Fork for 29r
Not lost wanderer.
Quoted: 885 Post(s)
Liked 990 Times
Fork for 29r
i have a Giant Revel here in Cambodia. I have upgraded it to 10 speed Deore XT with a 13 to 42 rear cassette
looking for a nicer fork that will work.
Tiocfáidh ár Lá
I don't really have an answer for your question but wow! What's it like riding in Cambodia?
n00b
Bikes: Surly Karate Monkey, Twin Six Standard Rando
Quoted: 428 Post(s)
Liked 466 Times
I don't have a specific recommendation, but it looks like you're looking for something that has a "straight steerer tube" and not a "tapered" one. you'll need to confirm the internal diameter of your head tube. if the ID at the bottom of is is 44mm, you can put an external cup for a tapered fork and use a more modern fork. forks still manufactured with straight steerers are harder to find because that's old technology.
I can't tell what kind of axle your bike uses from the photo, but it's likely a 9mm quick-release. that means you do NOT want a "boost" fork, nor one with with a 15mm thru axle. doing that would require a new front wheel (or at least a front hub if you're willing to build a new wheel from the rim down).
I'm not sure if you have access to it, but SR Suntour has an excellent upgrade program. Something like an XCR32 Air or Epicon can probably be found with a straight steerer and QR.
Not lost wanderer.
Quoted: 885 Post(s)
Liked 990 Times
Rainy season can lead to some real clay mud.
Tiocfáidh ár Lá
Wow! hahahah yeah that is some mud there. I've been reading a lot about Cambodia lately I'm glad to see how far they have come.
