Self inflating tire?
Quoted: 626 Post(s)
Liked 701 Times
This is an interesting concept.
If the CRR is low enough, I can see some situations where it would be useful, but for those of us that already check our tires ~weekly, maybe not so much?
I wonder how well this would work in conjunction with a good flat sealant (I have been really happy with Flat Attack)?
https://airwinder.com/
The tech page explains how it works: https://airwinder.com/technology/
I'm not going to get in on this kickstarter, but I'm going to watch and see if this actually makes it to market.
Quoted: 2604 Post(s)
Liked 1,928 Times
Looks like a non-cycling student did a "project" for a non-cycling instructor, and they went off open loop.
30 seconds thing by a cyclist here...
What happens if a piece of glass or metal, or a thorn, punctures the inflation tube? (No pumping.)
So you have to buy an integrated tire and matching tube. How do you patch the tube?
Give the kid an A for originality, pat him on the head, and send him (or her) to Econ and Accounting classes.
Likes For pdlamb:
I can see how the principle could work, but I'm not sure if such system would be capable to generate more pressure than there is in the tire at any given moment - which would be needed to actually pump some air into the tire.
It says nothing about tubes, so I imagine it is meant for tubeless setup.
Tragically Ignorant
Quoted: 8186 Post(s)
Liked 9,098 Times
Bikes: 2011 Fuji Absolute 3.0 -- 1997 Trek 830 (modified to hybrid)
Quoted: 79 Post(s)
Liked 548 Times
Color me skeptical. I'd be a late adopter, after a few years of many people on Bikeforums posting how great it is...
I check the air in my tires every other ride, correcting as necessary. Some people hate to check/add air, to me it's just a normal part of my pre-ride process. My buddy hates checking the tires so much that he bought a Specialized Alibi with airless tires. To each their own! Viva la difference!
Likes For Rje58:
Quoted: 626 Post(s)
Liked 701 Times
Yeah, I didn't look to see where the wannabe manufacturer is from, but I suspect this is intended for the casual rider/commuter that hates to put air in their tires. I've known commuters who don't even own a pump, and just put air in at the gas station when they think about it, so....
I can also see this being useful in touring situations, where the tire pressure automatically 'sets' as the temperature changes. Other than that, definitely not for 'serious' riders.
Tragically Ignorant
Liked 9,098 Times
"As the tire turns, it pushes the air forward through the pumping mechanism and into the inner tube."
I think the theory is that the mechanism gets squeezed between the tire and the tube, so it wouldn't work on a tubeless setup.
Does it sound like they have a working "proof of concept" model?
climber has-been
Quoted: 3427 Post(s)
Liked 3,563 Times
My expert opinion: Probably will never work.
Their "pump" is a tube between the tire tread and casing. The "pumping action" relies on tire contact patch deformation to squeeze air through the tube.
Squeezing a tube is a very crude mechanism to try to get several atmospheres of pressure, even in the best situation. I seriously doubt they can manage it in a tire.
Then there's the reliability/safety issue of putting a flexible tube between the tire casing and the tread. No thank you.
Likes For terrymorse:
Quoted: 18410 Post(s)
Liked 15,531 Times
Why doesn't someone invent something really useful, like an electronic oil slick sprayer like the Batmobile had? Draft me on the M.U.P. without permission? I don't think so. Instead, we get things like disc brakes, gravel bikes and 1x drivetrains.
Likes For subgrade:
Quoted: 1002 Post(s)
Liked 237 Times
So was most of the tech developed for the Space Race in the 60's
In the public sector none of those solutions had problems they could solve. But once the solutions were out there, we found problems to use them on and tech exploded in the public sector.
Nothing wrong with developing technology just to the heck of it and without a clear viable practical purpose.
This concept is cool. It's over thinking a bike tire flat. But the concept is cool and when put in front of enough eyes, I'm sure someone will see an alternative use for it.
Likes For Skipjacks:
Liked 237 Times
Wanna automate it? Just get a windshield washer tank and pump from an older car, hook it up to a small battery and put a button on the handlebars.
(I may or may not have had this idea before and have already given it way more thought than I should have. Maybe.)
Tragically Ignorant
Liked 9,098 Times
Likes For livedarklions:
Quoted: 626 Post(s)
Liked 701 Times
It's the same idea behind a hydraulic lift similar to what's used for cars. You have a small pump making fairly moderate pressure, but it moves a lot of liquid (slowly) over time. You can lift a car with only 10 psi, it just takes a large area.
climber has-been
Liked 3,563 Times
For the tube pump to work, the pressure in the tire needs to be higher than in the tube, or it won't compress. But the the air doesn't flow into the tire.
It would need some pressure doubler.
Remonds me of my ideas to build a perpetum mobile... when I was 8.
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Ok, reading comprehension time.
The website took 5 minutes to read and is devoid of anything that would make it above an 8th grade reading level.
The product is intended for commuter and city bikes (35-45mm wide tires, pressures from 65-35psi) seeing frequent use. Not high pressure skinnies.
Best bet on construction is that it's similar to a clincher tubular tire. They won't fully explain the trade secret because 'trade secret', but the pumping tube is likely outside the casing under the tread. Some one way valves are capable of stepping pressure up around the wheel to overcome internal pressure.
Biggest downsides are increased rolling resistance and potentially abnormal handling, depending on the valves and how much volume the pumping channel uses.
Maybe for mtb tires too, but the amount of pumping needed for loaded touring, sport, and road tires is likely impractical.
