Bianchi Serial Number Identification
Old 05-05-09, 05:31 PM
  #51
Bianchigirll
Bianchi Goddess
Bianchigirll's Avatar
Quoted: 1906 Post(s)
Liked 692 Times in 435 Posts
Europa
Hello does your Europa look like this, but purple? it could be a 1993. Bianchi calls that color PD Blue
the Supetset 2 sticker refers to the fact that all Bianchis are built with a "super set design" heavier downtube and chainstays then the rest of the tubing set and on the "2" means that the down tube is actually ovalized as it nears the bottom bracket to create an even stiffer frame.
Bianchigirll is offline
Old 05-06-09, 08:29 AM
  #52
Fadoli
Yes, it's the very same! Thanks a lot for all the precisions!
Fadoli is offline
Old 05-06-09, 12:48 PM
  #53
Bianchigirll
Bianchi Goddess
Hello Fadoli your welcome glad I could help. they were nice bikes I sold a few of them to some very happy customers.
Old 07-14-09, 09:33 PM
  #54
Guccini
geezer
Bikes: 1 Bianchi Sport
my Sport 3 spd has ser number 312791 on the seat post,dark candy red/ black forks gold pin stripes late 50's early 60's my guess
Guccini is offline
Old 07-22-09, 09:50 AM
  #55
Samwiches
breasts
Samwiches's Avatar
I'm guessing mine is a Strada LX
KS5876459
"BIANCHI" stamped dropouts.
Rims, hubs: brown/bronze 32h 700c Araya w/ eyelets, Shimano
RD, cranks: Shimano Sport LX (also the missing FD)
Brakes, levers and shifters: Exage/Shimano SLR
Headset: stamped Specialized (1")
Bars: Sakae CT (or GT)
Stem: Stamped "custom" on the front and "5R" on the neck.
<-- Love this
Samwiches is offline
Old 07-29-09, 07:02 PM
  #56
T-Mar
Quoted: 3617 Post(s)
Liked 1,002 Times in 759 Posts
Originally Posted by Speare View Post
just noticed that on the steer tube it says:
AKISU 89
I would take it that means it was made in Japan in 1989?
Not sure where it was made, other than it's not Italian, but both the serial number and steerer stamps indicate a 1989.
T-Mar is offline
Old 07-29-09, 07:15 PM
  #57
T-Mar
KS5876459
The moment I saw the serial number I thought it was a 1985 Japanese model. But then I saw the Unicrown fork and noticed the Exage & Sport LX components and 7 cogs. That all points to something a bit later or something put through a blender.
T-Mar is offline
Old 07-29-09, 10:31 PM
  #58
mtbbikemike
Bikes: 1970 Peugeot U0-8, 1995 KHS Montana Comp Hardtail
What's up with the serial numbers? I have what I believe to be a '93. It is a 59cm Reparto Corse. Serial # 59C392. Columbus EL over size with internal cable routing, ovalized downtube at the bottom bracket, drop outs are stamped "Bianchi". I am looking forward to building it up, but I am short on the cash to do so. I am not sure what the componets were originally, but it does have a Shimano bottom bracket installed.
File Type: jpg
File Type: jpg
mtbbikemike is offline
Old 07-30-09, 05:59 AM
  #59
T-Mar
I would agree with 1993. Bianchi have several serial number formats because they were such a large brand and used so many different frame manufacturers. First there was Reparto Course, then the main factory for the mid-range and entry level models and then numerous Japan and Taiwanese manufacturers after Italian manufacturing got too expensive for the entry and mid-range models.
As for components, there was a 1993 EL model with C-Record.
T-Mar is offline
Old 07-31-09, 06:21 AM
  #60
T-Mar
Thanks T-Mar, would you have any idea on the model?
Assuming you're accurate with the calipers and the slot isn't pinched, giving an undersize reading, it's something less than mid-range. The mid-range models with Cromor or SL main frames typically use 27.2mm posts. An Aelle frame would use a 26.4mm post so that's a possibility but given it's an Asian frame, Columbus tubes would be unlikely. Most likely, it's something along the lines of a Sport SX with a Tange 1000 main frame, which has a seat tube inner diameter of 26.6mm and would use a 26.4mm post. I don't think pictures would help in this case, given that it has been stripped of decals and paint.
T-Mar is offline
Old 08-03-09, 07:04 AM
  #61
Bianchigirll
Bianchi Goddess
Hello Tmar do you have a pic of that ,93 EL OS with C-Rec? I had thought Campagnolo moved on to Ergo 8spd by then but I could be wrong
Old 08-03-09, 07:18 PM
  #62
sciencedoc
Need help with old Bianchi
I have just bought Bianchi tour. It is medium blue with forks that are half chrome. Ser is 1s18970
I have looked around to find out more. It says made in Japan but I don't know what year. Can anyone offer assistance. I want to restore to period.
thanks,
sciencedoc is offline
Old 08-04-09, 12:58 AM
  #63
Winston.Agust
Got it at the dump. cs599454. Red with gold lettering decals.
Winston.Agust is offline
Old 08-10-09, 01:38 PM
  #64
mindlesswacko
I ride bikes...
mindlesswacko's Avatar
Bikes: Trek road, Surly cyclocross, Fetish mountain
Anyone know the year on this one:
Bianchi Veloce ser# A500079.
Full Campy Veloce group, Dedacciai steel frame/fork, red w/white.
thanks!
mindlesswacko is offline
Old 08-17-09, 07:28 PM
  #65
Bianchigirll
Bianchi Goddess
Hello do you havea pic? a red Veloce is around a '96-98 it depends on the shade of red, decal style and finer differences in the Veloce components.
Old 09-17-09, 10:37 AM
  #66
rsharp
Anything with 2 wheels
Yet another ol Bianchi
I found this forum thru a google search on my new/old bike. I recently recieved a abandoned Bianchi which I am restoring. After reading the stuff here I think it may be pretty much original, if only because all the componennts come up as being roughly the same vintage. The bike sat for at least 5 years, maybe a lot longer.
I THINK it may be a mid 90s but the fully lugged frame makes me think it is early 90s. Regardless, it is in good shape so I am going to rebuild it as is and put it on the road for a while before making any changes.
The vitals are:
Bianchi Axis sn ES059524
Black frame with blue decals
Fully lugged “Superset II” & “Tange Cro Mo” frame with rack mount points on seat stays and integral pump location behind head tube.
Head tube has a bird crest decal and small “made in Japan” sticker at the top
“Cross Terra” sticker on left chain stay
Forks look more like MTB style, has Bianchi stickers that say “Unicrown” & “Tange Cro Mo”. Fork has front fender lugs at the bottom.
Sakae “X-Hybrid” handlebars
Suntour GPX brake levers
Crank Sakae SXC Roundtech, 3-gear
Pedals Sakae
Rear cluster Suntour 7-gear
Rear derailleur Suntour XCD
Front derailleur Suntour top pull
Brakes Dia Comp 986
Wheels have big sticker that says Araya 700c VX-400, Suntour hubs
I would be interested in nailing down the exact year, and if these are indeed all the original bits and pieces I will probobly just try to keep it in good condition, or at least keep the parts I remove. Since the bike was free I am not really inclined to sell it, even if it was worth a bit, but I do want to maintin its value. Doing a full disassemble and clean now, waiting for my tires to come in the mail.
rsharp is offline
Old 09-17-09, 01:24 PM
  #67
T-Mar
Baesed on your description, it should be a 1990.
T-Mar is offline
Old 09-17-09, 01:51 PM
  #68
Bianchigirll
Bianchi Goddess
like this but black? sounds like an all orginal '90 to me . nice bike and an even better price
Old 09-18-09, 06:43 AM
  #69
rsharp
Yup, thats it.
The tires came off in pieces and I am replacing with some Kendas for now. Also, the tape was shot and I bought red but otherwise I think it may have been bone stock. Most everything looks to be reusable except for corrosion on the wheel quick release levers / nuts. I have some other ones for now but will keep my eyes open for some good orig Suntours. Doing as much as possible on a $0 budget. The good thinn about that is you tend to recondition and resue as opposed to replacing OEM bits.
I can not tell from the pic, but it looks like the saddle is an Avocet. The one on there now is an Avocet Gelflex C20 seat. Was that stock too?
So it is a 1990, good to know. Thanks for the help. I will post some pics when I am done.
Thanks
RSharp
rsharp is offline
Old 09-18-09, 07:17 AM
  #70
maley
Hi all, long time lurker first time poster
I have a 1985 with the serial A343 (and a separate
number 4) stamped on the bb shell. Its a 57
The frame isn't named as such but is one model down
from the centenario, hope this helps anybody
trying to date a similar frame
maley is offline
Old 10-06-09, 10:49 AM
  #71
treebound
aka: Mike J.
treebound's Avatar
Bikes: 1995 Trek 520 is the current primary bike.
Quoted: 98 Post(s)
Liked 20 Times in 13 Posts
A co-worker has a Bianchi roadbike, doesn't know what model the bike is. He got it as a frameset and repainted it several/many years ago and put on a Bianchi decal set he got from somewhere. Rear spacing is 126mm and the frame is about 62cm ctc.
There is a number on the bottom bracket: CS26952.
Any idea what year it might be from? Also, what specific details should I look at to help identify it further?
And, sorry, no pics yet. I'll post some if/when I can.
Thanks for any input. He currently has it built up with a mix of parts, 6 speed on back, triple on front, Campy hubs, tubular rims, SunTour shifter arms on the downtube, Shimano derailleurs, 3TTT stem, whatever he could find at the time to make it ridable.
treebound is offline
Old 10-06-09, 11:12 AM
  #72
Bianchigirll
Bianchi Goddess
check for the type of dropouts, Campi, GPM, Suntour, also (if orginal) the fork ends. is there any engraving on the frok crown or seat stay caps? since it was repainted and built with 'spare' parts they are not much help. OH is the BB english or Italian?
Old 10-06-09, 11:33 AM
  #73
T-Mar
Originally Posted by treebound View Post
A co-worker has a Bianchi roadbike....
This one is a Japanese, 1982 model. Non-OEM, eclectic component mix makes model identification tenous without pics. What is seat post diameter? Integral derailleur hanger on rear dropout? Any fittings brazed onto the frame, like shifter bosses, bottle bosses, top tube cable tunnels (as opposed to stops?
T-Mar is offline
Old 10-06-09, 11:45 AM
  #74
treebound
aka: Mike J.
treebound's Avatar
Quoted: 98 Post(s)
It has a Campy headset which he believes is original. The BB is one he bought and doesn't recall any issues finding one to fit. Has Bianchi or a B in various places etched/stamped/pantographed into the metal. Has a rear hanger. Not sure what make the dropouts are but the rear are forged. Seatpost was set in deep with no saddle on the bike, eyeball guess would be close to the diameter on my Centurian or Colnago, bigger than the older Schwinns at least, and I suspect it's a fluted seatpost. There was at least one set of water bottle brazeons. I don't recall what the cable routing or stops were like.
I'll have to wait for the rest of the answers until I see it again, possibly Friday.
Old 10-07-09, 06:45 PM
  #75
sekaijin
sekaijin's Avatar
Bikes: 2000 Litespeed Classic, 1984 Schwinn LeTour, 1998 Gary Fisher Marlin, 1969 Hercules, 1977 Sekai 5000 Superlite, 1993 Koga-Myata TerraLiner, 2013 Trek Farley.
Here is a data point on a Bianchi I am in the process of acquiring:
SN: A404761 (the 0 is hard to read - could be a D, or maybe an 8 or 9)
- no tubing sticker
- oversized/ovalized downtube
- I'm told it's a 1990s bike
- silver metallic paint
Pics soon - any guesses?
sekaijin is offline
