Bike probably too big. How much can I shorten stem?
Quoted: 119 Post(s)
Bought a custom frame from a shop a while back who probably did not know as much about sizing as they thought they did. I am 6.1 and the top tube on the frame is 57 cm and currently has a 110 cm stem. Problem is, my back gets extremely stiff after a while even though my legs still feel fresh. I have done all kinds of stretching and strengthening exercises ad nauseum to no avail. I don't have much of a saddle drop so my conclusion is that I must be on a bike that is to big and has me stretched out too far.
Would swapping the stem out for a shorter one make much of a difference? I am well aware that it will change the steering somewhat but don't have any idea how much. I am thinking of starting with a 90 cm stem. Any thoughts would be greatly appreciated.
Bikes: 2006 Cannondale CAAD8
go with a 90mm stem. Also what handlebars do you have? You can go to something with a shorter reach too. Any shorter then that and maybe you should consider a new frame.
Sua Ku
Bikes: Trek 5200, BMC SLC01, BMC SSX, Specialized FSR, Holdsworth Criterium
I have ridden down to 80mm no adverse effects. In the end I changed bike.
By the way your bike does not sound too small. I'm 5' 7" and ride an effective top tube of 53-54. But if it doesn't feel comfortable for you then I guess it doesn't fit
Bikes: LS Archon T1, LS Ghisallo, QR TiPhoon
FWIW I'm 6'1.5' and ride an effective TT of 57.5 with a 120 mm stem, so you are in the proper ball park.
However, what is your HT and your drop? This might sound crazy but I Increased my drop by over 3cm and became more comfortable in the neck and back dept.
Proper fit per individual cn aonly be determined through visual anaysis while riding (pictures on the trainer are most effective IMHO) and even then are really just for a starting point to begin the tweeking.
To answer your question though even an 80mm stem is not going to kill you bike.
Bikes: Cervelo R3, Trek 2300, Trek Portland, Schwinn Homegrown, Cannondale Road Tandem, Schwinn Le Tour Commuter, Gary Fisher Paragon 29er
I guess it all depends on your torso and arm length but I'm between 6'1" and 6'2" and feel comfortable on a 58cm top tube with either a 120mm stem with 90mm reach handlebars (or 130mm stemm and 80mm reach handlebars). Maybe your handlebars are too low? I'd find some place that will work with you to get a better fitting. Expect to spend a couple hours on the bike while they do it.
Quoted: 119 Post(s)
Spelling Snob
Bikes: Panasonic DX4000, Bianchi Pista
Can you move your saddle forward any? That may move you forward enough to give
a little relief.
a little relief.
The first rule of flats is You don't talk about flats!
Quoted: 119 Post(s)
I have the saddle set to the position where it is kindest to my behind i.e. where the contours and padding fit just right. It is the Selle Italia SLR. Tried the Fitzik Arionne which did not work as well with regards to comfort.
Ninja don't wear flipflop
Bikes: Specialized S-Works Roubaix SL3, BMC TM01...if it every ships
You could probably go to an 80 cm, but this really sounds like more of a back problem. One thing you can try is dropping the nose of your saddle a little. This will change your hip/back angle a little, but will move more weight to your arms. I would try this first. Rather than looking at stem length and going too short, you may want to look at a stem with more rise. I had a 4-axis that was something like +/- 26 degrees at one time. If your stem is too short you will hit your knees or arms when you get out of the saddle to climb.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Dropping the nose of the saddle could actually cause MORE pressure to be placed on the shoulders, so it's a toss up there.
What size are the bars? You might want narrower bars, and a shorter stem as mentioned above. fwiw I am 5'10" and ride a 56-57cm top tube with a 100-120mm stem.
not a role model
My shot-in-the-dark guess would be to lower the bars.
Obviously, we're all just pulling guesses out of our asses here... either go find someone knows how to fit you, or start making changes yourself.
Quoted: 119 Post(s)
pan y agua
Quoted: 1447 Post(s)
Liked 728 Times
Leave the saddle where it is. You should not adjust the reach to the bars with the saddle.
Quoted: 119 Post(s)
That might be your problem. No bar drop, plus riding in the hoods could mean you're too bunched up.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Yes, dropping the saddle angle may cause some pressure to the shoulders but perhaps that would be the better of two evils. After all, there is no more power in the engine room once the back starts to act up which is extremely frustrating to me. So if I could exchange the back pain for some shoulder discomfort, I'd surely do it though it'd be nice to ride without either. I don't believe I can get any narrower on the bars and still breath efficiently.
In my experience a good fitting starts with getting the cleats right, then the saddle position (vertically, fore/aft, and angle) then you start worrying about the handlebar dimensions (width, reach, drop) and position (stem angle and length and spacers) and shifter placement. All the little changes take time to make and it adds up quickly.
Bikes: are better than yours.
How is your flexibility? The top tube length doesn't sound too short, and you're not running a lot of drop so your overall reach should, if anything, be a bit on the short side. I'm only 6' and run more drop and a longer top tube.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
This is assuming the OP's saddle is too far back to begin with. I would NEVER move my saddle forward to compensate for a too long stem or top tube. That's asking for knee problems.
Guadzilla
Bikes: Pinarello F4:13 W/Campy Reecord & Blue RC6 W/SRAM Force
I have a brand new FSA OS-115 90mm stem Ill make you a deal on. PM me if interested.
Bikes: 2005 Windsor Kennet, 1982 Raleigh Super Course
The bike is probably the right size. As mentioned it might be a back problem. You can try a 90 mm stem. Get one with a rise of about 12 degrees and that will help raise the handlebar to seat drop. I have a similiar problem and got a 90 mm stem with a 17 degree rise which helps a lot.
big ring
My too sense:
Leave the seat post and fore/aft, tilt alone.
Try a lower reach bar, such as the Deda Newton Shallow (something under 85mm of reach)
Try a 90-100 stem. 1-2 cm makes a huge difference in stem length.
Given your height and a TT of 57cm, it is entirely possible to achieve appropriate fit on that bike.
Elite Fred
Bikes: 2009 Spooky (cracked frame), 2006 Curtlo, 2002 Lemond (current race bike) Zurich, 1987 Serotta Colorado, 1986 Cannondale for commuting, a 1984 Cannondale on loan to my son
Quoted: 60 Post(s)
Liked 42 Times
I'm thinking that 6' 1" and a 57 cm top tube is on the short side for most folks looking for an aggressive position. If you have a longer than normal torso for that height (or shorter than normal legs if you are into putting things in the negative), then it might be right. I happen to be one of those folks (just a little taller at 6' 2") and usually the 57 cm top tube is correct for me.
While I am on the older side (53 years old) I'm pretty flexible (close to flat palms when "touching toes" with straight legs) so I run just short of 6" of drop on the one frame that I have that also has a short head tube. The bars have a "middling" amount of drop typical of anatomical bars and it is just about perfect. The other bike I have has a longish head tube and even though I have removed all the spacers and run a negative 17 degree stem I can't get quite enough drop. Maybe I need to change the pedals to ones with really tall cleats!
Voice of the Industry
Quoted: 1188 Post(s)
Liked 8 Times
A 2 cm drop with 57tt and you are 6'1"? You must be all torso and short legged then. I am 6'1" and ride a 57.5cm tt with 110mm stem and I am not particularly flexible. How long is your head tube and what is your cycling inseam?
OP, you can ride a 80mm stem with no adverse effect to handling so don't sweat that. As the other guys attested, most that are over 6' tall have at least a 57cm top tube so your bike isn't too big.
