Bike shopping advice for short female
Could I get some help figuring out what bike options are out there for my needs, and how to find them? My online searches have me frustrated and confused because I don't speak "bike language"--they've have changed so much since I last owned a 10-speed, 20 years ago. I'm a 50+ female, 5 feet tall, with short legs. I want a bike for casual city and park rides on mostly-paved paths, both flat and with medium/low inclines. I need one that:
1) fits my height/leg length;
2) has at least a few gears;
3) has at AT LEAST ONE EASILY-REMOVABLE WHEEL, so I can haul and store it inside my tiny Fiat 500 hatchback on weekend trips. This has been the hardest feature to search for. I was hoping to find something more "commuter" or "hybrid" than "mountain bike", but I can't find the removable wheel spec on any bikes for short women, unless I go "mountain". Is mountain my only option? Using the term "quick release" in my searches hasn't been very helpful.
-- If I see some commuter/hybrid bikes that fit my legs and have some gears, how can I tell if one/both wheels are easy to remove? Many times, the specs don't mention that feature. Is that because ALL bikes have this now? Or, are there terms I should look for other than "quick release"?
-- Should I just buy a bike that fits my legs and has a few gears, then plan to have the wheel-type changed? If yes, what spec terms should I look for to make sure it's possible to have it changed to quick-release? Any spec terms I stay away from? (I would be paying someone else to change this for me).
I will truly appreciate any constructive shopping recommendations, search-term tips, or "reality checks", so I can stop looking in circles. Thank you!
Quoted: 5224 Post(s)
Liked 3,581 Times
fwiw - Wifey is 5 feet even & likes her 15” Trek Stagger
EDIT: you sound like a candidate for a folding bike. some gave small wheels & frames & some are full size folding frames w/ full size wheels
Quoted: 18411 Post(s)
Liked 15,531 Times
Surly Long Haul Trucker. My ex is your height. She rides the smallest size they make. Quick release wheels. 30 speeds, with low gears meant for touring with full loads.
Expired Member
Quoted: 3669 Post(s)
Liked 5,420 Times
Most bikes above Walmart spec will have quick release wheels. Disc brake bikes have a different mechanism known as thru axle, also easily removable.
Thanks for the recommendation! It looks like the center bar is high for a short-legged person, but I'll keep this one in mind and see if I can find one local to try in person.
Liked 15,531 Times
Yes. Tough bike, too. Top tube slopes a bit for greater clearance. Good luck with your search.
Likes For indyfabz:
Here are your variables for ease of front wheel removal -
Are the brakes cantilever/v-brake or disk brakes?
Is the axle a thru-axle or a quick release?
Go to a bike shop. Have them show you examples of each, and how to remove and put the front wheel back on. Then try it yourself. You'll probably find that a disk brake combined with a thru-axle is a bit more difficult to install, but it's not hard. A quick release with cantilever/v-brakes is super easy to install.
Also, if you end up getting a bike with hydraulic disk brakes, be sure you know how to put the block between the brake pads when transporting your bike in that tiny Fiat. You don't want to accidentally press a hydraulic brake when the wheel isn't installed.
Quoted: 608 Post(s)
Liked 352 Times
For the back of a Fiat 500, folder as already suggested, is certainly the way to go. You could spend $300 to thousands depending on what your needs are. Name brands such as Tern, Dahon and Brompton are worthy contenders. For more inexpensive, have a look at Citizen or Origami folders. Both owners of these companies post in the folder forum.
Good luck with your search. If asking for further advice kindly post the approximate amount you want or think you want to spend it helps other forum members formulate their responses.
Happy banana slug
Quoted: 1533 Post(s)
Liked 1,528 Times
Great Ghu, it's NDS! Horror!
Likes For Korina:
My wife is your height. We've talked about getting her into biking since I'm constantly on my bike all the time. She is a casual rider around the neighborhood nothing pricey or fancy.
Quoted: 16 Post(s)
Liked 17 Times
Yesterday, I ran across the Fuji bikes page. They have quite the selection of women's bikes. Maybe browse those. I'm a bit bias, though. I have had my Fuji for 42 years. They seem to fit all your requirements, and come at several price points and woman friendly sizes. They all have quick release.
https://www.fujibikes.com/usa/bikes/pavement/womens
My preference would be the Absolute.
https://www.fujibikes.com/usa/bikes/...ns/absolute-st
Quoted: 3450 Post(s)
Liked 420 Times
I'm 5'1" with short legs as well and when it comes to off the shelf bikes for our size the best choice is 24"wheeled juvenile bikes.
See these, https://www.giant-bicycles.com/us/bi...ears--24-inch- I ride an ARX-24 myself although the Escape JR 24 looks like it would be right for you.
