ultegra brakes, 105 levers.
Are the new ultegra brakes (6700) compatible with the new 105 levers (5700)? I've read conflicting information from several sources, including shimano. (Ultegra brake caliper manual says they should be used with 6700 or dura ace levers, whereas description for 5700 sti levers says they are compatible with ultegra "brake arches").
Well I have no brakes at the moment, so I guess that means I don't worry too much. I was just thinking it would be fun to be able to stop, so I was going to order a pair of brakes that would hopefully work with my 105 levers.
Bikes: 2010 Masi Gran Criterium, Motobecane ca. 1980 Grand Jubilee, 1984 Trek 500, Specialized Camber Comp 2014
For future reference, brake to lever compatibility is hardly ever an issue. It's shifter to derailleur that is usually an issue due to different cable pull ratios.
the 105 brakes will be fine and leave money in your pocket to pay the bills for heat and light.
Constant tinkerer
Don't worry about it. In reality, any non-V-brake lever is compatible with any caliper or traditional cantilever brake.
The only time you can get into trouble is when you start throwing in V-brakes or discs.
Yes. Yes. Yes.
Traditional road brakes are compatible with ALMOST any shifter. You will have no problem mixing major brands: shimano, fsa, bontrager, etc.
I let the dogs out
Bikes: 2011 Fuji Roubaix 1.0, 2003 Ti Merlin Solis, & 1994 Raleigh MT200
Quoted: 140 Post(s)
Liked 163 Times
I quoted these posts for misinformation. 5700, 6700, and 7900 have altered brake cable pull. They are the same, so you can indeed mix and match brifters and calipers between 5700, 6700, and 7900. Mixing and matching with other brands will result in less than optimal braking, but it will work. I'm using Fuji brand Oval brakes with my 5700 levers and it's fine (though it's not fantastic)
Quoted: 2026 Post(s)
Liked 1,096 Times
If I understand this correctly, the latest Shimano road calipers (5700, 6700, etc.) and their matching series brifters have a cable pull requirement somewhat longer than the older versions, i.e. somewhere between older caliper/lever designs and V-brakes/ V-levers. The change isn't as extreme but it is there.
So using new levers with older brakes requires a bit more hand pressure for equivalent stopping power but less lever travel and using older levers with newer calipers gives more power at a given effort but more lever travel so you have to set the pads a bit closer to the rim. Is this correct?
Quoted: 140 Post(s)
Liked 163 Times
In reality, it's not a biggie at all to use the new levers with calipers designed for the "old" amount of cable pull, you'll see that a lot with no problems. I haven't seen a case of "old" levers with "new" Shimano calipers, and I think this would not be common anyway.
Bikes: 2012 Masi Speciale CX : 2013 Ghost 29er EBS
The thing that had changed with the newer design of these STI shifter levers in the brake lever design which does actually allow more pull leverage due to a better mechanical design. I do notice this right away compared to my older 9 speed Ultegra shifters.
The side effect to this is that, the brake calipers must not flex as much, or the better mechanical brake leverage will only get translated to energy stored in the spring when the brake calipers are flexing like it! This is common with cheaper brake calipers or off-brands; anything lower than 105 and with cantilever brakes like Avid Shorty Ultimate or Paul's on touring bikes.
There is a marked difference between having better brake calipers or cantilevers installed than the off-brand ones.
Liked 1,096 Times
This is really odd. If the latest 5700, 6700 and 7900 have different cable pulls, then how do you suppose they all work with the latest touring and cross bikes which DO NOT USE Shimano branded caliper brakes? I have the latest ten speed Shimano lever mated to a pair of canti brakes and braking performance is not in anyway hindered at all. The same canti brakes work with older 9 speed designs too! Remember that touring bikes with fatter tires can not use caliper brakes.
Constant tinkerer
Now, if you start going back in time there are a lot of horrible, useless, unacceptable brakes. Like all the flexy single-pivot sidepulls from the 1980s that came on low-mid end bikes.
