This is good, right?
slow up hills
Bikes: Giant TCR, Redline CX, Ritchey Breakaway, Spec S-works epic
Metal dissipates heat, no?
Bikes: Specialized, Moots, Bridgestone
Metal dissipates heat, yes.
Miscellaneous shrapnel in your pads tears up rims.
Pretend Racer
What wheels are you running there anyway?
cab horn
Bikes: 1987 Bianchi Campione
Quoted: 42 Post(s)
Liked 26 Times
Replace them with koolstops.
slow up hills
Mavic Ksyrium Elites. Lots of rainy rides in the last few weeks, somehow I wonder if that has contributed.
Sensible shoes.
Bikes: A few.
New pads. Clean your rims with alcohol and a scotchbrite pad. The rain helps pick up bits of grit which then dig into your rims when the pads clamp down. After riding in the rain make sure you give the pads a look. In winter I'll periodically file my pads a bit with a metal file to eradicate some of this junk and offer a fresh surface.
Gravy
Bikes: DBX-Schwinn
to buying disc brakes for my winter bike.--I loved them almost at once.
Now I ride disc brakes year around--Avid Mechanicals
For me changing to Disc Brakes was like going from Down Tube Shifters to STI
TTFN
slow up hills
I have torn up rims in winter riding in the past which eventually brought me
TTFN
TTFN
Gravy
Bikes: DBX-Schwinn
Not into Road Racing, Now only Commuting.
In the past I did century's and Double centuries .
I am now coming back from some injuries, will try STP this year.
But I never Raced.
The commuting is where the Brakes really shine, with all the Road YUK
in an Oregon Winter, Rubber Compound Brakes can go fast.
Yo
But I never Raced.
Yo
cab horn
Quoted: 42 Post(s)
Liked 26 Times
TTFN
TTFN
Although I do agree - for all-weather commuting, disc brakes would be the best choice.
LOOK, a bike! LOOK! LOOK!
replace the pads but at the same time sand off any hanging flakes on the wheels. I used to deal with this problem on my mtb until I realized I had to correct both areas at the same time or it would come back in just one ride.
rider of small bicycles
Bikes: Cannondale
"I come up out of the saddle, I shift and jump. Barthelemy on my wheel. I bite in the hard air, I rip down the left side of the road, I bridge the gap at a single tug. Now, what to do with my velocity? I could always use it to make my brake blocks nice and toasty: little shavings will go flying off of them, my bike another thousandth of a gram lighter."
Making a kilometer blurry
Rain kicks up more grit, which sticks to the rim. The brakes grab it and hold on to it (grains of sand). These then abrade the braking surface, which makes it look like you have metal bits in the brake pad.
The "right" thing to do is to replace the pads.
That said, I never have replaced pads because of this, in 16 years. I just take out my pocket knife and lever out the offending gravel bits. Wipe the rims off. Pads good for another few thousand miles. When it happens again in the next rain storm, poke those bits out again.
Most people on these forums buy about 15x more crap than they need to
Big Mac and No hills.
Bikes: Trek 1500, Raleigh Tarantula
Time for a change.
Liked 5 Times
Have gone a bit higher grade now but I have a set of Aksiums that are set up with cassette and ready to fit any time. Only thing is before the next dry ride- the blocks are cleaned or filed down to get rid of the stuff they picked up on the wet ride.
Spike Milligan
Spike Milligan
Gravy
Bikes: DBX-Schwinn
You're going to have a hard time convincing others to buy a completely new wheelset just to use disc brakes and the associated costs of doing so. Also, the fork will need to be changed as well.
I ride in Oregon EVERY DAY(on the wet side) and here we have a lot of wet days, so for me this makes a lot of sence -- The cost is negotiable there are lots of bikes which have disc's-maybe not so many road bikes -- but still there are always choices. (1)- buy during the year end close outs , (2)- keep two bikes in the stable.
TTFN
slow up hills
I've already picked the pieces out (using toothpicks) and sanded down the blocks. I only wiped off the rims, so i may need to go back over those with some 400-600 grit sandpaper and recheck my pads. Unfortunately I can't avoid riding in the rain. My schedule is limited, so if I have time to ride, I do. Rain or shine.
cab horn
Quoted: 42 Post(s)
Liked 26 Times
the pads came with my Ultegra SL group from pbk, I assume they're not of too poor quality.
Your pads are junk, replace or suffer premature wheel failure due to excessive brake track wear.
There's never a reason to sand down your braking surface other than to smooth a seam (mfg. irregularity). The gravel in the pads was doing enough sanding for you. Just wipe them down with a damp rag.
When you hear grinding after your next rain ride, pull out the toothpick again. I still like the pocket knife better though, as you whittle off pad ridges as needed too (more commonly needed on the old cantilever MTB brakes).
Don't forget to clean out the vertical channels in the pads as well. You should be able to see daylight in there.
