I need a chainring straightener
Old 11-28-20, 01:13 AM
Road Fan
Road Fan's Avatar
Quoted: 1167 Post(s)
Liked 171 Times in 149 Posts
I have a few bikes to refurbish for a friend and his wife (matching his/hers wedding gifts), and the 45+ year old steel chainrings are warped. New chainsets are not an option.
I need a Bicycle Research Chainring Straightener. Anybody have one or similar to sell? There was one on Ebay recently but I missed it.
EDIT: I've bought something that I think will do the trick - see below for the story.
Road Fan is offline
Old 11-28-20, 02:10 AM
reconnaissance
Bikes: Trek 850, Trek 510, Cannondale 300m, Specialized Rockhopper, Stumpjumper, Bianchi Virata
Quoted: 37 Post(s)
Liked 80 Times in 28 Posts
I use an adjustable wrench. Crescent wrench.
https://en.wikipedia.org/wiki/Adjustable_spanner
reconnaissance is offline
Likes For reconnaissance:
Old 11-28-20, 06:02 AM
oneclick
Quoted: 219 Post(s)
Liked 212 Times in 137 Posts
Yes.
Old big ones are the best, they've got lots of surface area, they usually have tighter jaws, and the larger thumbscrew lets you get a good firm grip.
And steel ones are usually easy - most of the ones I've dealt with bent at mounting holes where the metal is smallest in cross-section; what you do is watch the chrome surface reflection in a good light and you can see when each arm is flat. If it's a separable ring you can also grip it from inside, and tweak each branch of the arm-at-the-hole.
oneclick is offline
Old 11-28-20, 07:01 AM
ARider2
Quoted: 25 Post(s)
Liked 32 Times in 24 Posts
I have used the Park Tool rotor truing fork for straightening chainrings. It has a long slot that works well for most cases...
ARider2 is offline
Old 11-28-20, 07:55 AM
mountaindave
tantum vehi
mountaindave's Avatar
Quoted: 817 Post(s)
Liked 168 Times in 118 Posts
+1 on both of the above ideas
mountaindave is offline
Old 11-30-20, 12:05 PM
rhm
multimodal commuter
rhm's Avatar
Quoted: 1761 Post(s)
Liked 250 Times in 170 Posts
I have that tool and am willing to lend it; send me a private message and we can work out the details.
www.rhmsaddles.com.
rhm is offline
Likes For rhm:
Old 11-30-20, 01:46 PM
juvela
juvela's Avatar
Quoted: 2308 Post(s)
Liked 536 Times in 444 Posts
tip -
unless you can see visible runout right at the teeth it is best to make your adjustments down as low (close to the centre) as possible
some deformations are best resolved by cold setting the spider itself
the Bicycle Research tool is called the Lajeunesse for a mechanic at the shop whose name is Dan Lajeunesse and who created it
used to visit with him at the shop in Concord Califiornia back in the 1970's as we had purchased the same model of pickup truck and would exchange information on that
Dan is also a guitarist/guitar maker
Bicycle Research Products is a creation of Don Millberger, formerly an employee at Lawrence Livermore Laboratory
juvela is offline
Likes For juvela:
Old 12-12-20, 10:03 PM
Road Fan
Road Fan's Avatar
tip -
@rhm, Always generous, thank you so much!
@juvela, your advice matches my intuition, to make the adjustments down low. I already took a shot at that with my 14" adjustable and it's really too big to get in and bend things under good control.
Bottom line to all, I found a few of the Park tool on 'Bay, so I bought one.
As well, Juvela the tale of the history of Bicycle Research is interesting. I worked with some Livermore folks for a few years. I also had a colleague at Ford who was a physicist working as a mechanical engineer, and for the price of a few Mexican lunches, he made me a headset cup press. I made up a set of dimensions for a Campy Strada headset and the head tube on my Masi, and he designed cups and turned them on his lathe. I've never had problems with headsets on steel frames since. He also made me a ram for cup extraction, but its pretty hard to get it in place, so I'm still down to a big punch and a 1 lb hammer. It works quite well!
Any case I'd say my chainring need is settled.
Road Fan is offline
