Decoding of Eddy Merckx frames
#351
Hello everyone !
I would like to identify my Eddy Merckx bike but throughout forums and online discussion, I couldn't find any clue as the serial number does not match anything found.
The serial number is as following left side of the logo : A0 right side of the logo : 930
I should mention that the logo mentioned (bottom bracket) is the same as the one from post #252 on this thread. It is etched where you find the serial number as mentioned above It is also the sticker on the frame itself, like the bike from post #252.
I'm sure that the bike is genuine. It is in Domex-Weinmann Team's colors (Blue, yellow and white), full Campagnolo C-Records parts, Columbus fork and frame.
If anyone would help me I would be happy to know more about it's history. I unfortunately cannot post pictures for the moment, hence the description, I will gladly provide some when possible. I can answer questions about the bike if needed, although my bike knowledge is not the greatest.
Thanks in advance !
Thanks in advance !
#352
Quoted: 233 Post(s)
Liked 396 Times
A0 930 fits very well into the early markings scheme (first "letterless" series) from 1980
If your frame has the same bottom bracket model and how to combine dropouts and stays as #252, the frame was built at the end of 1980...
The Domex Weinmann painting pattern only appeared in 1988, the frame had to be repainted.
#353
Quoted: 786 Post(s)
Liked 520 Times
Question for owners of (and experts on) early Merckx frames (1980-1983): what's the tire clearance like? Could one run 28s? I've been keeping my eye out for a ~62cm, old-logo, flat crown specimen, but am wondering if the tire clearance is more like '70s loose or '80s tight?
Thanks,
-J
Thanks,
-J
#354
aka: Dr. Cannondale
Quoted: 2155 Post(s)
Liked 3,404 Times
Thanks,
-J
Thanks,
-J
Most of the early 80’s ones I’ve had my hands on are maxed out at 25’s as well.
Likes For rccardr:
#355
Bikes: Numerous
Quoted: 1677 Post(s)
Liked 3,097 Times
Beautifully preserved card - it can be a proof of the original painting (and only possible corrections). "Go" or "Co" - pure speculation... I have already reached "Green over" and "German overspray" In fact, we need for happiness the second frame from 1988 originally painted in Stuttgart "camo" with a preserved card or any EM with a card with an identical marking - I am afraid that only this will explain the situation. Another silly question: is EDDY MERCKX on brake bridge painted black or fuchsia?
Translated with www.DeepL.com/Translator
55 cm Professional, Reynolds 753. Top line matches serial # on frame
Professional Reynolds 753 in Kelme colors (Thank you CM, for your other thread in which I learned of the early Kelme colors!). I wonder if the "Go" is actually a number - 60, as the same position looks like 31 on mine.
#356
Quoted: 233 Post(s)
Liked 396 Times
100% digit - thank you
I don't know how long the codes were used, I'm not even sure if it was color codes (there would be a lot of them!) or e.g. next batches of built frames (more data is needed - as usual)
It's nice to see the 55/753...
#357
Quoted: 34 Post(s)
Liked 22 Times
I am working my way through this thread and came upon this post. Maybe my own bike can help decipher. This is the steerer from my 1985-ish
#358
Quoted: 211 Post(s)
Liked 199 Times
Thank you Jacek for all your efforts and help with our EM bikes !!!
It is all greatly appreciated.
I am still trying to figure out how to determine the year. You have confirmed mine is a 1990 and not a 1985 and I thank you.
W 5TTB and C 1649
I know it's a 55 and TSX Columbus tubing and made in the summer of 1990
This I learned from CM..Jacek !!!
And what, if any....is the difference between a Century .....and a Century Geo ??
Sorry to be a bother, but my curiosity and ocd mix is getting the better of me
Thank you again
W 5TTB and C 1649
Thank you again
#359
Quoted: 233 Post(s)
Liked 396 Times
The Century model was to introduce the "century geo" into EMC
Century was built between 1988 and 1994, first from Reynolds 653 tubes, then from Columbus TSX; in 1995 it was replaced by the Arcobaleno model.
The 'century geo' was gradually being replaced by new models of EMC frames:
- 1990 Corsa Extra Max
- 1991 Corsa Extra and Corsa (at the same time "road racing geo" was still used)
- 1992 Mx Leader
- 1994 Titane EM, Corsa Thron
- 1995 Corsa 01, Arcobaleno, Strada OS, also alu frames.
"century geo" was used until 2003, when some modifications were made (that is why the names Team SC 3, Millennium 3 appear)
- 1992 Mx Leader
#360
Quoted: 211 Post(s)
Liked 199 Times
All great information !!
thank you
What would 2 on one side and E with 4367 below
color is yellow.
Again....all your knowledge is greatly appreciated
#361
Quoted: 233 Post(s)
Liked 396 Times
Professional model
2 = 52 cm seat tube (c-c)
E4367 = serial number, frame built in 1982
The frame has been repainted, some stickers are inappropriate
#363
Hi everyone,
new in this forum, I found a mxl in my size
The engraving in the BB
P F6459
I was told the frame was brought from Belgium. not an expert but I have never seen this paint scheme.
on the top tube says "Geant Bruno"
any idea?
P F6459
any idea?
#364
Quoted: 233 Post(s)
Liked 396 Times
P F6459 = 1995
for the paintwork pattern please refer to the EMC 1995 and 1996 catalogues
Bruno Geant - first proud owner of this bike (not widely known)
#365
Steel is real
Bikes: 40 - accumulated over 40 years
Quoted: 375 Post(s)
Liked 1,081 Times
I presume the frame to be really large considering the first owners name. Otherwise it would/could be ironic...
géant
nom
adjectif
énorme
géant
nom
- 1.
Personne dont la taille dépasse anormalement la moyenne (gigantisme).- Les Géants de la mythologie
nés de la Terre (Gaïa) et du Ciel (Ouranos). - À pas de géant
très rapidement. - Les géants de l'automobile, du textile
entreprises les plus importantes dans le domaine.
- 2.
Génie, héros, surhomme.
Les géants de l'art, du sport.
adjectif
- 1.
Dont la taille dépasse de beaucoup la moyenne.
Tortue géante.
h
Liknande:
colossal
énorme
- gigantesque
- 2.
Étoile géante
de grand rayon, peu dense, très lumineuse.
#366
géant
nom
adjectif
énorme
géant
nom
- 1.
- 2.
adjectif
- 1.
Tortue géante.
h
Liknande:
colossal
énorme
- gigantesque
- 2.
Étoile géante
#368
greetings all
I'm in the hunt of EM corsa extra, and I found this corsa extra with 90s production colorway (most likely). wanna make sure the frame is Corsa Extra and the tubing is Columbus SLX. The frame also has headtube cable guide. Greatly appreciate if anyone can help decipher the bb shell code, its L C9175 (pictures attached - error cant upload pic yet ).
thanks in advance!
thanks in advance!
#369
Quoted: 233 Post(s)
Liked 396 Times
Bruno Geant - VLP or VLB scheme painting (94-97)
L C9175 - end of 1991
There should be additional markings around L, check steering tube (card?)
Likes For CyclesMakaron:
#370
Bikes: 1980's Spectrum 10 sp Campagnolo Centaur, 1990 Eddy Merckx 10 sp Campagnolo Centaur, Bushnell Tandem, Co-Motion Speedster Tandem
Quoted: 185 Post(s)
Liked 102 Times
I've been meaning to put this up here to see what the date and info is. I've had this since 2001 when I purchased it from a fellow in South Carolina. Unfortunately it had been used on a trainer and sweat accumulated around the top tube pump and created a significant amount of rust and bubbling in the pain. Off to hot tubes for paint. I've not been a fan of chrome so had the frame fully painted covering the chrome. This is a daily rider so is showing chips and scratches but rides like a million dollars.
#372
few images in spoiler:
Spoiler
#373
Quoted: 233 Post(s)
Liked 396 Times
C9715 - that changes things a bit
This is a team frame built in late 1991 for Telekom (for 1992 season), rebuilt and repainted ~94/95 (PS paint scheme - 1996 catalog)
2p.chroom - chrome paint scheme
later - frame repainted in EMC
#374
so is it corsa extra? SLX / TSX tubing?
#375
Quoted: 233 Post(s)
Liked 396 Times
Corsa Extra or Century
SLX, TSX or Reynolds 753
The team frame does not have full technical markings
Are there "riflings" inside the tubes? (steering tube and all tubes visible through the BB cover) - if so: SLX or TSX; if not: R753
The distinction between SLX and TSX is completely crazy - but it can be done...
