[Just Curious] Can a Hybrid be converted to a Road Bike?
Bikes: Nashbar CR5
Quoted: 5 Post(s)
So I just ordered my first Hybrid, a Fuji Absolute 2.1. A pretty decent bike, with Shimano Altus shifting components and a decent crank/stem/etc. 23 speed, with; yes, one of those granny rings on the front. (Which I'm sure I'll be glad to have as a beginner). I rode one they had but it was too small, but it felt great. The road bikes were all so much more expensive, and though there are Road bikes in that same $450 range, the Hybrids in that price range seemed to be a much better value.
I did ride a couple proper 'road bikes' around the parking lot. And I really liked the feel. I really liked the riding position. And I really liked the performance. BUT, it was obvious my 'extra weight' was less than compatible, and it was obvious I was going to have some strain after just a short ride. The shop owner suggested I start with a hybrid, then just 'trade it in' when I've lost the last bit of weight (I've lost 122lbs so far), and built up some muscles and flexibility; and can be more comfortable and more confident on a Road Bike.
But, just out of my own curiosity (nothing I'm considering doing now or probably even in the next year; but much farther down the road). But is it possible/practical to add drop bars, STI shifters, swap gearing; and have a quasi-road bike? Or is that just not done? (Or perhaps a poorer value than trading in or just adding a road bike to the stable)
This is just a curiosity, at the end of the day. Thinking out loud, if you will.
Thoughts?
Thoughts?
Bikes: Giant Escape 1
Quoted: 136 Post(s)
I think you'd be better off just buying a road bike. Here are some issues: You swap out the flatbars for the drop bars. This means you need to swap out the shifters as well. You'll probably want "brifters" which means different brake levers. So far, no big deal - but, will you get drop down shifters compatible with your front and rear derailleurs? I don't know, but that's a consideration. You want to match the indexing. A bike mechanics can tell you about that. Next, you'll want to swap out tires for a narrower one - probably "25's" and possibly "23's" Will your rims accommodate that? But other than those things, no problem.
Uber Goober
People normally don't. The frames aren't that big of an issue, it's all the other stuff, so it's easier to just go get a proper road bike when you feel the need.
Bikes: 1984 Miyata 310, 1986 Schwinn Sierra, 2011 Jamis Quest, 1980 Peugeot TH8 Tandem, 1992 Performance Parabola, 1987 Ross Mt. Hood, 1988 Schwinn LeTour, 1988 Trek 400T, 1981 Fuji S12-S LTD, 197? FW Evans
Quoted: 530 Post(s)
Liked 1,004 Times
Many people do make the change, but it is not without issues. Most flat bar bikes use MTB derailleurs, which pull more cable per shift than the road bike derailleurs. The frame geometry may require a different stem to get the bars in the correct place. If you do have to change wheels, a lot of hybrids use the MTB standard 135mm axle, where the road bikes are 130mm.
One way around this is trekking bars, which can use the flat bar shifters and brakes, but still give you a variety of hand positions. They are also pretty inexpensive, bars and bar tape would be under $50.
aka Phil Jungels
Figure out what you want your final weight to be - and divide that by the number of weeks until you get there. Using that figure, figure out how much you have to put away every week, to reward yourself with a road bike when you attain that weight. $10 a week, is 520 bucks in only one year.
Keep the Hybrid for a utility bike, with racks and panniers for hauling stuff.............
Bikes: Univega/custom,Evil Brut Fatbike
If weight is any issue you could use some of the parts from your hybrid and build a 29er.They have strong frames better brakes and a smoother ride than a roadie.Add some road tires and the speed these things will do is scary.You don't need to loose those nice low gears either.
Bikes: Nashbar CR5
Quoted: 5 Post(s)
Bikes: 2013 Fuji Absolute 1.4
hi there mate,
am currently using Fuji 1.4 Absolute 2013 model.
why not instead of getting a road bike look,you opt for a road bike feel..
I did major upgradation for my fuji and it feels like a lot like roadbike...here's what u need to consider:
1. road groupset
2. slick tyres and mid range wheelset
3. narrow handlebar
i made the switch and it is awesome!
1. road groupset
3. narrow handlebar
Bikes: One of each: Road, Hybrid, Trekking
Quoted: 137 Post(s)
Liked 115 Times
N + 1. If you are loving your hybrid when ready to buy a road bike, buy the roadie and have a spare bike. I ride almost every day now so it's fun to switch up bikes depending on my mood, the ride ahead, or a mechanical issue. BTW, I've also added a trekking bike to the garage and took it on a self-supported bike tour down the CA coast and I'm thinking about getting something vintage.
I guess I am hooked.
Bikes: Specialized Sirrus Sport, Kona Kahuna 29er, Santa Cruz Nickel 650b, Cannondale CAAD 10
Quoted: 5 Post(s)
congrats on the weight loss! It most certainly can be done but to do it properly with a new groupset it may be cheaper in the long run to just get a new bike. And who doesn't like a new bike! Most hydrids are a 3x9 set up with roadbikes being 2x10 with a much different gear ratio.
Bikes: Nashbar CR5
Quoted: 5 Post(s)
Yeah, I guess that's the route for me! When I feel like I'd be comfortable on a road bike; I'll move up to one! Hang on to the Hybrid. Maybe put a pair of fenders on it and a rack for my briefcase and make it a bonafide commuting machine
The Fuji has an adjustable handlebar that can get pretty low. The main thing I want a road bike for is the varying riding positions and just the overall Road Bike position and feel. Lowering the stem, lowering the adjustment on the handlebars, and maybe adding some sort of clip-ons will give me all the varying positions and comfort I need.
Plus, I'm sure that granny ring will come in handy on these early rides. Another intimidating factor of starting on a road bike was the more aggressive gearing. Walk before you run!
It's hard to find pics of this bike; but here's one of the 3.0 (which has grip shifters and a lower overall component set. The 2.1 seemed like a MUCH better value in terms of quality name-brand components.) But it's the same idea. And maybe other Hybrids are like that; I dunno. But as you can see on the step, the handlebar height is adjustable. A slammed stem and the handlebar adjusted to be flat in front would be plenty aggressive. With some clip-ons, I'd have the riding position I want (eventually) and the granny gearing I need. Then, when I'm ready, might as well take the other advantages of a road bike and just bite the bullet.
Quoted: 5 Post(s)
if hand position is an issue you can always add bar ends or change out the handlebars themselves to something more accommodating.
