Any disadvantages to a flexible v-brake noodle?
Installing v-brakes. Have my choice of rigid or flexible noodles. Any reason I should pick one or other?
Quoted: 1529 Post(s)
Liked 718 Times
Suck it and see.
I suppose the flexible one is perfect for the odd application where a normal one gets fouled; can't think of any other advantage.
Downside might be a mushier brake with poorer modulation if the internal length doesn't remain contant when it flexes.
How are they constructed, anyway?
Quoted: 1438 Post(s)
Liked 1,092 Times
Rigid noodles are made in other angles besides the usual 90 degrees; 45 and 135 are also available for special jobs. I would expect that a rigid noodle would give a firmer brake action than a flex one but I have never used them so I can't say for certain.
If you have the room and use like Nokon bead and tube housing
you dont need a noodle at all..
