#6302
Quoted: 4559 Post(s)
Liked 2,802 Times
I use Boeshield T9. Its not messy but your chain will give you black tattoo if you get against the big ring. I clean the chain with wd-40 or mineral spirits depending on how dirty it is then put a drop on every link then spin it a few times. I let it sit a while or even till the next day then wipe the residue off usually with some paper towels. I go anywhere from 100-200 miles depending on how lazy I am. My chains usually last about 3000 miles and I have never had one squeak or maybe I am just too old and deaf to hear it.
Boeshield also works to restore some smoothness to old cables/housings if we don't have time or money to completely replace with new cables and housings. I've postponed replacing those for a few months by using T-9 to slick up the oxidized cables. It wicks quickly down the cable. Less messy and smelly than WD-40.
#6303
'89 STB. Tricolor 7 speed gripshift.
Over cast lighting. The second generation 8 speed tri color shifts so smoothly matched with the 7 speed gripshift. To the point you're not sure it shifted. Aero seatpost, aero bars and tricolor crankset, brakeset, and derailleurs.
This is how I ride it. It's 52cm instead of my regular 54cm. Although it's about as dialed in as I could want, I'm still gonna make it 9 speed dura ace...eventually. It's my Friday rider.
#6306
Quoted: 3241 Post(s)
Liked 2,512 Times
For lubes/grease, I use auto parts store house brands. Silicone spray inside the frame instead of Frame Saver. High temp bearing grease for the headset and BB. For cleaning parts, I mix brake cleaner, a penetrant, dish soap and something like Simply Green. I dip the part in and go at it with a toothbrush. One of these days I will buy an ultrasonic cleaner. For rust spots on paint, I use vinegar, and a rinse. Then I apply rust stopping primer with a Q-tip. After that, I apply a clear protector like fingernail polish with another Q-tip.
#6307
Liked 2,512 Times
One thing I don't use anymore is ordinary electrical tape to tape cables to the handlebars or finish off bar wrap. It could be the humidity here, but the adhesive on the back will get liquidy/gooey and make a mess.
#6308
The chain man, what about the chain?
#6309
My riding buddy and I went on a 18 mile ride today. He uses a Garmin and asked him to calculate mileage because we were going on a different route. When we finally got to the last half mile then turnaround he started using some choice words directed to me because we were on our hilly course. I told him it was for his own good, hehe.
I was riding the trek and he in his Ironman. The 56cm trek rode well and felt much like my Ironman. So no real complaints about it...well other than it'd not an Ironman. I thought the lighter weight would help on the hills but the first hill is steep but short probably a 1/4 mile. I don't know the grade but itll get you to 40mph on the down side before you get to the bottom, if that tells you anything. I stayed within a bike length as we headed up but I paid the price as I thought my heart was gonna explode. I was in the next easiest gear. I actually never used the easiest gear the 42x28. I recovered well enough as I lead the last 1/2 mile hill before direct turnaround. Actually at that point, we traded bikes. I adjusted the height of his saddle, easy enough as I had measured before we headed out and the trek has a quick release seat bolt. Unfortunately I didn't change saddle height for his bike I was riding. Weirdly were the same height but his saddle is set way lower than mine but it doesn't look like his legs are shorter than mine. I finally said man I wish I had brought an allen wrench, he said there's one in the saddle bag. As soon as I pulled them out I recognized they were what I use, he said you gave those to me. It was a 4,5,6. I put the same things in all my saddle bags. 3 Allen wrenches, a new spare tube, tire levers, 35mm canister of quarters, and 4 benadryl pills. Then I wrap a toestrap around-the outside of the seatbag. So we pulled over and I adjusted and we were on our way.
I can tell you but you probably already know, the trek 5900 handled so very similar to the Ironman however it's lighter. It is quick handling like the '88s and '89s too.
Afterwards I said dude the tires on your ironman are hard! He said I was gonna say the same thing about the trek.
Afterwards I went on a lone ride aboard my exceptionally smooth riding and shifting '89 Ironman. Later Irongents.
#6310
Liked 2,512 Times
#6311
I have my phone holder wrapped around the stem. And then the usual elbow rest, inner tube bar wrap, and gripshift.
The hoods are switched/reversed, the left hood is on the right and vice versa. I got em like that on my '88 master, however I've left them for fear if I changed them back I would tear them.
#6312
Liked 2,512 Times
#6313
aka: Dr. Cannondale
Quoted: 2152 Post(s)
Liked 3,402 Times
Liquid Wrench chain lube works great. I just hate the smell.
#6314
Liked 2,512 Times
#6315
Liked 2,802 Times
#6317
Liked 2,512 Times
#6318
Bikes: 86' Centurion Ironman
Quoted: 628 Post(s)
Liked 316 Times
OK , I messed that up . It's not crystal blue , it's Summer time blues . don't be afraid to slap me around a little , mswesti does it all the time .
#6321
New (to me) 87 Master
The closest I've owned to a time capsule bike. Paint is near flawless. I have only noticed one part that is not original. Can you spot it?
I.C.
I.C.
#6322
Quoted: 1947 Post(s)
Liked 2,010 Times
Rear tire and bar tape. If you'll be I. Cambria next week, I can bring you a tire to match your front.
Jeff
Jeff
#6323
I was thinking tire- didn't know about the tape.
Next week I will be working like a dog. Thanks anyway. Hope you all have a good time.
edit: I just rememberd I have a NIB set of yellow Turbo Pros in 23mm. They wouldn't look good on any of my other bikes.
I.C.
I.C.
#6324
Nice '87 Master. How's the ride?
#6325
Just picked up today afternoon. Pic after taking it off the car.
