Handlebar Tape from the Top?
Quoted: 3513 Post(s)
Liked 2,927 Times
I've wrapped hundreds of road bike handlebars in my time. I have never even considered wrapping from the top to the ends. Yet I've seen several examples of this in the C&V forum. What would be the benefit?
Liked 2,927 Times
Quoted: 1562 Post(s)
Liked 1,734 Times
It's not much of a bulge when you are using silicone bar tape- you can kind of control the thickness by stretching out the silicone wrap. When you are using silicone bar wrap with no electrical tape , there is zero glue residue anywhere. None on the bar and none on the bar tape itself. You can take it off and rewrap as often as you want.
Bikes: Still have a few left!
Quoted: 467 Post(s)
Liked 532 Times
Tried it on one of my commuter bikes prior to retirement. Liked the clean, no finish tape look but the exposed edge soon developed curl where my hand positions were located. Still, must not have bothered me much, as rode with it for a couple years, or perhaps I was just too cheap to replace it early. Don
Liked 2,927 Times
Quoted: 1610 Post(s)
Liked 2,593 Times
I go top down sometimes. Not sure what bulge you speak of...
Likes For curbtender:
2k miles from the midwest
Quoted: 525 Post(s)
Liked 931 Times
I've tried silicone a couple times. I'm not a fan of the feel, but my problem was it tore on the edge of the brake lever body.
You used to see a lot of Benotto and cotton wrapped top-down. I think one of the problems with that technique is your hands can roll down the edges when riding on the hoods. As bike fit/STI forced more riders to ride on the hoods, the industry moved to "cork" tapes and bottom-up wrapping. I was always taught if you start your tape on the tips and wrap up-and-away as you move towards the clamp, it won't be as likely to roll.
Likes For Dylansbob:
Quoted: 1952 Post(s)
Liked 2,013 Times
I thought this was an April Fool's joke.
Likes For Classtime:
Quoted: 1829 Post(s)
Liked 3,376 Times
Likes For steelbikeguy:
Quoted: 3464 Post(s)
Liked 2,831 Times
Likes For repechage:
working on my sandal tan
Quoted: 3871 Post(s)
Liked 2,568 Times
I've tried the top-down wrapping once or twice. It does have the advantage that it holds itself in place nicely as you work, but if you're not using a thin tape and/or shellacking it down when you're done, it will curl on the tops after some riding.
I have gone to, and will advocate to anyone who will listen, starting my wrap at the brake levers and working outward in both directions. It's probably the most fiddly of all methods short of harlequin wrapping, and you need something to hold the tape in place at the brake lever while you work. And then you still have to use tape or twine or something to finish the ends near the stem. But the beauty of this method is that the tape will not curl up from riding in any position on the handlebars! It just stays put and resists shifting because it's been wrapped in the opposite direction of your hand pressure.
Likes For ThermionicScott:
Liked 2,927 Times
Liked 2,927 Times
Likes For smd4:
Henderson, NV
Bikes: Trek Alpha 3700, GT STS DH, Raleigh Grand Prix, Fisher Montare, Fisher CR-7, Fisher Aquila, Diamondback Sorrento, The Bike Beat Revolution, KHS XC 504R
Quoted: 322 Post(s)
Liked 596 Times
I've always wrapped from the top down.
There is no need for any additional tape that way. At the end just pop on the bar end plug and you're done,
No adhesives needed.
Likes For Desert Ryder:
Likes For Aardwolf:
Likes For BFisher:
Liked 2,927 Times
Did I say I cared? People can use foam for all I care. Just curious what any benefit would be gained. Personally, I can't see any benefit. Wrapping from the top down only seems to open up the possibility of the edges of the tape being pushed.
Quoted: 1641 Post(s)
Liked 831 Times
The point of wrapping from bottom up is so the natural downward and forward pressure from your hands will not catch the edges of the tape that could eventually force the seams between the turns of the tape apart.....
this was more problematic with the older cello type tapes. Newer padded tapes were a bit better at resisting this separation as they incorporated adhesive backing, but seams can still separate and expose the metal handlebar when the adhesive breaks down from heat and age....
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto/Raleigh/Legnano
Quoted: 987 Post(s)
Liked 641 Times
Loved the look until after the 2nd or 3rd ride.
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto, 1973 Raleigh Gran Sport, 1974 Legnano. Susan: 1976 Windsor Profesional.
Quoted: 767 Post(s)
Liked 1,898 Times
Framing the topic as you did, and then retorting that you'll just stick to what you deem better is quite an odd thing to do when the biggest factor in something like this is personal preference. It suggests that, yes, you do care. Otherwise, why ask why others do what they do?
Likes For BFisher:
Liked 2,927 Times
Quoted: 4806 Post(s)
Liked 3,932 Times
I love to climb hard. My hands are hard on bar tape. Top down jobs I wear to unacceptable (and with cloth, full tears) very fast. From the bottom the tape stays completely rideable long after I've worn holes to the bars.
Quoted: 525 Post(s)
Liked 931 Times
I have gone to, and will advocate to anyone who will listen, starting my wrap at the brake levers and working outward in both directions. It's probably the most fiddly of all methods short of harlequin wrapping, and you need something to hold the tape in place at the brake lever while you work. ....
Quoted: 2588 Post(s)
Liked 4,824 Times
A little flair, but no unsightly bulge here:
Shellac ensures curling tape isn't a problem, whether you wrap top-to-bottom or bottom-to-top. In any case, if you regularly exploit all the real estate of a drop bar, at some point you'll be putting your hands on an area where the overlap can become curled up over time by contact.
As for the question of the benefit of taping top-to-bottom: what's the benefit of taping bottom-to-top? This tape direction argument never seems to get old, does it?
DD
DD
Likes For Drillium Dude:
