Centre-pull hangers are all too short, so...
Old 11-24-20, 09:27 AM
oneclick
Quoted: 235 Post(s)
Liked 221 Times in 143 Posts
I made my own.
It's just a nut, drilled and tapped M6x1, silver-soldered to a bent spoke. It goes around the seatpost clamp bolt.
AND they all rust except the Mafac stainless ones - this won't: Brass and stainless and silver.
Anybody else want one?
oneclick is offline
Likes For oneclick:
Old 11-24-20, 09:32 AM
SJX426
SJX426's Avatar
Quoted: 863 Post(s)
Liked 480 Times in 308 Posts
@oneclick - Show us the application please.
SJX426 is offline
Old 11-24-20, 09:39 AM
oneclick
Quoted: 235 Post(s)
Rear brake (thot that was implied by "seatpost clamp bolt).
oneclick is offline
Likes For oneclick:
Old 11-24-20, 10:18 AM
tiger1964
tiger1964's Avatar
Bikes: Drysdale/Gitane/Zeus/Masi/Falcon/Palo Alto
Quoted: 330 Post(s)
Liked 69 Times in 51 Posts
Great idea for thinking outside the box. Hmm, I have no idea what the tension load is on the part under hard braking... those connections will hold?
Larry:1958 Drysdale, 1961 Gitane Gran Sport, 1974 Zeus track, 1988 Masi Gran Corsa, 1974 Falcon, 1980 Palo Alto. Susan: 1976 Windsor Profesional.
tiger1964 is offline
Old 11-24-20, 10:53 AM
squarenoise
squarenoise's Avatar
Bikes: 80 Raleigh Competition, 83 Freschi Supreme, 84 Miyata 610, 84 Miyata 1000, 86 Miyata 1000, 89 Marin Pine Mountain, 93 Specialized Stumpjumper, Soma Smoothie, Surly Cross Check
Quoted: 42 Post(s)
Liked 77 Times in 31 Posts
I have one of these on my Surly Cross Check: https://surlybikes.com/parts/cable_hanger
squarenoise is offline
Likes For squarenoise:
Old 11-24-20, 11:06 AM
unworthy1
Stop reading my posts!
unworthy1's Avatar
Quoted: 666 Post(s)
Liked 249 Times in 204 Posts
I also would like to see how it installs, but yes, I am interested! Always appreciate it when C&Vers are also skilled DIYers, we have had many examples over the years!
unworthy1 is offline
Old 11-24-20, 11:09 AM
mrv
BIKE RIDE
Bikes: my very own customized GUNNAR CrossHairs
Quoted: 245 Post(s)
Liked 53 Times in 40 Posts
the SURLY looks like a weld. The OP is using a braze.
It would be easy enough to insert a bolt and pull on it test it. I'm guessing a person could go full 200lb of body weight on the SURLY welded part and just hang out for a good long time.
A possible improvement to the OP's hack would be a tall nut to get more brazed length. Maybe bend the spoke around the nut a bit. Maybe put a flat on the spoke to get more surface area.
Found this trying to get a best guess on brazed joint shear strength: https://lucasmilhaupt.com/EN/Brazing...ndamentals.htm
see table 1 here: https://app.aws.org/wj/supplement/WJ_1975_08_s276.pdf
... next question: fatigue cycles associated with braking (which would lead to breaking....)
i should really get back to work....
anyway, I'll vote HACK (not a bodge.....)
cheers.
mrv is offline
Likes For mrv:
Old 11-24-20, 11:33 AM
SJX426
SJX426's Avatar
Quoted: 863 Post(s)
@oneclick - I implied a picture with my request.
Such as:
075_PaTrek on Flickr
SJX426 is offline
Old 11-24-20, 11:34 AM
Cynikal
Team Beer
Cynikal's Avatar
Bikes: Too Many
Quoted: 55 Post(s)
Liked 37 Times in 31 Posts
I've made several of these with spokes and cable stop braze-ons. They are perfectly strong. To the OP, nice thinking on using a brass nut.
Cynikal is offline
Likes For Cynikal:
Old 11-24-20, 02:25 PM
oneclick
Quoted: 235 Post(s)
a) yes
b) yes
c) no, I already file a groove into the nut, and I check for full-fillets (see pic 1 & 3, below).
Mk II:
oneclick is offline
Likes For oneclick:
Old 11-24-20, 02:37 PM
SJX426
SJX426's Avatar
Quoted: 863 Post(s)
Good work!
SJX426 is offline
Old 11-25-20, 06:02 AM
bwilli88
bwilli88's Avatar
Quoted: 626 Post(s)
Liked 278 Times in 183 Posts
I would take 2 or 3
bwilli88 is offline
Old 11-25-20, 07:35 AM
oneclick
Quoted: 235 Post(s)
Originally Posted by bwilli88 View Post
I would take 2 or 3
How about 3 of Mk III (pictured below) for $30 and I'll pay postage. You only get the hanger, you'll have to supply your own adjuster.
This one has the plain nut, but it has two holes cross-drilled into the edges and the spoke is bent 90 degrees and silver-soldered into the holes. I think this is (so far) the best solution, it's lighter than Mk II, the thread engagement for the adjuster is longer. It's a 2mm spoke, if you have a seat-lug with a show-off thin kerf it may not fit; I can make one with a thinner spoke if that's the case.
Just to be clear, this is *real* silver solder, the same as used in jewellery, not that "silver-bearing" stuff sold in hardware stores. It melts at medium-red heat and has a bulk UTS of around 50 KSI, the hardware stuff you can do with a soldering iron and is more like 10 KSI. It's not coming apart.
oneclick is offline
Old 11-25-20, 08:10 AM
rhm
multimodal commuter
rhm's Avatar
Quoted: 1767 Post(s)
Liked 254 Times in 173 Posts
I made something similar for my Holdsworth Gugifacazione, but instead of a nut soldered to the spoke, i have a piece of aluminum. The ends of the spoke go all the way through the aluminum piece and are then bent to a J shape, the end of which goes back into a second hole in the aluminum. Ive used this for a few years, no problems.
rhm is offline
Old 11-27-20, 01:20 PM
oneclick
Quoted: 235 Post(s)
Mk IV prototype...
This was too much trouble to make the way it is. If I do anymore like this it'll probably just have a separate ring, not be formed from one piece:
oneclick is offline
Likes For oneclick:
Old 11-28-20, 01:52 AM
squarenoise
Quoted: 42 Post(s)
Now THIS is a great upgrade!! Such a smart/elegant solution to help alight the cable housing and relieve that pressure right at the adjuster.
Old 11-28-20, 05:50 AM
oneclick
Quoted: 235 Post(s)
That's a great no-heat solution.
But maybe something like this would keep that cable-outer from rubbing:
oneclick is offline
Old 11-28-20, 08:01 AM
mountaindave
tantum vehi
mountaindave's Avatar
Quoted: 824 Post(s)
Liked 175 Times in 124 Posts
There’s no end to the creativity found in this forum - kudos!
mountaindave is offline
Old 11-28-20, 12:29 PM
tiger1964
tiger1964's Avatar
Quoted: 330 Post(s)
The expensive part might be the custom wrench for that locknut. I don't even think an ignition wrench (remember those?) would fit. OTOH, I could be proven wrong...
Or mount the locknut underneath?
Old 11-28-20, 01:04 PM
oneclick
Quoted: 235 Post(s)
It's no trouble really, you can get at the outermost flats easily with pretty much any spanner, and you just turn your adjuster the max 30 degrees either way to get it lockable.
I do have a nice little channel-lock-type set of pliers, the jaws are about 3/32" thick and about 3/4" long, it works no matter where the adjuster is.
oneclick is offline
Old 11-28-20, 01:08 PM
cudak888
www.theheadbadge.com
cudak888's Avatar
Quoted: 1211 Post(s)
Liked 1,224 Times in 746 Posts
Maybe bend the spoke pear-shaped around the adjuster? Might be wise to braze in a curved reinforcement to prevent it from straightening out.
cudak888 is offline
Old 11-28-20, 07:16 PM
dddd
Ride, Wrench, Swap, Race
dddd's Avatar
Quoted: 1000 Post(s)
Liked 406 Times in 298 Posts
Old cable housing adjusters had mere knurling on their (usually round) locknut, so didn't rely on anything more than finger-tightening.
I find that they tend never to loosen on their own!
dddd is offline
Old 11-30-20, 09:58 AM
oneclick
Quoted: 235 Post(s)
5mm/wingnut version
I had to get more brass nuts to make more of these things. I knew that the flat nuts I had would not work for a 5mm adjuster; either the existing hole was too big or the nut outside was too small. Then I saw my local hardware store had 8-32 brass wingnuts:
The nut costs more but that's not a big factor, it's just as easy to make. I got some 10-24 wingnuts and will make a few 6mm versions like this.
oneclick is offline
