Edge 830 out in front mount
Hills!
I just mounted my Edge 830 on my bike yesterday. Due to cable routing, I need to mount the out in front mount on the right side of the clamp. The OIF mount comes configured to mount to the left of the clamp, so the computer is centered.
I didn't see an obvious way to reverse the mount, so I mounted it on the right side of the clamp, but the computer sits off to the right of center now.
Did I overlook something simple? I took the mount apart but didn't see an obvious way to invert the attach point for the 830. Is this not possible?
Quoted: 6193 Post(s)
Liked 4,808 Times
I don't think you overlooked anything obvious except that it doesn't have to be in the center unless that is where you want it. There are the little quarter turn mounts that Garmin has and others make that mount on your stem. They are what I used on my two older bikes where cables coming out from under the bar tape were an issue.
Hills!
I considered the stem mount... but I have a very short stem. Might try it anyway.
Thanks for confirming the OIF mount is not reversible. I am a bit surprised by that, but no worries. I can live with the 830 being off center. It's not *that* bad.
Quoted: 152 Post(s)
Liked 173 Times
Amazon has a bunch of cheap mounts that go on the right side. Can't speak to the quality though. K-Edge mounts are great and all alloy but somewhat spendy. Having my 830 offset like that would drive me bonkers.
Interestingly, I had the opposite problem with the right side mounts had interference issues with my brake line.
Quoted: 54 Post(s)
Liked 175 Times
I have my Garmin Edge mounted to an F3 Form Mount. It attaches to either the upper or lower bolts of the stem clamp.
https://www.f3cycling.com/formmount
Quoted: 3236 Post(s)
Liked 2,080 Times
Hills!
Those are some great suggestions. Looks like the K-Edge Sport is one of the lesser expensive options, short of re-routing the brake cable that currently interferes with the left side mount.
https://smile.amazon.com/K-Edge-Hand...%2C146&sr=8-11
Unfortunately, there are a number of reviews that are not very favorable for it. And some of the cheaper ones show pics of broken mounts. Guess you get what you pay for!
Liked 2,080 Times
Hills!
I think I'm just gonna live with the stock Garmin mount as is and put the money I'd otherwise spend on another mount towards a Varia RTL515.
Likes For speedlever:
Liked 4,808 Times
One time I had an out front mount that would fit very wide diameter bars and on my smaller diameter bars I was able to cut a grove in the adapter for it to let my cable go under the clamp. It was a very tight fit.
Soon after I was having some shifting issues that I thought might be the clamp and took the out front mount off. Later I found the cause of the shifting issue was something else, but never put the out front mount back on.
