Best brifters for a newbie?
Mostly harmless ™
Bikes: Heavy, with friction shifters
Quoted: 1107 Post(s)
Liked 216 Times
Looking for advice. When I was looking for the best newbie/recreational/commuter groupset, I was recommended 105 is the best in terms of quality/durability/not too expensive.
Now, my left brifter got broken after just 50 kilometres. 105 5703 groupset. But I got it 2nd hand (taken off a new bike, unused, but still 2n hand - no guarantee). Now I need new STI brifters.
Which brifters do you recommend? Are 5700 good and I just got a bad piece? Should I get ultegra? Are Tiagra good and will they work on a 3x10 105 groupset?
Quoted: 1529 Post(s)
Liked 718 Times
STI is over-complicated and prone to failure.
You can use Campy's far more reliable (and sexy, IMO) shifters with the aid of a ShiftMate.
Some folks hate em though, so you should prolly test ride an Ergo bike before committing.
Advisor
105 is great stuff; Ultegra is "better"?, smoother and quicker shifting, it will last longer but that is open to discussion and opinion; I have 40,000 miles on my Tiagra before it failed, it doesn't look as nice as the 105 or Ultegra. Your choice.
Sounds like you got a bad part, 105 is traditionally good stuff... Or something unusual happened.
Quoted: 1438 Post(s)
Liked 1,092 Times
Mostly harmless ™
Liked 216 Times
If I can't find those, It'll probably be best to switch to double front rings since double brifters are easier to find round my hometown in case of future failures.
Liked 718 Times
there is the option of No Brifter.. 2 schemes now use a downtube lever
Placed within reach while grasping the brake-lever hood.
retroshift mentioned, and Kelly .. the lever inside of the inner face of the hood..
rather than on the front.
