seat post clamp help
Bikes: Wife says I have too many :-)
Quoted: 327 Post(s)
Liked 250 Times
I have an old hard tail mountain bike with a 27.2mm dia seatpost. I want to add another clamp above the seatpost clamp for extra clamping to help keep it from sliding down. All I want is a clamp with 27.2mm inside diameter. Nothing else. I find a ton of them with I.D. for clamping around the seat tube, for example 31.8mm ID. Doesn't seem like it would be that hard to find a clamp with 27.2MM I.D. but I can't find one.
Bikes: S-Works Stumpjumper HT Disc, Fuji Absolute, Kona Jake the Snake, '85 Cannondale SR900
Quoted: 219 Post(s)
Liked 217 Times
Sorry if this is a weird question, but -
do you want that extra clamp-above-the-clamp there to REALLY prevent the seatpost from sliding down, [like, because the lower, "real" clamp at the top of the seat tube is not keeping the post up] ...
or just for a bit of extra convenience [say, to prevent the post from sliding down annoyingly when you loosen the main clamp, or when you're putting the post/seat back in] ?
Cause if it's the former, I'd just figure out why the post/original clamp are not keeping things in place, and if the latter, I'd use the mounting ring for a light or reflector to do that.
Quoted: 327 Post(s)
Liked 250 Times
I think I have found an easy solution. I didn't know there were twin seat psot clamps avaiabe. I found one with the bottom half that clamps on to 31.8 and the top half clamps to 27.2. Problem solved.
Quoted: 645 Post(s)
Liked 797 Times
Quoted: 327 Post(s)
Liked 250 Times
as you’ve discovered, seatpost clamps are sized to accommodate the seat tube in addition to the seatpost. Maybe look for a clamp designed for a 25.4mm seatpost. Of course, if you simply want to prevent the seatpost from slipping down, and your current clamp is preventing rotation, might a simple (albeit ugly) hose clamp around the seatpost do the job?
Quoted: 2026 Post(s)
Liked 1,096 Times
I used a hose clamp for two years until my bike needed a drive train replacement. Lbs changed it out for a regular seat post clamp, without even asking me!. The nerve!
