Best deal on a crankset
I'm looking to replace my stock specialized triple crank.
Requirement number one: It has to be black.
Requirment number two: Compact Double.
Requirement number three: Cheap.
Right now I'm looking at the Campagnolo Veloce crankset from PBK. $115 for the crank and $15 for the bearing cups. I'm looking to keep things under the $150 mark, total. Anyone have a better deal than the Veloce crank?
Quoted: 21 Post(s)
Liked 13 Times
Is your current bottom brackets quare taper? If it is and is already a 110MM size then these will work...
https://www.velo-orange.com/stimcr.html
The price with a new bottom bracket would run you right at 150$
Bikes: Specialized, Moots, Bridgestone
There are a lot of black compact doubles out there. I'd check sources like ebay, wisecyclebuys, aebikes, excelsports, coloradocyclist, supergo/nashbar/performance, probikekit, etc. and see where the best deals turn up for a crankset/BB.
Absolutly the best deal on a compact crankset including bottom bracket. Appears to be out of stock and only $7 over your budget and only chainrings are black, but you can't have everything.
https://www.universalcycles.com/shopp...&category=2220
Bikes: Bianchi, Miyata, Dahon, Rossin
Liked 5 Times
They have black veloce CT at PBK now? I thought PBK only carried the silver CT version.
Food for thought: if you aren't dead by 2050, you and your entire family will be within a few years from starvation. Now that is a cruel gift to leave for your offspring. ;)
https://sanfrancisco.ibtimes.com/arti...ger-photos.htm
L-I-V-I-N
"The older you do get, the more rules they're gonna try to get you to follow. You just gotta keep livin', man, L-I-V-I-N." - Wooderson
'14 carbon Synapse - '12 CAAD 10 5 - '99 Gary Fisher Big Sur
Bikes: 07 Cannondale Six13 (9 speed Ultegra) + 19?? Lugged Steel Specialized Allez Pro
The best deal would probably be an Ultegra 6500 crank, but it's not black or compact. You can get them for $60 bucks though.
Batüwü Creakcreak
Quoted: 229 Post(s)
Liked 288 Times
You can get a campy centaur 172.5 compact crank for 70-80 bucks from performance. Get a veloce bb for 40 bucks shipped and there you have a compact crank for 120 bucks. I paid 110 for mine online.
The centaur compact UT crankset is the best way to go if you don't mind spending the 150 for that and the cups. I was going to go this route but it didn't make sense for a bike that would be ridden in less than admirable conditions since I have a feeling that the UT/integrated bb's are a little more vulnerable to grit.
....gets the cheese
Bikes: Cannondale Synapse, Cannondale Caad 8, Wilier Triestina Jareen
Quoted: 12 Post(s)
Liked 5 Times
This might be the cheapest way to go, if you can deal with a Nashbar branded crank:
$100.00 for the crank & bb.
Cheers.
Cheers.
Quoted: 15 Post(s)
Liked 27 Times
