Technical questions for the retro grouches on here
I hope we can use this thread to query the retro grouch community on border issues pertaining to equipment, cycling performance, expectations, etc.
So here is my question/point of discussion:
If disc brakes had come before rim brakes, would RGs still love rim brakes as much as they do?
I mean imagine if disc brakes were there first and then the idea of rim brakes came along? A brake that sacrifices the rim you say? I’m sticking with my tried and true sacrificial rotor to protect the wheel!
Likes For speyfitter:
Quoted: 1950 Post(s)
Liked 2,188 Times
It is not controversial. Classic car retro grouches convert from drum to disc because there are good conversion kits available. If discs brakes preceded drum brakes in the car world, drum brakes would not exist.
The same with bikes. Rim brakes would not exist if disc brakes preceded them. And for road bikes rim wear is pretty non-existent, especially hard anodized.
Retro grouch is a fluid term as it is generational; even index shifting is turning 40 this year.
John
John
Likes For 70sSanO:
Mad bike riding scientist
Quoted: 6237 Post(s)
Liked 4,244 Times
You are making the mistake of assuming that rim brakes are not disc brakes. Converting drum brakes on cars to disc brakes was a great improvement. Hub mounted disc brakes are just making the “disc” smaller. A rim brake works exactly the same way as a hub mounted disc brake…they just have a much larger rotor.
As to rim wearing out, yes, it happens. It’s not a big a problem as many people make it out to be. I’ve had many more rims crack at the spoke holes than I’ve had wear out due to brake wear.
Stuart Black
Stuart Black
Forum Moderator
Bikes: Fuji SL2.1 Carbon Di2 Cannondale Synapse Alloy 4 Trek Checkpoint ALR-5 Viscount Aerospace Pro Colnago Classic Rabobank Raleigh C50 Cromoly Hybrid Legnano Tipo Roma Pista
Quoted: 3100 Post(s)
Liked 6,634 Times
I just had to correct the spelling of grouches in the thread title.
Likes For cb400bill:
Bikes: old ones
Quoted: 26456 Post(s)
Liked 10,416 Times
...I thought the retro grouches were supposed to remain within the confines of the C+V forum ? Why would you start this thread in General Cycling ?
Likes For 3alarmer:
Expired Member
Quoted: 3708 Post(s)
Liked 5,545 Times
Isn't there a section called Trollheim?
Likes For shelbyfv:
Quoted: 631 Post(s)
Liked 406 Times
Hydraulic rim brakes came before disk brakes. The reasons they were not as popular is the weight was undesirable to the racing crowd and people didn't like the idea of bleeding them. I have them on my Tandem and they are superior to hydraulic disk brakes in many ways. The drop bar lever versions are no longer made. If I had not needed frame couplers on my current bicycle I would use the Magura HS33s. Disk brakes are more costly and complicated. cyccommute is correct about the rim being a larger disk. The effect of rain on rim brakes is mostly diminished when using hydraulic rim brakes.
Quoted: 982 Post(s)
Liked 1,647 Times
Are Rim/Caliper Brakes easier to repair and adjust than Disk Brakes?
Do Rim/Caliper Brakes cost more than Disk Brakes?
Do you need special modifications to wheel sets to use Disk Brakes?
Can you use Rim/Caliper Brakes on Carbon Rims?
Oddly I find the use of Disk-Brakes kinda like Indexed Shifting. Seems like everybody is converting over but me...
All Campy All The Time
Bikes: Listed in my signature.
Quoted: 177 Post(s)
Liked 114 Times
Hydraulic and/or mechanical disc brakes were being used on cars, trucks, busses, subway trains, airplanes, motorcycles, go karts, lawn mowers, etc. years before they became common on bicycles. So why did it take so long?
I decline to debate which is better. I have vintage bikes, they have rim brakes, they stop fine and still have anodizing on their rims after 40-50 years. Discs might be better, but they are just bikes fercrissakes,
My C&V Bikes:
1972 Bottecchia Professional, 1972 Legnano Olympiade Record,
1982 Colnago Super, 1987 Bottecchia Team C-Record,
1988 Pinarello Montello, 1990 Masi Nuova Strada Super Record,
1995 Bianchi Campione d'Italia, 1995 DeBernardi Thron
My C&V Bikes:
Quoted: 3978 Post(s)
Liked 7,417 Times
Expired Member
Liked 5,545 Times
Bummer OP wasn't around 10-15 years ago when this "discussion" was relevant, or at least not
Quoted: 827 Post(s)
Liked 1,967 Times
Your answer sounds like a reluctant revisionist RG who has lost faith in the rim brake, acknowledges the superiority of disc brakes, yet is stubbornly clinging to not want to admit it “on paper” by attempting to assert through some convoluted logic that they are the same.
Likes For kcjc:
Quoted: 4480 Post(s)
Liked 4,951 Times
Reluctance to change and obsession with weight (still both lingering). Maybe cost too at the lower end of the market. Mountain bikes really paved the way for bicycle disc brakes and it was inevitable that they would eventually find their way onto all other types of bike.
Likes For PeteHski:
Must be symmetrical
The fact is that disc brakes did not come first on bikes and there is a reason for that: they purport to solve a problem that didn't exist. So posing the counterfactual question makes little sense and isn't worth answering.
But i will: the fact that disc rotor diameter slowly approaches rim diameter over time suggests that eventually rim brakes will be back.
Likes For Frkl:
Bikes: old ones
Liked 10,416 Times
Must be symmetrical
If it were posed in cv, where people might actually know something to constructively respond, the thread would die because all the curmudgeons would ignore it. Since we are busy polishing our silver rim brakes. In General, it will turn into a multi page thread filled with the standard stuff
Must be symmetrical
I'm going to go adjust my friction shifters. Oh wait, they don't ever need to be adjusted. So i guess i'll just move on.
Likes For Frkl:
Liked 4,951 Times
Likes For PeteHski:
Must be symmetrical
Not that it will make a difference in changing your mind, but disc brakes on cars, and especially high performance cars, have gotten progressively larger in diameter until they are limited by the rim. But the rim on a bike doesn't limit in the way a car rim does.
either one goes for disc brakes or not, no one really cares any more , the arguments are all out there, and none are conclusive or convincing in either direction
Likes For Frkl:
Discs are the perfect example, along with tubeless and now hookless tubeless. Appropriate tech on a MTB, all sub-optimal on a high-end road bike.
You want the ultimate performance on a road bike, as in highest speed on pavement over a sustained period of time? Then you'll want a full carbon everything, rim brakes, tubulars, electronic shifting from circa 2015. No 2024 road bike can match this spec, no matter how much you spend.
Likes For Dave Mayer:
Liked 4,244 Times
As to the mechanism, hub mounted discs and rim brakes are exactly the same. Rim brake calipers push brake pads into a spinning disc of metal using friction to slow and stop the bicycle…just as disc calipers push brake pads into a smaller spinning disc of metal. Any differences are in details only. The principle, however, is the same.
Stuart Black
Stuart Black
Liked 4,244 Times
Stuart Black
Stuart Black
