View Poll Results: What size tires should I use for my René Herse
28mm
4
11.11%
32mm
17
47.22%
35mm
15
41.67%
Voters: 36. You may not vote on this poll
Help me choose tire width for my René Herse
Help me choose a tire width for my René Herse
EDIT/UPDATE: Thanks y'all, I decided to go with 32s, at least for now. I already have 28s and 35s on other bikes, so if I buy 32s, I can try all three out and decide for myself, with 32s being the starting point. I have decided that 35s will look a bit out of place on this bike. I am slightly worried I'll feel the same way about the 32s, but we'll see when they arrive and are mounted. 28s look very nice on there, so if nothing else, I'll have a nice fallback.
Original post below:
I'm choosing tires to use as my "rider" set on a René Herse I restored. I'm going to use Herse tires with their extralight casing, and my options are 28mm, 32mm, and 35mm.
I've included a photo of the bike with a 28mm tire and a 35mm. I don't have a 32 so you'll have to use your imagination for that one. I also attached a photo of the full bike with the original wheels so you can get a sense of what the build itself looks like. My clincher set for this build looks very similar to the original tubulars.
Don't pay attention to the wheels themselves in the 28mm and 35mm photos - they are of different wheels I have which currently have the relevant tires mounted, so they made for good comparison shots.
I'm inclined to go with 32s, because while I have room for 35s and as a general rule I'd like to go large, the 35s look kind of disproportionate to me. And on this bike, aesthetics matter. Then again, the bike has a rear rack, so fat tires wouldn't be too outlandish, but it was also built around Campy components, and is not a heavy touring bike.
I'm curious for other folks thoughts and opinions. What would you put on?
Side note: this bike was found via a bikeforums post. It was bought at auction for way too little money because it looked to be in pretty rough shape, but as you can tell from the current photos, it was mostly just dirt and grime.
28s
35s
Full build
28s
35s
Full build
Last edited by J_Climacus; 04-23-24 at 08:16 AM. Reason: Edited to add an update on my decision
Likes For J_Climacus:
The Huffmeister
Bikes: '79 Trek 938, '86 Jim Merz Allez SE, '90 Miyata 1000, '68 PX-10, '80 PXN-10, '73 Super Course, '87 Guerciotti, '83 Trek 600, '80 Huffy Le Grande
Quoted: 1241 Post(s)
Liked 3,591 Times
A Copake bike? Or the one that went for like 500 smackers somewhere on the East Coast...Maryland, maybe?
There were 135 Confentes, but only one...Huffente!
Bikes: several Eddy Merz (ride like Eddy, braze like Jim!)
Quoted: 1103 Post(s)
Liked 1,868 Times
As goldilocks said……
The 28s are too small. They look puny on such a large frame
The 35s are too big. They look out of place.
The 32s are prolly just right.
"Leave the gun. Take the Colnagos."
Likes For Robvolz:
Quoted: 1957 Post(s)
Liked 2,029 Times
I’d be inclined to ride a bike with such a pedigree with the tires it was designed for—At least for several thousands of miles. And then if you must ignore the builder’s intensions, 28s.
Nice Bike.
Nice Bike.
aged to perfection
Quoted: 850 Post(s)
Liked 1,278 Times
maybe a 35 Rear and 32 front?
larger frames tend to have more of the weight distribution on the rear wheel.
yes, very nice bike
/markp
yes, very nice bike
/markp
aka: Dr. Cannondale
Quoted: 2157 Post(s)
Liked 3,427 Times
If your intended use is around DC and environs, a 32 would be pretty much perfect. Would even be good for the C&O.
I’d go fatter for touring, though.
I’m in NoVA and ride into DC frequently. We should get together some time!
Clark W. Griswold
Quoted: 4422 Post(s)
Liked 4,064 Times
If it were my bike and a 35 could fit fine, it would be 35 all the way. Plusher is better, ATMO!
Likes For veganbikes:
Quoted: 2345 Post(s)
Liked 2,854 Times
don't know it this will help but here is what 32 look like on my kirk. Rims are H+Son archetypes
Likes For squirtdad:
Bike Butcher of Portland
Bikes: It's complicated.
Quoted: 4690 Post(s)
Liked 5,837 Times
I like to ride my bikes, not stare at the tires. 35's ride a lot nicer than 32's, IMO.
Likes For gugie:
Quoted: 192 Post(s)
Liked 568 Times
Without knowing the geometry, I am guessing that it is “competition” geometry or a slightly relaxed version. If that is the case, the bike is supposed to be a bit snappy and I would be inclined toward 28 or even 25’s….especially if the tubes are very light gauge…
Likes For pnwgopher:
ignominious poltroon
Quoted: 2255 Post(s)
Liked 3,470 Times
If it fits 35s, try to cram in 38s.
Likes For Polaris OBark:
Quoted: 802 Post(s)
Liked 755 Times
I really like 28mm tires for road riding. A bit of extra cushion without feeling heavy like wider tires can feel. Though iff your roads are rough, opt for 32mm probably.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,704 Times
I say 35s. Especially if you can fit the 35s under fenders for that bike.
For whatever it's worth, I recently picked up some Jack Brown 33.3 tires to replace some Herse 35s that were tight under the front fender. I just replaced the front and I really kind of like it- so right now it's rolling with a Herse 35 Bon Jon Pass in the rear and a Jack Brown 33.3 in the front.
by https://www.flickr.com/photos/151917295@N05/, on Flickr
Commence to jigglin’ huh?!?!
Not lost wanderer.
Quoted: 890 Post(s)
Liked 1,011 Times
I like the widest tires I can fit.
go with the 38s
go with the 38s
Cambodia bikes, Bridgestone SRAM 2 speed, 2012 Fuji Stratos...
Likes For bwilli88:
Señor Member
Quoted: 1497 Post(s)
Liked 1,099 Times
I voted 32s - with the presumption being that the bike should have mud guards, and 35s would give dicey clearance. If 35s and mud guards are not mutually exclusive, go for it.
Quoted: 837 Post(s)
Liked 2,165 Times
With 32s, you may also be able to fit fenders (if you ever decide to take that beauty in the rain). How much clearance in the rear? Are you able to remove the rear wheel with the 35mm tire without deflating the tire? That's another consideration. Normally I'm in the "fit as large as you can" camp, but there's a point when minimal clearance can pose its own problems. I find 32mm tires to be plenty comfortable (though I haven't much experience with 35mm tires).
Quoted: 3817 Post(s)
Liked 6,741 Times
I've put a fair number of miles on both 32 and 35mm RH tires. I really like them both, but I understand that aesthetics are important and "skinnier" might look more proportional. Really, you can't go wrong with either (I have no experience with the 28mm version).
Quoted: 881 Post(s)
Liked 2,307 Times
I can’t understand how anyone else can recommend tire size for someone based on a picture of the bike. All the sizes you mention are fine , choose the one YOU like!
Liked 2,029 Times
I have no problem recommending tire size (or chainring and cog sizes, or handlebar orientation, or saddle height, or saddle to bar drop, or even colors).
Likes For Classtime:
I'm curious what your thought process on 28s is. Is it just that the bike was designed for a snappier feel than 30+ tires can provide? That thought crossed my mind.
Sir, this is the internet. All we do here is give opinions, oftentimes bad ones!
Crawlin' up, flyin' down
Quoted: 1035 Post(s)
Liked 2,556 Times
My guess is that the builder's intentions were that the bike be ridden, taken care of and loved. I'd say you are doing just fine in the "doing justice to the builder's intentions" department regardless which size tire you ultimately choose. Pick the one that fits and feels best to you.
