Where to find downtube cable stops?
I have a Raleigh Technium 440 that I'm restoring for one of my room mates.
Everything is going well, however the plastic double cable stop on the underside of the downtube is broken into half, and no longer bolts to the frame.
The LBS I checked out didn't have one - and the only one I can find online is a nice metal one @ Rivendel Bicycles. I'd prefer not to spend $18 on this part though, although the riv bike one would probably out last the technium frame.
Are there cheaper options available elsewhere?
Palmer
Quoted: 1671 Post(s)
Liked 1,826 Times
A reasonably well stocked bike shop should be able to fix you up with a Jagwire stick-on cable guide and cable stop insert.
HTH,
tcs
HTH,
tcs
Quoted: 1572 Post(s)
Liked 643 Times
Oh man!
I had one but I've either thrown it away or stashed it somewhere that I can't find easily. I'll keep looking.
I have a clamp on down tube double cable stop, but it's the wrong diameter for your Technium.
Sorry.
Sorry.
Bianchi Goddess
Quoted: 2935 Post(s)
Liked 2,930 Times
are you looking for a cable housing stop of some type or a cable guide that bolts to the bottom of the BB shell?
https://www.loosescrews.com/index.cgi...d=386052823748
Sugar "Kane" Kowalczyk
Liked 643 Times
Raleigh Techniums were their own animal. The double cable stop was a plastic piece that screwed into a fitting under the down tube and about 5 or 6 inches from the head tube. I took the one off of my Technium when I converted it to fixed gear. Unfortunately, I reasoned that's such an unusual bike that I probably threw away the part.
Bianchi Goddess
Liked 2,930 Times
IC that is likely going to be a hard part to find.
GO BIG RED
Bikes: 1996 Bianchi Veloce 1993 Bridgestone MB-3 1992 Trek 700 1992 Trek 820
Something like this could possibly be made to work.
https://www.novacycles.com/catalog/pr...roducts_id=595
Back in the day I had a Raleigh Technium 400 that came with stem shifters. But I thought downtube shifters were much cooler so I fashioned a downtube clamp out of some white thick wall PVC and homemade shifter bosses to mount some DT levers to. It looked kinda funky but it worked well. I rode that bike with that setup for years. I don't know whatever became of that DT cable stop either.
Gear Hub fan
Bikes: Civia Hyland Rohloff, Swobo Dixon, Colnago, Univega
I recently machined an aluminum cable stop for a friend who has a Technium 400. He had not ridden it for years due to the plastic down tube cable stop being broken and a replacement was not available fom Raleigh even years ago when it broke. He also told me that at the time the LBS could not find a replacement or substitute either.
The original, and my replacement, mounted to the frame via a standard 5mm mounting boss that looked like a single water bottle holder mounting boss.
The Tektro clamp-on stop linked to by Panthers007 should work if the correct diameter for the downtube. With the popularity of SS/FG conversions and use of FG frames for IGH conversions there are a lot of parts like that available now which were not available in the past. Maybe too the Internet has made it easier to find them.
Gear Hubs Owned: Rohloff disc brake, SRAM iM9 disc brake, SRAM P5 freewheel, Sachs Torpedo 3 speed freewheel, NuVinci CVT, Shimano Alfine SG S-501, Sturmey Archer S5-2 Alloy. Other: 83 Colnago Super Record, Univega Via De Oro
Visit and join the Yahoo Geared Hub Bikes group for support and links.
https://groups.yahoo.com/group/Geared_hub_bikes/
Bianchi Goddess
Liked 2,930 Times
OMG I think I know some one else who can use that too
Bianchi Goddess
Liked 2,930 Times
Hello did you get a housing stop yet? you will not believe this but I have one!! I was looking through my stuff here at the house and I said hey what the _____ is this? let me know if you still need it.
Same problem can't find this plastic double cable stopper for a Raleigh Record.
Any one no where I can this plastic double cable stopper for a 1986 Raliegh Record.
Back In The Saddle
Bikes: N+1
Quoted: 87 Post(s)
Liked 8 Times
In life there are no mistakes, only lessons. -Shin
smelling the roses
Quoted: 7081 Post(s)
Liked 901 Times
Raleigh Record 1986 same problem
Generally bewildered
Quoted: 1152 Post(s)
Liked 341 Times
You could go retro and get a Campy cable stop (only 40 bucks on ebay!)
Quoted: 741 Post(s)
Liked 818 Times
(For $11 the Rivendell part is also hard to beat). Lots of choices.
Liked 341 Times
Slightspeed, I agree: SunTour stuff is terrific. They really beat out Shimano in the early derailleur design improvement battle.
I just stripped all the Nuovo record stuff off my Paramount and will be selling it. The Campy stuff was all great, but the Suntour ratchet bar end shifters I used were absolutely wonderful.
Looks like a sweet setup on your Raleigh. They made some great frames. I had a 531 Competition (in Lavender!) that was wonderful. Got stolen in college, though. Enjoy your Super Course.
