Otero: I hate D[rew]i2 more than words can tell
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,404 Times
Those who've been around here for a decade might have an idea what's coming up given that thread title.
So a local friend - admittedly a flipper - picks up an Otero short wheelbase crit bike. "It was a good enough deal for the parts that were on it, but the owner said he modified it for Di2. That's when I realized he wrecked the frame."
So it *looks* fine...
...until:
Oh, and not only is this chainstay hole on one side, it's on the bottom too.
Apparently, someone thought this was an appropriate fix for a missing cable stop.
If the removal of paint pains you, it so happens that a lot of it is a cheap respray that happens to match the original pretty well. Nothing is particularly being lost by removing it.
Hijinks with the torch await.
-Kurt
...until:
-Kurt
Likes For cudak888:
Quoted: 3823 Post(s)
Liked 3,369 Times
the forum had a thread on a quality model Otero road machine from the mid-sixties a few months back
https://www.bikeforums.net/classic-v...cup-issue.html
aged to perfection
Quoted: 850 Post(s)
Liked 1,278 Times
that's terrible. somebody went crazy with their makita
/markp
/markp
Likes For mpetry912:
Likes For nomadmax:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4690 Post(s)
Liked 5,837 Times
Drillium!
Likes For gugie:
Quoted: 1627 Post(s)
Liked 630 Times
Oh dear.
Likes For Lascauxcaveman:
Bikes: Bike Friday PRP, Bike Friday NWT, Bromton M6R, 1991 Miyata 914, 1991 Miyata 1000, 1986 Raleigh Portage, many more frames
Quoted: 215 Post(s)
Liked 351 Times
Arguably worse than modifications made by the fixie crowd.
Likes For philpeugeot:
Likes For Dylansbob:
small ring
Quoted: 439 Post(s)
Liked 931 Times
well I guess I won't show my latest project....
59 Allegro Special -- 72 Bob Jackson -- 74 Motobecane Grand Jubile -- 74 Sekine SHS 271 -- 80 Nishiki International
Likes For droppedandlost:
Liked 4,404 Times
I figured this thing deserved a better end than the scrap pile, so...if the Woodrup wasn't enough...
Will this bike make me Reverse Drillium Dude?
I wouldn't entirely call this a Di2 hackjob; I think it would have wound up hacked one way or another with that cable stop. Di2 had no bearing on someone mercilessly drilling out the stay for that cable stop; that looks as if it was going to happen Di2 or otherwise.
-Kurt
Likes For cudak888:
Master Parts Rearranger
Quoted: 1556 Post(s)
Liked 2,027 Times
Definitely a lack of pageantry going on with those holes, opposite of, say, early Specialized Expeditions with holes at/near the BB and the lower head lug for rear-wheel-to-front-fender/end dynamo lighting. Modern bike frames built specifically for Di2 (these are often carbon) suffer the same sort of exclusivity (marginalization?) when it comes to being for sale. Mid-'80s Treks have a cable hole cut/formed at the BB end of the drive side chain stay and exit out the cast rear dropout. That's perfect, IMO, for routing a Di2 line without doing any structurally disapproved work in that sector of the frame.
Likes For RiddleOfSteel:
Quoted: 18400 Post(s)
Liked 4,526 Times
I've got a frame that I need to remove all the extra braze-on parts on it that shouldn't be there. Very bad mismatch between the shifters and dropouts.
Likes For CliffordK:
Liked 4,404 Times
-Kurt
Likes For cudak888:
Steel is real
Bikes: 1992Giant Tourer,1992MeridaAlbon,1996Scapin,1998KonaKilaueua,1993Peugeot Prestige,1991RaleighTeamZ(to be upgraded),1998 Jamis Dragon,1992CTWallis(to be built),1998VettaTeam(to be built),1995Coppi(to be built),1993Grandis(to be built)
Quoted: 671 Post(s)
Liked 985 Times
Unthinkable and terrible
I am potato.
Quoted: 1795 Post(s)
Liked 1,641 Times
I feel like I'm being trolled.
All of them. Any of them.
https://en.m.wikipedia.org/wiki/Stress_concentration
Car dependency is a tax.
Quoted: 1873 Post(s)
Liked 692 Times
2019 Salsa Warbird
2019 Salsa Warbird
Le Crocodile
Quoted: 370 Post(s)
Liked 788 Times
The through hole on the chainstay is the issue. A singular hole for Di2 can be "gotten away with' , ideally it's reinforced (requires brazing), but going all the way through is the sin, in the manner it was done.
Likes For Erzulis Boat:
Liked 2,027 Times
I've seen holes drilled for internal cable routing on a former CAAD10 of mine where it exited at the top of the chain stays nearer to the dropout, one for shifting (right stay) and one for the disc brake hose (left stay). There was reinforcement on each of those in similar form to internal top tube cable guides on steel bikes we've seen (as well as on this frame). It helped that the CAAD frames are not waifs. The size of the chain stay hole on this Otero in relation to the diameter of the chain stay at that point is what makes me a touch uneasy. Everything else looks fine enough to me, structurally. You plan to eventually send it along to someone else? [I am not asking this for me as the frame is much too small, and I have plenty on my plate already]
Bikes: a couple
Quoted: 563 Post(s)
Liked 867 Times
Consider a bicycle frame to be a cantilever bridge with each part between endpoints as a stressed member
When a body is on it, the whole unit supports that weight.
When part of that unit designed to be used as a unit is compromised that creates a failure zone.
Where that hole has been placed as well as the position of the hole is creating a weak point. unfixed the frame WILL break there.
Liked 3,369 Times
I've had a chance to see one time trial example in person; roughly the same era as the short wheelbase Swiss cheese I'm working with here. They're nicely-built machines, and the "OterO" bicycle logo on the seatstay caps is a fun touch.
-Kurt
-Kurt
wrt the fun Otero crest:
it is interesting to compare it with that of Cyclo of France
IIRC the CyclePro line of house branded products also made use of this idea for an emblem - at least in the early days...
expect there may well be others have not seen or do not recall
https://www.oterociclos.es/
Otero main
https://www.thebeautifulbicycle.com/...est-bike-shop/
Likes For juvela:
Liked 692 Times
Ah, I missed the hole going all the way through, that changes things.
2019 Salsa Warbird
2019 Salsa Warbird
Likes For shoota:
Edumacator
Quoted: 2475 Post(s)
Liked 3,202 Times
You beat me to it.
Personally, I think this is a job for 650b modifications... put a cantilever boss on the chain stays...stopping power would be excellent!
1987 Crest Cannondale, 1987 Basso Gap, 1992 Rossin Performance EL, 1990ish Van Tuyl, 1985 Trek 670, 2003 Pinarello Surprise, 1990ish MBK Atlantique, 1987 Peugeot Competition, 1987 Nishiki Tri-A, 1981 Faggin, 1996 Cannondale M500, 1984 Mercian, 1982 AD SuperLeicht, 1985 Massi (model unknown), 1988 Daccordi Griffe , 1989 Fauxsin MTB, 1981 Ciocc Mockba, 1992 Bianchi Giro, 1977 Colnago Super, 1971 Raleigh International, 1998 Corratec Ap & Dun, 1991 Peugeot Slimestone
Likes For jdawginsc:
