike subsection there are people with some Bafang knowledge.
Likes For veganbikes:
Liked 1,383 Times
What the OP said and doing a search indicates it’s a list of wheel sizes. I mentioned circumference (why it was better)and the OP didn’t come back that circumference was an option. Seems safe to conclude it doesn’t use circumference.
(It should use circumference, since that allows for a more accurate number.)
Likes For njkayaker:
Liked 4,904 Times
The OP mentions that a Garmin Edge Explore is used too. If that's going to be a permanent fixture on the bike to get distance from both. Then that might for various activities be like the proverbial man with two watches.
But it will let the OP find a value that close enough.
Liked 1,383 Times
The bike is still going to report the speed, etc. What it reports should be as accurate as possible.
Guys, I got an email back from the seller and get this, he says to input "29" into the computer.
But I'm pretty sure that my 700c 38mm tire equals to a 28" 1.5 inch tire. At any rate I set it to 28 right now and will compare it to the Garmin GPS.
Disco Infiltrator
Quoted: 3133 Post(s)
Liked 2,115 Times
Well if you set it to 29 you will see the maximum speed it could possibly be so it you can feel really good about your purchase.
Really it's right in between 27 and 28. You might be as much as 1.8% off!!!
Genesis 49:16-17
Genesis 49:16-17
Liked 4,904 Times
So does it ask for anything else? Or does it seem that you only enter the approximate overall diameter and it figures it out from there.
Liked 1,383 Times
https://support.biktrix.com/kb/guide...1035267,943481
Wheel Diameter
The speed display will show Wd. You will not need to change this setting unless you are putting different diameter wheels on your bike than what came with it. Press the UP and DOWN buttons to change between 16/18/20/22/24/26/700C/28/29 inch wheel diameters.
Liked 4,904 Times
Looking up the manual for the display shows that it provides a choice of "16/18/20/22/24/26/700C/28/29 inch wheel diameters". This doesn't match what the OP said exactly (which is why I didn't provide the link earlier). But, yes, all evidence points to only being able to enter the "approximate overall diameter". (I'm not sure why you keep insisting following a path that there is no evidence of existing. I'm also not sure why I'm the only person who appeared to do any research.)
Bikes: Diamondback "parkway" Spec. "expedition
Quoted: 48 Post(s)
Liked 42 Times
Check the Sheldon Brown site. I believe there was a chart as to setting bike computers.
Disco Infiltrator
Liked 2,115 Times
Research was not needed because OP is not confused at all about the way his computer works. He just wanted opinions whether to pick 27 or 28.
27 is clearly the only possible correct answer. <- this is an opinion
Genesis 49:16-17
Genesis 49:16-17
Likes For Darth Lefty:
Liked 1,383 Times
"Bafang 800S" was enough to get hits. Maybe, you used too many search terms?
It wasn't quite clear what was going on. So I did a search. It was easy to provide those results.
Liked 4,904 Times
Just think of me as ADHD without the H and oncoming dementia from old age. <grin>
Liked 1,383 Times
Yes, obviously. Things should generally make sense. Having people wonder if a post of yours is one of the ones that "doesn't make sense" seems like an unreasonable ask.
Continuing to talk about the circumference is communicating that it might matter to the OP. When, as far as other indications show, it isn't relevant at all. That is, it looks like you are trying to provide an answer but you aren't really.
Liked 4,904 Times
Maybe I'm not the only one with some type of dementia! <grin>
Liked 1,383 Times
This quote is suggesting the OP missed something. And that suggests that the answer still could be the circumference nonsense (it keeps this open as a possible solution).
No, it looks like you aren't paying attention. Since the answer was basically provided earlier.
And kind of lazy. But was fine with a longish (and irrelevant) post about how to do a roll-out. (You said you tried to search earlier. Here, you suggest you didn't do a search at all.)
No. Though, if you actually have dementia, it would certainly explain your posts here.
Liked 4,904 Times
It's the other stuff about the irrelevant circumference that looked like you were providing an answer.
If you read the posts carefully, the answer was there. Yet you kept asking pointless questions (questions the OP isn't likely to want to answer).
No. If you actually have dementia, it would certainly explain things here/
I don't see any issues with my question. My prior statements before that don't matter anymore for that question as the OP's comment about entering a simple number that I wasn't sure was a wheel diameter or wheel size name. And I was curious if it'd also ask for something else such as width of the wheel which would have put the accuracy to which the calculation for distance and speed to maybe 2% instead of what might just be 5% or more based on what I currently understand.
Liked 1,383 Times
It doesn't seem like you read the OP (very carefully).
You should have read more of the comments in this thread instead of spending the time posting the long (and irrelevant) roll-out post (which indicated you didn't understand what this thread was about).
The question the OP asked was an indication that this wasn't an option.
Not surprising.
Not surprising.
