Denial of stats due to "contributing" factors........
I'm cross-chained
Quoted: 4226 Post(s)
Liked 3,200 Times
CDC website today with stats from 1/21/2020 until 11/25/2020. 12,498,734 total cases. 259,005 deaths.
Therefore 2% of those who get it die., the majority of whom are over 65, and most of the deaths are in facilities which are easily isolated.
Put another way:
330,000,000 people in the US.
Therefore 12,498,734/330,000,000 = 3.7 % (0.0378) of US population has tested positive for it.
259,005/330,000,000 = 7 ten thousandths % (0.000784) of the US population has died from it.
So, for 2% of the 4%, most of whom are already in facilities, we are shutting down the economy, increasing significant mental health problems and trampling civil rights. Yeah, sounds logical to me...
Put another way:
So, basically you don't get what we can expect when the number of cases continue to grow exponentially, right? That mortality rate is likely to shoot up when that share of the population getting the virus gets a lot higher than 4%. Also, the mortality rates for car accidents, heart attacks, infected hang nails or whatever when no one can reliably call on emergent medical care.
Your use of statistics is completely illiterate.
Likes For livedarklions:
Youngman Grand
Quoted: 1558 Post(s)
Liked 637 Times
Maybe if people grew a pair and started caring about others, we'd get through this a little easier.
no stats or sarcasm either.
Likes For clubman:
Quoted: 12851 Post(s)
Liked 1,643 Times
https://www.cdc.gov/nchs/nvss/vsrr/c...htm#PlaceDeath
On this link, updated as of 11/25/2020 the CDC lists 240,213 deaths. (So much for accurate statistics).
213,919 took place in a hospital, Nursing home or hospice facility.
So, 89% of deaths took place in controlled environments.
16,000 deaths outside of facilities, roughly that caused annually by automobile accidents. Yeah, seems like a good reason to shut down the other 98% of the country....
But the average years lost for nursing home patients may be < 1 year, and not necessarily their best year of their lives.
That leaves about 2/3 of the deaths from community members. It doesn't matter if they die at in the hospital or at home. They went to to the hospital because of COVID.
Yes, many of those may have had other risk factors. But, they might have been able to live for years without COVID.
Risk is probably closer to 1%, with higher numbers due to individuals who aren't tested.
Still, if half the country was to get COVID, it could be millions of deaths, and tens of millions of hospital admissions. With our medical system largely collapsing (increasing the mortality rate).
Likes For CliffordK:
I'm cross-chained
Liked 3,200 Times
The article didn't list corresponding deaths in those areas, just higher cases. Doesn't list the demograhics either. Just a political hcwmtlbt piece.
People are allowed to take part in high risk behaviors. Heck, riding a bike on the road is a higher risk behavior.
As the CDC data shows, higher case counts does not necessarily produce a corresponding increase in deaths of that group.
But thanks for showing me my original post was correct.
Peace.
Peace.
The number of new cases has just started a dramatic rise, now exceeding a million reported cases per week nationwide, and we know that the lack of available testing is leading to a gross understatement of the actual number of cases. There's a lag time between the trends of new cases and hospitalization, and an even longer one for deaths. We're now just seeing the beginning of the take-off in hospitalizations nationwide, and the number of deaths per day has just started climbing. It had been stable at about 1000 per day, but now is more like 1500-2000 deaths per day, and that's by all reasonable calculations just the leading edge of a dramatic increase over the next several weeks to months.
If you actually want to understand what's going on, stop trying to cherry-pick factoids to make it sound like inaction is a reasonable strategy and look at the trend data that show inaction is going to kill a lot more people from COVID than we've seen so far. It's also already overwhelming hospitals and emergency care, so we're going to see all sorts of mortality increases for conditions otherwise unrelated to COVID.
So first you tried to get this thread shut down and now you're using it to deny the obvious. Unfortunately for you, people on this thread aren't part of your echo chamber, so when you try this half-baked data-distortion, you're going to get caught.
Bikes: Novara Safari, Raleigh Team U.S.A.
Quoted: 223 Post(s)
Liked 94 Times
About 1/3 of the deaths have been in nursing homes. A sad statistic. One problem is that in the past, hospitals would routinely discharge patients into nursing homes for a step-down care level. But, that is really bad for COVID patients causing major outbreak risks.
Be watchful, stand firm in the faith, act like men, be strong. Let all that you do be done in love.
Quoted: 223 Post(s)
Liked 94 Times
Who said anything about inaction? Older people and those at risk with other co-morbidities should be very very careful and protected. And can be done relatively easily with proper precautions.
That is not reason to cause harm in other ways to the 98% of the population who is not at high risk.
Liked 1,643 Times
Nursing care patients leaving a home and returning to the same home is an issue, although if the home is fighting an outbreak, returning back may not be bad as long as isolated.
Oregon previously published a map with nursing facility outbreaks, but has buried that data.
A Roadie Forever
Quoted: 2586 Post(s)
Liked 1,050 Times
I hear ambulances day and night. Last Saturday I chatted with an ambulance crew member who was taking a break by his ambulance between calls. He was exhausted, Many times the number of calls before the pandemic.
Sentencing the weaker to death so the strong get to celebrate their freedom - OK, those who entered voluntary or involuntary (the draft) servitude to serve our country and preserve that freedom for people like you are now in the "weaker" category. Is it asking too much to suck it up and give up a little for a finite amount of time so that those veterans aren't sentenced to death similar to death by waterboard? Is letting them live out their lives to their natural end too much to ask?
Likes For 79pmooney:
FLIR Kitten to 0.05C
Quoted: 2307 Post(s)
Liked 358 Times
I didn't ask for the thread to be shut down, just moved to a more appropriate forum.
But, like they say--you cannot teach old dogs new tricks. So, I fully expect you to keep going.
Likes For Marcus_Ti:
Society Dropout
Bikes: Too many Motobecanes
Quoted: 1542 Post(s)
Liked 1,577 Times
Here is Bubba and Bubbette’s hero.
I'm cross-chained
Liked 3,200 Times
This was the approach Sweden was taking, and they were in a far better position to isolate vulnerable people than the US is. Sweden is currently giving up that strategy as it's been a miserable failure.
And you're just looking at deaths here, the morbidity from COVID has been terrible, and we'll likely be seeing those effects for years.
Again, you just ignore what happens to the medical system when you don't contain the spread of this thing.
Oh, and if you actually knew what the co-morbidities are, you'd know there's a hell of a lot more than 2% of the population in the high risk category. Seriously, just stop with the numbers, you're just embarrassing yourself.
Liked 358 Times
Quoted: 223 Post(s)
Liked 94 Times
It would be easy enough to create a model of clean homes and dirty homes. Ok, so don't use those terms, but take some nursing facilities for COVID recovery care (and in the future communicable disease recovery). And, other facilities and separate staff for those without the disease. Although, multiple-exposures is a potential issue with lumping people with different diseases together.
Quoted: 223 Post(s)
Liked 94 Times
This was a interesting article put out than taken down by John Hopkins.
https://web.archive.org/web/20201126...ue-to-covid-19
Liked 358 Times
Well folks,
I haven't posted in a bit, but here is just one fact -(oid) but true "locally". The federal government pays more to hospitals when the deaths are covid related. With that in mind, most of our deaths in hospital have been "covid" with other complications. What is another 2,3 or 10k in dollars gained for the hospital if the death suddenly become a covid mortality? As much as I hate it, the healthcare industry has become as much if not more greedy than the insurance industry.
I took a blow to the head a few weeks ago and I got to go to the ER, They kept me for two days when they could have released me in three hours. Why? Because they can bill my insurance for two days of observation, before they have to release me. My bill was padded by 45 hours with nothing else benefitting me, but plenty benefitting the hospital. My take is covid deaths have become a new cash cow for the hospitals. Smiles, MH
Seen it before. Heard it before. Seen it debunked before. Could have saved yourself the typing.
I'm cross-chained
Liked 3,200 Times
I'm cross-chained
Liked 3,200 Times
Meantime,
https://www.cdc.gov/mmwr/volumes/69/wr/mm6942e2.htm
Society Dropout
Liked 1,577 Times
I found the answer
Likes For Hondo Gravel:
Quoted: 13126 Post(s)
Liked 4,450 Times
CDC website today with stats from 1/21/2020 until 11/25/2020. 12,498,734 total cases. 259,005 deaths.Therefore 2% of those who get it die., the majority of whom are over 65, and most of the deaths are in facilities which are easily isolated. Put another way:330,000,000 people in the US.Therefore 12,498,734/330,000,000 = 3.7 % (0.0378) of US population has tested positive for it.259,005/330,000,000 = 7 ten thousandths % (0.000784) of the US population has died from it. So, for 2% of the 4%, most of whom are already in facilities, we are shutting down the economy, increasing significant mental health problems and trampling civil rights. Yeah, sounds logical to me...
Quoted: 644 Post(s)
Liked 497 Times
Well folks,
And yeah, the extra money for covid deaths is BS, if anything, deaths are being under reported.
Liked 358 Times
Well folks,
https://www.factcheck.org/2020/04/ho...9-death-count/
And there are lots of others. Those too, have been up since April...and you're here 7 months later parroting the debunked conspiracy.
They tend to do that with head injuries, even here in Australia, where health care is free, so no incentive to keep you in hospital, and actually government pressure to churn you out ASAP. Head injuries are complicated, they could send you home after a few hours and nek minnit you're dead and suing them (well technically it'd be your estate).
RUSA #3100
People keep saying that the Federal Government (CDC) dropped the ball on this early on. Well, the CDC is an advisory agency only and cannot do anything but make a recommendation. Each States Public Health Department has the responsibility to deal with a pandemic locally. If they choose a different response from what the CDC recommends then it seems to be a stretch to put the blame at the Federal level. Essentially you now have 50 different responses to the pandemic and 50 different ways that they are tabulating the data. This is how we got to the place where a fatal motorcycle accident is listed as a Covid death because he tested positive post-mortem, and it is why you cannot trust the numbers. There are 50 different ways the data is being collected, and the standards keep changing so you cannot really even compare data from this past summer to current numbers.
I think one thing we can say with certainty is that things will get much worse before they get better!
Quoted: 3923 Post(s)
Liked 1,666 Times
I have several friends who work in health care -- doctors, nurses, EMTs, etc. -- with no particular axes to grind politically or culturally. They're independent thinkers and well informed so I pay attention when they talk about the differences between this SARS pandemic and COVID-19 cases, versus previous years of the usual flu, colds, even occasional outbreaks of meningitis.
This pandemic is worse. Much worse than anything we've seen in the US in my lifetime (I'm 63).
But it still doesn't seem real to many Americans because so many of the deaths are among the invisible people - older folks who are retired, disabled, in nursing homes, assisted living or, like my apartment complex, independent living exclusively for folks over age 55. Many of these folks are invisible because they aren't working full time, or working at all, and rarely see their own families, if they have any surviving family. When I moved here I was surprised to discover how many residents never see or hear from their families.
Even my mom, who was one of the most generous and giving people I've known, never heard from her grandkids during her final decade. Her older brother was the only family member, besides myself, she had any contact with and he died a few years before she did. I was her caregiver during her final decade and the only family member she saw at all. For awhile I reached out to my kids and other family but they never responded. She didn't have any money, and was too old and tired to be a babysitter, so they didn't have any use for her. Their loyalties were to other family who had money and things to offer.
Sounds callous but that's a common theme here. And probably common across the US. These are forgotten people and the numbers -- now approaching a quarter-million deaths -- don't register with many younger folks.
Just today I read a baffling post on social media from a women who is an ICU nurse in my area. Her 2,000 word essay could basically be summed up as "Old people shouldn't expect to live forever. This is just a super-cold. If you die, well, too bad, that's life. The rest of us need to get on with our lives, having fun and partying."
As a former health care professional working in ICU, ER, hemodialysis and with chronically ill patients awaiting transplants, I was disappointed to say the least. I wish I could claim I was shocked but I've seen too much of that this year. I rarely respond to strangers but I suggested she reconsider her career and get out of patient care that involved acute illness and injury. If I was her manager or a hospital administrator I'd have been stunned to see such public callousness in an ICU nurse and would have taken action to protect the patients first. Her attitude was an imminent threat to patients and a liability to her employer.
And those rumors about hospitals fudging the statistics to boost their profits were based on misunderstandings by laypersons about how the SARS virus works. Despite months of readily available factual information, too many people still believe it's just a "really bad cold" or "just like the flu."
Nope. The respiratory system is merely the entry point. And, consequently, the system most commonly attacked. But it's not confined to the respiratory system.
The early 2000s SARS epidemic prompted research that made connections between SARS and a range of non-respiratory illnesses, ranging from cardiovascular disease to inflammatory diseases to autoimmune disorders to neurological damage and dementia.
Unfortunately there wasn't much follow up on that early research. This pandemic is prompting renewed research. If it turns out these viruses attack more than just the respiratory system, and there may be permanent consequences even for younger people who get sick but never fully recover, then we may finally see some emphasis on effective vaccines that may improve our lives in ways we didn't expect.
Likes For canklecat:
Quoted: 350 Post(s)
Liked 201 Times
Would you go shopping?
South Dakota's governor encouraged people to go shopping the same day the state reported its highest single-day COVID-19 death total
https://www.yahoo.com/news/south-dak...153612071.html
