Building frame, ten years on.
Ten years ago I got the bug, built five frames and gave four to my kids, fully equipped and ready to ride. I made a couple mistakes on mine I had thought I would live with, but five years ago I bought tubes from Henry James and lugs from Richard Sachs, intending to correct the errors but keep the same geometry, which was perfect for me. I am now faced with the daunting task of re-learning enough to get this frame built, working from my original drawing, which is barely adequate. It seems that when you are engrossed in a subject you can fall short on documentation, carrying much of the information in your head - not the best place, I am finding. First completed joint was the seat tube to bottom bracket. Twenty minutes brazing with silver, eight hours filing, grinding, sanding and scraping to remove excess silver inside and out, plus trying to figure out how, after facing the bottom bracket, the seat tube seems to need tweaking UP on my alignment table, but when I reverse the BB it still wants to go up. Seems to me I should get the opposite reading, but that’s not why I’m posting. After ten years, most of the suppliers I bought things like cables, braze-ons, seat stay tips, rack bosses and inserts, etc. from are not around or have limited stock. If I don’t screw up any tubes or lugs, I will need to buy these things. I plan on using my old Ultegra components, they still look pretty good. Can anyone suggest current sources for those items I mentioned? Has Amazon become a good place to look for bike stuff?
Randomhead
Liked 3,697 Times
I would order from Framebuilder supply probably. Nova is OOS of a lot of things and they just moved. Not sure how responsive they are right now
But this thread is proof that nobody reads sticky threads.
https://www.bikeforums.net/framebuil...suppliers.html
If you watch Paul Brodie's video about making and aligning the front triangle, he says that the heat always shrinks the top of the bb shell. Pretty interesting video
Don't know if it's part one or part 2
Likes For unterhausen:
Don't know if it's part one or part 2 https://www.youtube.com/watch?v=kVLruIgvVsc
Thanks for the link to Paul Brodie. Watching him work is like taking a refresher course, plus I got to see what the process looks like when done a master.
The frame I built this winter I salvaged cable guides from an old Schwinn. Heated them up and pulled them off the old frame. They cleaned up nicely and was easy to do. I also salvaged a brake bridge and chain stay stiffener. Maybe not ideal or fancy, but it worked out quite well.
Quoted: 321 Post(s)
Liked 263 Times
You could probably use steel car brake pipe for cable guides. Brodie says it's the same size as that tubing he uses. Or even the copper stuff if you could work out how to solder/braze it on.
OP here, problem solved. Silver brazed the dt/ht, came out pretty good, but about one degree off the desired angle. I was coldsetting, with pipes inserted in both tubes. After maybe five attempts with little change, I, naturally, pulled harder. The moment the dt kinked it sounded like a gunshot. I think this project has reached it’s conclusion. Of the problems I was trying to fix on my current bike, I think they can be solved without building a whole new frame. One is that the chainstay bridge, which is just a piece of tubing, is too far back, which means I have to deflate the tire to remove or install it. The other is rust, which powdercoating didn’t prevent. I’m thinking of stripping the finish off in the bb area and replacing the chainstay bridge with one of the cast ones with tire clearance, if I can find a source. Then send the whole frame to the powdercoaters for sandblasting and recoating. I’ve heard that some colors require two coats, therefore more rust protection. Sound reasonable?
Quoted: 4205 Post(s)
Liked 3,863 Times
lbgary- No surprise that you kinked a tube setting it. Chainstay bridge replacement is an easy enough job. But do know that cast or not you'll likely spend nearly the same amount of time doing the replacement. I wouldn't consider thicker PC to be any more rust proof then thinner. From what I've been told the real issue is with how PC and steel mate together and not how much PC sits on top of the steel. Andy
AndrewRStewart
AndrewRStewart
Randomhead
Liked 3,697 Times
that stinks about the tube kinking. It's a disadvantage of modern tubes. BITD, you could wail on them and nothing bad would happen.
Old fart
Quoted: 3588 Post(s)
Liked 3,400 Times
Dave Tesch used the rollers from SedisSport chains for the top tube housing guides. As others have noted, you can salvage braze-ons from derelict frames. I have a whole pile of bottom bracket cable guides and chainstay cable stops I fished out of the scrap barrel at Trek when marketing had us move shift cable routing from above the bottom bracket to underneath.
Likes For JohnDThompson:
Funny you mentioned Dave Tesch. I have a Tesch frame built up with all Dura Ace components from around 1986, It’s mostly in great shape except for quite a lot of deep rust where the rear brake cable housing exits the top tube, right where most of the sweat drips off my chin. Last frame I built I routed the cable through the tt, but used some full length stainless tubing to run the cable housing through. I’ll have to ask my daughter if there is any rust appearing.
Andy, I’m now thinking of just eliminating the chainstay bridge. Reading old posts, it seems that their value is debatable. Only an inch forward is a cast-in bridge which is part of the bottom bracket. By the way, what is PC?
Quoted: 321 Post(s)
Liked 263 Times
As the great Brodie said in one of his videos he once met a guy who never made any mistakes. He never did anything.
Old fart
Liked 3,400 Times
Liked 3,863 Times
Agreed that the CS bridge is not really needed (assuming no fenders). And now with disk brakes the SS one isn't really needed. Still I like their look and they do hold my brakes and sometimes fender. Andy
AndrewRStewart
AndrewRStewart
Here is one of the issues I have with my old frame. Rust, plus the chainstay bridge I will eliminate.
Here is the other problem, though it’s never really bothered me. On assembly, I found that the rack was too low and interfered with the brake arm, so I cut a new piece of tubing with the bend in it and had the rack re-powdercoated. Maybe I’ll raise the rack, maybe not.
Liked 3,863 Times
I don't think the rack is too low but that the stay mounts are poorly located WRT the brake. I see this all the time with production bikes (along with other common "braze on" placements that might work on the 58cm sized frame but not the 50cm one).
To the rust- is this a PC or a wet job? Rust like this, focused on the edges and corners of the surface of the frame, usually speaks to the exposure amount, the pre paint prep and the paint's chemistry and lay down. Andy
AndrewRStewart
AndrewRStewart
Randomhead
Liked 3,697 Times
That's a nice looking rack
Bikes: Homebuilt steel
Quoted: 2193 Post(s)
Liked 425 Times
I had rust on one of my early frames just like the photo because I didn't soak all the flux off. In fact, I didn't soak the frame at all, just removed the flux on the outside using mechanical means. Flux is acid and needs to be removed.
I thought the same, though I did soak it quite a while after brazing. It seemed to me that the rust first appeared at the sharp outside corners of the lugs, so I thought it was due to too-thin powdercoating.
Liked 3,863 Times
PC is essentially a plastic that has been melted over the frame. It has less attraction/bonding with the frame then a proper primer does. It doesn't like going around sharp edges. It is relatively porous to water (compared to wet paint). And it's an application that is built around it's low cost which, IMO, welcomes taking short cuts in the prep before powdering the frame. So no rust inhibiting (phosphate) treatment is not uncommon. I've even been asked if the job needed sandblasting first!
So when I see PC jobs with rust issues I am not surprised. Andy
AndrewRStewart
AndrewRStewart
Likes For lbgary:
