Park grease
Bikes: 86' Centurion Ironman
Quoted: 628 Post(s)
Liked 316 Times
Park grease
What is the difference between PPL-1 and PPL-2 And what is BF's preference for all steel vintage grease ?
Mark .
Mark .
PPL-1 and PPL-2 are the same,1 is a tube, 2 is a tub.
Buckle up, grease is a highly controversial topic around here.
Not lost wanderer.
Quoted: 886 Post(s)
Liked 1,000 Times
I have an old grease gun refill that is dipped into for threads and other junk but bearings and other rolling parts get Park grease. PPL-1 is in a tube and PPL-2 is a tub both contain Poly Lube 1000
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
Likes For bwilli88:
Friendship is Magic
Bikes: old ones
Quoted: 26427 Post(s)
Liked 10,386 Times
Likes For 3alarmer:
Likes For thinktubes:
señor miembro
Bikes: '70s - '80s Campagnolo
Quoted: 3891 Post(s)
Liked 6,491 Times
Likes For SurferRosa:
Friendship is Magic
Bikes: old ones
Liked 10,386 Times
Likes For 3alarmer:
Quoted: 970 Post(s)
Liked 1,635 Times
Oh... Grease not Geese...
Likes For zandoval:
Quoted: 970 Post(s)
Liked 1,635 Times
Quoted: 801 Post(s)
Liked 754 Times
My preference is cheap, so I use marine grease and I haven't found it to be lacking.
I would like to try out 'Green Oil' brand Ecogrease at some point, it doesn't use PTFE or petroleum-based ingredients. Costly product, but as an environmentalist I feels it's prudent to change where I can.
https://www.green-oil.net/Ecogrease.html
Red 'N' Tacky grease from Lucas Oil from Home Depot. This is my go-to grease for bikes, cars, and everything. Best grease to repack ball bearings. Economical and effective.
https://www.homedepot.com/p/Lucas-Oi...0005/202521504
Likes For Eyes Roll:
Bikes: 1980 Gitane sprint,1977 Motobécane C4, 1977 Carlton Clubman, 1959 Claud Butler European
Quoted: 69 Post(s)
Liked 122 Times
However, try ballistol. Get the 1kg tin, it is really good grease and no ptfe.£15 for a kg.Try the oil, wonderful, actually good for your skin.“Ballistol univeral multi-purpose grease is stable in a temperature range from -30° C to +120° C and is also characterized by a very good water resistance. Ballistol, providing reliable long-term lubrication and good sealing properties and easy pumpability in central lubrication systems.
Ballistol Multi-purpose grease is resistant in wet and dusty environments as well as in cold and hot water. In combination with its good adhesion and oxidation resistance it also protects in such problematic areas safe from corrosion.
Ballistol Multi-purpose grease reduces the friction and wear of all moving parts and has a high load carrying capacity. Ballistol is also aging resistant and drum stable and resistant to dust and water. The multi-purpose grease is silicone-free, resin-free and acid-free and therefore it does not resinify”.
Likes For awac:
Quoted: 1084 Post(s)
Liked 688 Times
As a member of the cycling community, you have an obligation to support the industry by buying overpriced specialty "bicycle" grease, instead of just buying a big tub of marine grease, Lucas Red 'N' Tacky, or just about any generic waterproof wheel bearing grease.
Likes For Colorado Kid:
Quoted: 656 Post(s)
Liked 469 Times
What the…? You mean I don’t have to lube my Dura Ace bits with Dura Ace Special Grease? Next I suppose you’re going to tell me I can put Quaker State in my Buick.
Quoted: 5888 Post(s)
Liked 3,472 Times
Yeah Park grease is overpriced but it looks nice next to all my overpriced Park tools and Park stand. Sort of like a bike gruppo, right?
Likes For bikemig:
Quoted: 3811 Post(s)
Liked 6,718 Times
Who here is still using whale blubber?
Likes For nlerner:
Likes For RustyJames:
Quoted: 628 Post(s)
Liked 316 Times
Thanks , I just bought a new tube of PPL-1 . I saw the PPL-2 and that got me wondering . About the controversy , I know . I made popcorn .
Likes For markwesti:
big fan of Lucas red for car and bike. Although a bit ago I found this military can of Vietnam war era grease so that's what I am currently using.
The most important thing about grease is not what brand you use but that you actually repack it on a regular basis. The best grease in the world that you leave on the bottom bracket for twenty years can't compete with the cheapest grease in the world that you repack every year.
Likes For abdon:
Quoted: 628 Post(s)
Liked 316 Times
At the risk of dumping butter on the popcorn, I believe that Park Poly and Lucas X-tra heavy duty is the same. Maybe it's slightly tweaked so the people at Park can say it's bicycle specific and still sleep at night. C'mon man, it's only grease.
Liked 6,718 Times
Likes For nlerner:
Randomhead
Liked 3,702 Times
Okay, yeah, just checked. I bought the tub in 2017 for $15.28, now it's over $28.
I used to get Phil grease, but they are really proud of the stuff nowadays.
It's just a lithium grease. Not good for keeping a seatpost from getting stuck.
Quoted: 2339 Post(s)
Liked 2,832 Times
I stick to phil's a tube last a long time.
and in general grease and lubricants are cheap for volume used. I don't understand all the people who are trying to save pennies on non bike specific grease and lube. I have never had a bike use quarts of grease and change lube
