How often should I check my spoke tension?
Especially on my rear wheel? I ride with 2 panniers, total weight maybe 7kg max, 20km every weekday at least to the office and back.
24 spoke rear wheel.
Quoted: 125 Post(s)
Liked 29 Times
If the wheels were well built with equal spoke tension then a giveaway to go check what's wrong is the wheel becoming out of true. How much out of true do you tolerate in a way reflects how much spoke tension discrepancies you are happy with. But on a 32-spoke cross-lacing a spoke going essentially loose gets very noticeable on the rim going untrue, with caliper brakes you would know immediately.
Quoted: 125 Post(s)
Liked 29 Times
The person tightening the spokes (assuming he was tightening them all because he/you like stiffer wheels) maybe just felt the wheel could have been built stiffer.
There's indications on the rim what it can tolerate in terms of spoke tensions. What happens with some wheels is that when you pump them up especially tubeless they go "looser" in the spokes. This is totally normal and the manufacturers typically have a notice saying one should NOT be trying to account for that when lacing a new wheel (no tube/tire and no pressure).
The wheel if it keeps itself true is not going "bad", your LBS might just have felt like they prefer stiffer wheels.
I would careful especially with front wheels when tightening up factory made ones. On road bikes with rim brakes these often radially laced, as few spokes as possible, very high tension and recipe for having the flanges fail.
It's just my take, but unless your wheels go out of true often I would not be concerned - this all assuming the wheels were well-built from the start with equal spoke tension.
NB Trying to press the spokes etc I do not know some people claim they got the feel of it, I do not, I would be better able to tell e.g. ringing the spoke with a spoon or something (maybe do not do this with anodized ones) and hear different tone coming, but other than that this is what tension meters were made for.
Likes For am8117:
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
One concern, however, is that the LBS apparently tightened them while telling you they were well built. Tighter is not necessarily better, and can even lead to catastrophic rim failure if it's too much. Hope the mech used a spoke tension meter and knows what they're doing.
It's like riding a bicycle
Likes For urbanknight:
Quoted: 6196 Post(s)
Liked 4,811 Times
I will sometimes lightly squeeze pairs together or plink them. I'm looking more for just change from what they were before or for a really notable difference between them. Tension meters and stuff are for the wheel builders that know more about wheels than I do.
I will do it more often when I get a new wheel and less often as the get past the 300 mile mark. But probably once every 18 months or so I'll make a effort to check them all. Otherwise when I'm cleaning my bike I might grab a spoke or too randomly just to see.
Quoted: 2604 Post(s)
Liked 1,933 Times
I normally give the wheel a spin every week or two, and look for a sideways jump. If that's present, it's a good bet squeezing adjacent spoke pairs will find one that's noticeably loose.
Likes For pdlamb:
Quoted: 896 Post(s)
Liked 2,065 Times
I'd check before embarking on a tour.
Other than that, unless the wheel had a history of issues, then only if out of true.
Likes For downtube42:
Quoted: 125 Post(s)
Liked 29 Times
Unless you saw the mechanic literally giving birth at each and every spoke while "tuning your wheel", you can sleep peacefully at night. And that comes from me who has had a wheel come back out of dish from an LBS once and took up wheel lacing myself since.
If you were into more intricate details just for the fun of it, feel free to delve in:
https://spokecalc.io/spoke-tension-t...ive-guide.html
EDIT: Also this is rear wheel we are talking, if the LBS went crazy tight it would very likely bring the whole wheel out of dish. If you have rim brakes you would have noticed right away, if not you can check still.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
So I first thought about dropping in the "too high tension might be counterproductive", but then to ease off the OP mind a bit after this last comment above let me say this: If you want read the recommended tension off the rim (it will look something like max 100kgf or 950 Nm or a range). If you cannot find it try to find out what rim model it is. I could tell you that overtightening spokes for beyond e.g. 1200 Nm is physically hard to do with normal spoke wrench, it just does not feel right and I cannot picture an LBS mechanic doing this around the whole rim without feeling the pain. Lots of wheels can take up to 1200 Nm and I would expect yours to be at that end because how else does one build a 24-spoke stable wheel than with high spoke tension.
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
I would suggest just spinning the wheels off the ground and checking for wobbles for the time being.
RUSA #7498
Originally Posted by noglider
Likes For KerryIrons:
Drip, Drip.
Bikes: Trek Verve E bike, Felt Doctrine 4 XC, Opus Horizon Apex 1
Quoted: 1034 Post(s)
Liked 193 Times
Never in my experience have I used a wheel which maintained spoke tension over a long period of time.
I usually go based on feel with a spoke key, starting first with the drive side, then moving to non drive, using less tension on non drive. Id make sure to at least check every month or so.
Bikes: 2012 Specialized Elite Disc, 1983 Trek 520
Quoted: 676 Post(s)
Liked 741 Times
Ditto those who say if it ain't broke don't fix it. If you have disc brakes, check trueness often, as every day you ride, certainly every time you use the tire pump. The tension gauge is useful for a new build with a new rim, or for trouble-shooting weird problems or a major repair. After that, the real world takes over, especially for a daily commuter, and tensions will not be uniform.
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
A well-built wheel shouldn't require routine retensioning. Check tension if/when it goes out of true. If it keeps going out of true, rebuild or replace the wheel, perhaps with more spokes.
Likes For JohnDThompson:
Liked 2,568 Times
Likes For ThermionicScott:
60,000+ miles of riding on New England roads and I've never checked spoke tension, but I do suppose that it's been checked the few times when my wheels have been trued.
My last set of wheels (Bontrager Aeolus3 D3) needed one truing in ~25,00 miles of riding, they were destroyed when I was hit by a car.
I've got a set of 2010 Bontrager RXL's that I bough used, and have added >10,000 mile to, they spin laser straight.
Currently have 1,000's of miles on Bontrager XXX2 rim & Aeolus Pro 51 Discs, no truing needed thus far.
I did have a set of 2013 Bontrager RXL's that repeatedly snapped spokes, they were checked over & over and even when true, the spoke tension was all over the place. The wheels were eventually replaced under warranty.
I'm not sure if or why I'd need to check tension except if the wheels couldn't stay true or if I had problems with spokes breaking.
Over the hill
Quoted: 998 Post(s)
Liked 1,206 Times
Quoted: 125 Post(s)
Liked 29 Times
1) How a a well-made wheel would start its life
2) What would happen uniformly by itself, i.e. without coming out of true at the same time
Likes For am8117:
Super Moderator
Bikes: Surly Crosscheck
Quoted: 1542 Post(s)
Liked 868 Times
I have been riding my Surly for over a decade, probably closing in on 2. Thousands of miles. I have never thought about checking my spoke tension. I hope I didnt jinx myself.
Good Night Chesty, Wherever You Are
Likes For making:
Bikes: Homebuilt steel
Quoted: 2193 Post(s)
Liked 425 Times
A year or so back, I decided to upgrade the Mavic Open Pro's on one of my older wheelsets to some wider rims, just because. The wheel was "true enough," but upon breaking down the wheel I found several of the brass nipples sticking pretty bad on the spokes. I used grease on the spoke threads when originally building the wheels. So question being, what maintenance should be done on wheels, other than obvious bearing maintenance? It seems to me that waiting for the wheel to go out of true may not be the best course of action in the long term.
Quoted: 4415 Post(s)
Liked 4,871 Times
Only time I've ever seen a spoke fail was on a group ride last year. The guy said he'd just had his spokes re-tensioned the previous week! Personally I just don't bother. I might give them a quick check once in a while to see if there are any obvious issues, but I've never had any issues with spokes in many decades of riding.
