Quick release skewers not enough threads to tighten rear wheel
Old 09-08-20, 06:52 AM
Adis
Quoted: 24 Post(s)
Liked 2 Times in 1 Post
Quick release skewer not enough threads to tighten rear wheel
Hello,
I converted the front wheel on my bike with quick release and I'm having problems with the rear wheel. I installed the quick release axle to the rear wheel and the axle is too long so I cut it with a saw and it solved that but, I'm having another problem. The quick release skewer thread is not enough for the rear wheel so the rear wheel is not secure. Is threre a longer threaded rear wheel skewer that I can buy?
Adis is offline
Old 09-08-20, 07:14 AM
dsaul
Quoted: 713 Post(s)
Liked 796 Times in 473 Posts
You know front and rear skewers are different lengths, right?
dsaul is offline
Old 09-08-20, 07:21 AM
Adis
Quoted: 24 Post(s)
Yes. The shorter is for the front and the longer one is for the rear. What I'm talking about is, can I get a longer threaded rear skewer.
Adis is offline
Old 09-08-20, 07:25 AM
dsbrantjr
dsbrantjr's Avatar
Quoted: 1438 Post(s)
Liked 1,092 Times in 723 Posts
Is the rear skewer not long enough, or do the threads not go far enough from the end? It sounds like you shortened the axle and now need a shorter skewer because you are running out of threads, is this the situation?
dsbrantjr is offline
dedhed
SE Wis
dedhed's Avatar
Quoted: 2740 Post(s)
Liked 3,388 Times in 2,051 Posts
Does the axle sit within the drop outs and not extend beyond them?
https://www.bikeforums.net/bicycle-m...se-skewer.html
dedhed is offline
Old 09-08-20, 07:37 AM
Adis
Quoted: 24 Post(s)
Here's my axle and skewer. I put the original axle back to the wheel.
Adis is offline
Old 09-08-20, 07:42 AM
HillRider
Quoted: 2026 Post(s)
Liked 1,095 Times in 741 Posts
What is your rear dropout spacing? If you have a 126 mm OLD frame and hub but have a 135 mm OLD skewer, it would not be threaded far enough to tighten.
HillRider is offline
Likes For HillRider:
Old 09-08-20, 07:51 AM
Adis
Quoted: 24 Post(s)
I have 126mm spacing, the axle is 136mm (after cutting it) and 180mm rear skewer (not sure. I measure with a ruler).
Adis is offline
Old 09-08-20, 07:58 AM
dsbrantjr
dsbrantjr's Avatar
You need a shorter skewer suitable for your dropout spacing/axle length.
Likes For dsbrantjr:
Old 09-08-20, 08:39 AM
Crankycrank
Quoted: 836 Post(s)
Liked 1,058 Times in 742 Posts
you need a shorter skewer suitable for your dropout spacing/axle length.
+1.
Crankycrank is offline
Old 09-08-20, 08:54 AM
dsbrantjr
dsbrantjr's Avatar
The threads on the current skewer are rolled, not cut, so there will not be sufficient material to cut more threads and still have adequate thread depth, so a shorter skewer is your only choice.
Old 09-08-20, 09:27 AM
dsaul
Quoted: 713 Post(s)
I would think a skewer for a 130mm wheel would still have enough thread, but here is a skewer for 126mm wheels https://www.loosescrews.com/product/...or-137mm-axle/
dsaul is offline
Old 09-08-20, 10:07 AM
fietsbob
Bikes: 8
Quoted: 7607 Post(s)
Dropout width kept getting wider as "Speeds" were added _ 120-5, 126-6~7, 130-8 & 135 MTB. & now disc rear wheel ..
(Through axle, went even wider)
you need a QR Skewer from the past era when bikes had 126 mm wide dropouts
(or *hack* add spacers outside of the drop out , not a safe thing unless vertical dropouts.. sketchy even then..)
fietsbob is offline
Old 09-08-20, 05:28 PM
JohnDThompson
Old fart
JohnDThompson's Avatar
Quoted: 3582 Post(s)
Liked 3,395 Times in 1,929 Posts
+1 this. In my experience, even cheap skewers have rolled threads.
JohnDThompson is offline
Old 09-09-20, 08:20 AM
oldukbkr
Bikes: '59 Rory O'Brien, 49/72 Holdsworth Trike, '66 Bates BAR, '74 Bob Jackson
Quoted: 16 Post(s)
Liked 26 Times in 13 Posts
Since you mentioned cutting the axle to size, make sure it does not extend beyond the dropouts. If the axle is slightly too long the QR will clamp against the axle instead of the dropouts and the wheel will not be secure.
oldukbkr is offline
Old 09-09-20, 08:43 AM
alcjphil
alcjphil's Avatar
Quoted: 1815 Post(s)
Liked 1,693 Times in 974 Posts
It appears that you bought an axle that was too long for your application and that the skewer was sized for that axle. It is possible but not ideal to cut the axle to a shorter length but not the quick release. All this could have been avoided by buying the correct length parts in the first place.
alcjphil is offline
