What type of gearing does a Trek 7.1 FX have?
Old 05-18-15, 06:58 PM
yashinon
yashinon's Avatar
Bikes: Trek Domane
Quoted: 7 Post(s)
In another thread, someone mentioned that the 7.4 FX has mountain gearing. A friend bought a 2015 7.1 FX. Just curious as to what type of gearing the bike has?
yashinon is offline
Old 05-18-15, 09:45 PM
squatchout
Bikes: '15 Trek 7.2 FX
It has "mountain bike" type gearing as well (just 21-speed instead of 27-speed on the 7.4). Most hyrbrids like that do until you usually get into the higher models that are meant to be more like flat bar road bikes. In the Trek FX lineup that's not until you hit the 7.5 and 7.7.
squatchout is offline
Old 05-19-15, 07:20 AM
ScotchMan
Sorry for the noob question, but can someone explain what the difference is between "mountain" gearing and the alternatives?
ScotchMan is offline
Old 05-19-15, 08:05 AM
Wanderer
aka Phil Jungels
Wanderer's Avatar
Bikes: 08 Specialized Crosstrail Sport, 05 Sirrus Comp
Quoted: 141 Post(s)
Liked 2 Times in 1 Post
Mountain gearing usually ends up with a largest rear cog at a minimum of 30-36 teeth, road gearing usually 28 or smaller. Mountain gearing usually has a rear derailleur with a long cage to accommodate those bigger sprockets. Road gearing has a short cage. Front sprockets on mountain gearing is usually 48 and smaller, while road gearing will be 50 or bigger, on the big sprocket. Road gearing is leaning away from triple front sprockets, while mountain gearing embraces them.
Wanderer is offline
Old 05-19-15, 08:15 AM
ScotchMan
Why would road gearing have a smaller largest rear cog? Wouldn't you want a larger one because you go faster on a road bike than on a mountain bike?
Old 05-19-15, 08:46 AM
gpburdell
Quoted: 76 Post(s)
You've got it reversed. On the REAR cog, smaller (fewer teeth) = higher gearing ratio.
gpburdell is offline
Old 05-19-15, 08:50 AM
ScotchMan
Gotcha. Yes that makes sense now that I think about it.
Old 05-19-15, 10:47 AM
steve_cay
Bikes: 2013 Trek 8.4 DS
Also mountain drivetrain is optimized to be tougher, while road drivetrain is optimized to be lighter.
steve_cay is offline
Old 05-19-15, 06:12 PM
yashinon
yashinon's Avatar
Bikes: Trek Domane
Quoted: 7 Post(s)
What would it take to convert a 7.4 to more road friendly gearing?
yashinon is offline
Old 05-19-15, 07:11 PM
ColonelSanders
ColonelSanders's Avatar
Bikes: 2017 Surly Troll with XT Drive Train, 2017 Merida Big Nine XT Edition, 2016 Giant Toughroad SLR 2, 1995 Trek 830
Quoted: 1275 Post(s)
Liked 25 Times in 23 Posts
A rear cassette with a tighter range, like a 9 speed 11-25.
But if you are happy with your current gearing, making a change to the above would seem to be of little value.
You won't be any faster on the road, you will just have more precise gear ratio's.
ColonelSanders is offline
Old 05-19-15, 07:30 PM
steve_cay
... and less ability to climb steep hills.
Old 05-19-15, 07:42 PM
yashinon
yashinon's Avatar
Bikes: Trek Domane
Quoted: 7 Post(s)
Just a question, not planning any changes.
yashinon is offline
Old 05-19-15, 08:12 PM
ColonelSanders
Because you have a triple ring, you could switch your cassette out to something like a 12-27 and use your granny ring for hills(26/27) and have more precise gearing for various conditions.
If you feel like indulging in some weight weenieism, you could also eliminate maybe 150grams or more by switching to an Ultegra version of 12-27 cassette.
Old 05-20-15, 11:51 AM
fietsbob
coprolite
fietsbob's Avatar
Bikes: 8
Quoted: 6925 Post(s)
Liked 246 Times in 204 Posts
Google is easy .. 7.1 FX - Trek Bicycle
Crank
Forged alloy, 48/38/28 w/chainguard
Shifters
Shimano Altus EF51, 7 speed
Cassette
SunRace Freewheel 14-34, 7 speed
I'd call it a Trekking Type for the 48/38/28t crank and the 14 to 34t cassette tooth counts.
Trekking is riding anywhere and even bringing the camping gear in panniers, AKA Touring.
fietsbob is offline
thombiker
Road Cycling
69
12-06-15 10:59 AM
yashinon
Hybrid Bicycles
0
05-18-15 06:46 PM
MissDaisy
Hybrid Bicycles
14
10-02-14 10:19 AM
sizzam
7
05-30-14 02:56 PM
jaycb74
Hybrid Bicycles
32
11-03-12 11:45 AM
