Zipp 404 firecrest tubeless
Hi everyone, just installed Zipp 404 firecrest tubeless wheelset and even after adding sealant 3 times to the rear tire the pressure is losing about 1 PSI per hour. I feet the air is leaking around the valve itself.
any tricks you have to make the valve more airtight?
thanks
thanks
Quoted: 1833 Post(s)
Liked 1,709 Times
I am not familiar with those wheels, but most of the time air leaking at the valve is because there is a problem with the tape elsewhere along the rim bed. Once air gets into the hollow rim, it will escape at the valve
Bikes: SL8 Pro, TCR beater
Quoted: 1003 Post(s)
Liked 588 Times
Yep - it's probably not the valve itself, but a leak somewhere due to poor installation of the tape or a hole somewhere. Just bring it back to wherever you bought them and ask them to fix it. If that's not an option, then I would inspect the tape, make sure it's properly installed, replace if needed, and inspect the valve as well.
they were bought online unfortunately
will inspect it and see if there is a hole that could explain the problem
thank you
Quoted: 7050 Post(s)
Liked 11,101 Times
It would help to know if the wheels are new, and whether OP is using the valves supplied by Zipp.
Quoted: 9656 Post(s)
Liked 6,366 Times
How much loss is normal? Our three sets all loose air overnight to varying degrees, but all in the same ballpark.
I've always topped off air before a ride, even on consecutive days.
Quoted: 1463 Post(s)
Liked 1,487 Times
1psi per hour means the tire would be completely flat after just a few days. This is not normal.
My guess is the same as others - look at the tape job. It's probably that, but could be the valve itself, particularly if they're not the factory Zipp valves.
FWIW - I'm still using the factory tape on a pair of Zipp wheels that were purchased new in spring of 2021.
An easy to try trick that works a good bit of the time if it is the valve. Take the wheel off and bounce it with the valve at 6 o'clock so you are splashing sealant around the base of the valve.
Likes For Canker:
Bikes: 2022 Moots RCS, 2014 BMC SLR01 DA Mech, 2020 Santa Cruz Stigmata, Ibis Ripmo, Trek Top Fuel, Specialized Levo SL, Norco Bigfoot VLT
Quoted: 464 Post(s)
Liked 182 Times
Tighten the nut at the base of the valve too. If that does not fix the issue, you will have to examine the tape. If you replace the tape, put a tube in overnight, The tube will put huge pressure on the tape and make it much less likely to ever let sealant and air in under it. It squishes the tape down really nicely...far better than you can do by hand. When poking the valve through new tape, I usually cut a very small cross-shaped cut with a sharp utility knife to let the valve poke through. Never had issues this way. You could also burn a tiny hole with a hot tiny screwdriver or something similar but you don't want to take the hole too big. Also, overlap the tape 8+ inches over the valve hole area.
Likes For Chandne:
thanks
thanks
You should be able to tell if it's leaking around the valve stem. Put some dish soap in water and put it around the stem. It should blow bubbles even if it's a slight leak.
J.
