Old 05-06-20, 03:03 PM
  #8601
seypat
Quoted: 3241 Post(s)
Liked 2,512 Times in 1,510 Posts
So you build those wheels and now you need to get them tight and true. Same as wheel building, find yourself a good reference site and get to it. If you think you need a dishing tool, here is a cheap DIY that works. The local hardware store will have everything you need. Buy the strip of metal and the bolt/washers/nuts. Drill a hole in the center and install the bolt/washers/nuts. Bend the metal strip and check your angles/sides. That's it, now you have a dishing tool.
seypat is offline
Old 05-06-20, 03:19 PM
  #8602
seypat
Other than trial and error, the one truing tip I can give is this: Once you've snugged up the wheel some and are ready for the truing, put the wheel in the dropouts. Take the brake caliper off and mount a measuring device. Now slowly spin the wheel. There will be some point on the rim that will be true. Mark that point on the inside of the rim. True the rest of the rim to that point. Never let that point get out of true. If you have an iPhone, there is a spoke tension app for iPhones.
seypat is offline
Old 05-08-20, 12:04 AM
  #8603
__Dom__
Quoted: 12 Post(s)
Liked 10 Times in 5 Posts
Well look what I found...
Everything original.. even tires which are still good! Pretty sure it was never ridden much. $175! Even the tubes were still good. Aired it up and lubed the chain and turned this baby loose. Lightest bike I have ever felt. Like driving a vintage ferrari.
__Dom__ is offline
Old 05-08-20, 04:37 AM
  #8604
seypat
Dang, that's practically NOS!
seypat is offline
Old 05-08-20, 06:44 AM
  #8605
RobbieTunes
Quoted: 378 Post(s)
Liked 1,409 Times in 909 Posts
Um, I found a fork in a box.....
It appears to be ready for shipping.
Alloy, polished, from an Ironman Carbon.
I cannot remember to whom it goes, or where.
PM me if you're the huckleberry.
I'll check my way too long list of PMs and get it shipped.
RobbieTunes is offline
Old 05-08-20, 11:23 AM
  #8606
madpogue
Quoted: 2363 Post(s)
Liked 1,749 Times in 1,191 Posts
+1; check out the rim brake tracks.
madpogue is offline
Old 05-08-20, 11:39 AM
  #8607
Classtime
Classtime's Avatar
Quoted: 1949 Post(s)
Liked 2,010 Times in 1,109 Posts
Rims -- Schrims
Look at those hoods!
Classtime is offline
Old 05-08-20, 12:06 PM
  #8608
canklecat
canklecat's Avatar
Quoted: 4559 Post(s)
Liked 2,802 Times in 1,800 Posts
Sweet! No apparent wear on the cranks, original snap in covers, dork disc, etc. That bike was ridden little and carefully stored. Looks like the original tires too -- skinny-minnie Panaracer Tecnova 700x20. I'd ride those maybe once on smooth pavement just for grins, then put 'em away as sorta-collectibles.
Try a set of Continental Ultra Sport II tires in 700x23. Best affordable tires I've tried. I'm a cheapskate but still want good tires. Those Conti's cost around $30-$40 a pair, depending on current sale prices, and ride almost as nicely as my much more expensive Schwalbe One V-Guards. I'm currently riding Conti Grand Prix Classic skinwalls, which look great -- true translucent skinwalls, handmade in Germany -- and cost twice as much but don't ride any better than the Ultra Sport II.
canklecat is offline
Likes For canklecat:
Old 05-08-20, 12:35 PM
  #8609
valve_timing
Bikes: 2018 Breezer Doppler Pro , 1989 Centurion Ironman Master
Quoted: 48 Post(s)
Liked 22 Times in 10 Posts
Well if things go according to planned im gonna snag RobbieTunes 56cm notyoufathers ironman and swap over shimano 600 from my current IM if anyone is looking for 60cm master blue water IM shoot me a pm would be frame fork headset cinelli stem and bars. 110mm / 42cm.
valve_timing is offline
Old 05-08-20, 12:39 PM
  #8610
__Dom__
Quoted: 12 Post(s)
Yea, I’ll do a full strip and frame restoration. Overhaul all bearings and replace all consumables. And you’re right about the panaracers, 20 up front lol. Actually has 25 rear which makes me think it was stock since I can’t see how someone who didn’t ride the bike much went out and bought a fatter rear in the same make. I do like the conti ultra sport a lot. For the aesthetic of the bike I will probably do something a little higher end in a gumwall. If I was gonna restore and sell I’d do something lower end like a michelin dynamic but I can’t really see myself parting with such a great find unless the money was too good to pass up or I find another dream bike and my wife won’t let me keep both lol....
__Dom__ is offline
Old 05-08-20, 01:13 PM
  #8611
canklecat
canklecat's Avatar
Yeah, the Michelin Dynamics are a great value in a gumwall. The sidewalls are stiff, so the ride may not be great compared with other tires. But the supple, thin sidewall of the Conti Grand Prix Classic skinwalls doesn't magically translate to a significantly better ride. They look great and ride well, but it's not really any better than the Ultra Sport II.
Old 05-09-20, 06:03 AM
  #8612
texaspandj
texaspandj's Avatar
Quoted: 1605 Post(s)
Liked 583 Times in 380 Posts
Originally Posted by Classtime
Rims -- Schrims
Hoods - Smoods. Check out those OEM pedals!
texaspandj is offline
Old 05-09-20, 11:03 AM
  #8613
tjcough
Quoted: 9 Post(s)
Originally Posted by tjcough
Finally got her all done up after sitting in the garage for years.
Edit: sorry for potato quality, I'm not good with this forum stuff!
Thinking about trying to satisfy my tinker bug and upgrading this. Is it possible at all to go 2X10 on this?
It is currently set up as a 2x8 with 6400.
If it is possible, what do I have to change out? I’m assuming it’s everything but the frame.
20 Giant Escape 2 Disk
89 Centurion IM Master
tjcough is offline
Old 05-09-20, 11:10 AM
  #8614
texaspandj
texaspandj's Avatar
Pic assist.
Old 05-09-20, 11:13 AM
  #8615
tjcough
Quoted: 9 Post(s)
Originally Posted by texaspandj
Pic assist.
Thanks. I couldn’t quite figure out how to get that situated.
tjcough is offline
Old 05-09-20, 11:33 AM
  #8616
rccardr
aka: Dr. Cannondale
rccardr's Avatar
Quoted: 2155 Post(s)
Liked 3,404 Times in 1,205 Posts
It is currently set up as a 2x8 with 6400. If it is possible, what do I have to change out? I’m assuming it’s everything but the frame.
You can keep the wheels and the derailleurs, they’ll both work with Shimano 9-10 speed. You need 10 speed 105, Ultegra or Dura Ace STI shifters (or 7850/7900 downtube shifters and brake levers), a ten speed cassette and ten speed chain. Set it up properly and patiently and you’ll be very happy. You can upgrade to a ramped and pinned 130 bcd chainring for marginally improved shifting up front.
rccardr is offline
Old 05-09-20, 01:17 PM
  #8617
tjcough
Quoted: 9 Post(s)
Any recommendation on the group set numbers for the STI shifters or chainrings if you’ve experienced them?
tjcough is offline
Old 05-09-20, 07:40 PM
  #8618
rccardr
aka: Dr. Cannondale
rccardr's Avatar
Have had good luck with FSA chainrings.
For STI's, 5600 105, 6600 Ultegra, 7800 Dura Ace are all good but do not run the shift cables under the bar tape. Some folks prefer all of the cables to run under the bar tape. That would be 5700 105, 6700 Ultegra, and 7900 Dura Ace. All six of those suggestions are ten speed brake/shifter components. Personally have had good luck with both 105 and Ultegra STI units.
rccardr is offline
Old 05-09-20, 08:02 PM
  #8619
RobbieTunes
Quoted: 378 Post(s)
Pedals Smetals, check out that OEM stem!
Old 05-09-20, 08:10 PM
  #8620
seypat
Ditto on the Nitto!
seypat is offline
Old 05-09-20, 08:49 PM
  #8621
markwesti
markwesti's Avatar
Bikes: 86' Centurion Ironman
Quoted: 628 Post(s)
Liked 316 Times in 175 Posts
Nice score @ _DOM_ , Your in the cult now .
markwesti is offline
Old 05-09-20, 10:01 PM
  #8622
tjcough
Quoted: 9 Post(s)
Thanks for the info. Gonna be a fun time trying to find good deals on these
tjcough is offline
Old 05-10-20, 05:58 AM
  #8623
seypat
Originally Posted by jim dandy
The Stem is a Gem, but the Vetta is Betta ...
JD
seypat is offline
Old 05-11-20, 09:22 PM
  #8624
texaspandj
texaspandj's Avatar
I just finished posting a long post starting with Thanking @rccardr for tires he sent me and finishing with thinking about tuning bikes for some cash. Thanks again Doc. But I posted it on another thread. Hot dang it! I didn't save it because I immediately deleted it. Oh well I'll try again tomorrow.
Old 05-12-20, 07:05 PM
  #8625
RobbieTunes
Quoted: 378 Post(s)
The mind is the first thong to go.
