Taking a seat tube 27.0 -> 27.2?
Old 09-20-20, 11:16 AM
coffeecherrypie
Quoted: 37 Post(s)
Liked 12 Times in 9 Posts
I have an '86 Centurion Ironman (the red and white one) that I've put modern components on. Wheels and drivetrain are now black, seatpost and cockpit are not. I think it would look better with all black components. The issue is the seatpost. I prefer two-bolt seatposts since I am anal about my saddle angle. I also need some setback. The bike takes a 27.0mm seatpost. I cannot find a black 27.0 two-bolt seatpost with setback--Thomson apparently only makes a 27.0 with zero setback, even if they did make at 27.0 with setback I am right on the edge of it not working with the way they angle the seatpost.
SO--to my question. I have heard one can ask a shop to ream out a seattube to go from 27.0 to 27.2 ID. On the scale of not an issue at all to a horrible idea, where is this? Frame is not a showpiece by any means, it gets ridden a lot, but by the same token I would be sad if this lead to its demise.
EDIT: also just curious: *why* is this bike 27.0? Is that just how Tange tubing of the time was? This has the Tange No. 1
EDIT #2 : just more context as to why I'm asking here....recently moved and so LBS and I are new to each other. I want to make sure I understand the risks if any, should they end up being the overconfident type.
coffeecherrypie is offline
Old 09-20-20, 11:34 AM
Bad Lag
Bikes: 1974 Bob Jackson - Nuovo Record, Brooks Pro, Clips & Straps
Quoted: 1104 Post(s)
Liked 794 Times in 452 Posts
IMO, it's a HORRIBLE idea. Don't mess with the frame.
If you can find a smaller diameter seat post, use a shim to fit the post to the frame.
Honestly and without question, I'd do the shim before removing metal.
Alternatively, I'd get a machinist to turn down the seat post and refinish it. Alternatively, do it yourself (even by sanding) and refinish the turned down section. Heck, done properly, there may be next to nothing to refinish.
Bad Lag is offline
Old 09-20-20, 11:46 AM
coffeecherrypie
Quoted: 37 Post(s)
Honestly and without question, I'd so the shim before removing metal.
Ok, thanks for the advice. Turning down a 27.2 is a good idea...I'd guess that at minimum the turned down part would be no longer black though right?
Hmm, maybe I could just get my current seatpost powder coated black? ...not sure how much thickness that would add.
Old 09-20-20, 12:15 PM
shuru421
Quoted: 284 Post(s)
Liked 50 Times in 20 Posts
I think its best to find the correct sized seatpost so that you avoid any damage or potential risk of malfunctioning.
shuru421 is offline
Old 09-20-20, 12:20 PM
Fahrenheit531
52psi
Fahrenheit531's Avatar
Quoted: 790 Post(s)
Liked 802 Times in 391 Posts
Maybe find something silver in the correct size and throw a few bucks at your local powdercoat guy?
Fahrenheit531 is offline
Old 09-20-20, 12:26 PM
guy153
Quoted: 321 Post(s)
Liked 263 Times in 212 Posts
0.2mm is hardly anything to take off. It will be fine. You will then also have a nicely dimensioned seat tube (assuming the LBS does a decent job) unlike a lot of production bikes which often have seat slipping down issues.
guy153 is offline
Old 09-20-20, 12:27 PM
xiaoman1
xiaoman1's Avatar
Bikes: A few too many
Quoted: 1364 Post(s)
Liked 2,181 Times in 1,183 Posts
O.P.
Find the post you want and insert to the desired height, mark it where you want the black paint to end, remove it and use a matt black industrial paint from Rustoleum....done.
Powdercoat will add thickness that you will need to sand off anyway.
Best, Ben
xiaoman1 is online now
Old 09-20-20, 03:25 PM
rccardr
aka: Dr. Cannondale
rccardr's Avatar
Quoted: 2155 Post(s)
Liked 3,404 Times in 1,205 Posts
This. Tange #1 will easily work with reaming to 27.2.
In fact, my 87 Ironman Classic- like yours, but yellow and white- uses a 27.2 already, and did not require reaming or any sort of magic or fancy forcing for it to fit properly.
rccardr is offline
Old 09-20-20, 04:42 PM
Bianchigirll
Bianchi Goddess
Bianchigirll's Avatar
Quoted: 2930 Post(s)
Liked 2,926 Times in 1,491 Posts
I won’t debate the merits of doing it.
To me the real issue is finding a competent mechanic with the right tool you can trust to do the job.
I’d exhaust all other ideas. Have you searched everywhere for the black two bolt? Is there a machine shop in your area that does anodizing or hydrographics or hydro dipping?
Sugar "Kane" Kowalczyk
Bianchigirll is offline
Old 09-20-20, 04:52 PM
Bianchigirll
Bianchi Goddess
Here is a black Cannondale sport two bolt and has an angle so looks like lots of setback
https://www.ebay.com/itm/NOS-CANNOND...Cclp%3A2334524
Old 09-20-20, 05:34 PM
coffeecherrypie
Quoted: 37 Post(s)
Interesting...I was just looking at vintage-centurion.com, and I was wrong, mine is an ‘87 too. Funny, that site lists ‘89 as the first 27.2 year. So either it’s wrong, or someone reamed yours out, or a 27.2 happened to fit in your 27.0 tube.
Old 09-20-20, 05:36 PM
coffeecherrypie
Quoted: 37 Post(s)
thanks! That’s the only such seatpost I’ve ever seen. Unfortunately the listing says it’s missing a part.
Old 09-20-20, 05:40 PM
coffeecherrypie
Quoted: 37 Post(s)
Originally Posted by xiaoman1
O.P.
Best, Ben
Thanks, that certainly sounds like something I could manage, though I’m not sure I’d trust myself to paint it particularly nicely. Is this a spray paint you’re thinking of?
Old 09-20-20, 05:42 PM
coffeecherrypie
Quoted: 37 Post(s)
yes, and it’s not like I can go in and check out their tools—everywhere around me is still all curbside due to covid. However this makes me think I could try to find a local frame builder, who would certainly be competent to do this. I’m in Philly btw.
good idea, powder coating had been on my radar but not anodizing or hydro (actually I have not even heard of that)
Old 09-20-20, 05:45 PM
Bianchigirll
Bianchi Goddess
If I were to do this I’d look to see if Stanley still works at D&Q over in Cherry Hill NJ. He coldest my Hetchins and built some killer wheels for me. I don’t know if Belinkey in Philly would do it or not.
Old 09-20-20, 06:06 PM
xiaoman1
xiaoman1's Avatar
CCP,
Scotchbrite pad to " lightly" scuff up the seat post.....hang the post up with wire or twine masking what you do not want paint on (seatbolts and saddle clamps etc).
Use very light coats (small bursts) and stay at least 10-12 inches away, if using a satin or matt paint you won't go wrong....just light coats not one heavy one.
No sweat, if you foul up wipe it off and try again....
Rustoleum or Krylon are good rattle can spray paints.
Best, Ben
Krylon might have a "fan nozzle" making spraying easier....not as durable as P.C. but it's on a part that will not get a lot of touching, unless wrapping a chain around it!
Old 09-20-20, 06:12 PM
coffeecherrypie
Quoted: 37 Post(s)
it looks like D and Q the cycle shop is gone now (tho there is now a D and Q the ski/snowboard shop). I’ll try Bilenky, thanks again.
Old 09-20-20, 06:14 PM
coffeecherrypie
Quoted: 37 Post(s)
CCP,
Best, Ben
Thanks, once long ago I rattle canned a frame and it came out fine so this seems within my limited skill set...dumb question, but Scotchbrite pad as in something that scrubs one’s pots?
Old 09-20-20, 06:34 PM
xiaoman1
xiaoman1's Avatar
CCP,
No dumb questions...yes the ones we use to scrub pots and pans...if using an already used on be sure to clean the post after to get the cooking grease off.
Best, Ben
Old 09-20-20, 07:37 PM
rosefarts
With a mighty wind
Quoted: 1088 Post(s)
Liked 862 Times in 490 Posts
Fwiw, a 27.2 fits fine in my wife's Centurion Ironman.
When I got it, the post was frozen into the frame. I got it out with some help of a bench vise. After that, I loosely wrapped some 120grit sandpaper around a rod and spun it inside the frame with a drill for a few seconds to clean up the rust.
I assembled and adjusted the bike with a cheap 27.2 from my shelves while I was deciding which seat to give her. It was only on final assembly that I realized it was a 27.0 bike.
You should just try a 27.2 and see if it fits tightly. Don't get a super long one, that's just a lot of extra work. It's tight enough that frequent adjustment would be a bummer.
rosefarts is offline
Old 09-20-20, 08:17 PM
droppedandlost
small ring
droppedandlost's Avatar
Quoted: 438 Post(s)
Liked 925 Times in 370 Posts
You could also try a ball hone, that did the trick for me on a frame.
There was a post recently (don't remember the thread) of a frame that got reamed slightly off line and went through the side of the seat tube.
59 Allegro Special -- 72 Bob Jackson -- 74 Motobecane Grand Jubile -- 74 Sekine SHS 271 -- 80 Nishiki International
droppedandlost is offline
Old 09-20-20, 08:24 PM
coffeecherrypie
Quoted: 37 Post(s)
Hmm you are the second person in this thread to note that a 27.2 has worked in a Centurion frame that is supposed to be 27.0. And, it is the case that I really have to crank down the seatpost bolt on mine to stop the 27.0 post from slipping...interesting...
Old 09-20-20, 08:38 PM
scarlson
scarlson's Avatar
Quoted: 964 Post(s)
Liked 1,451 Times in 723 Posts
Yeah sometimes people have an undersize post in a frame for years. I've seen it. The binder bolt will still hold the post up, but the ears that it holds together may be angled and the slot may be smushed. You should have a look at the slot and see what you think. Post a pic if you're not sure. If it looks like it's been smushed down, you can always pry it open gently.
Otherwise, it's not a bad job to ream a seat tube yourself. You will need a Chadwick & Trefethen adjustable reamer size #3 or a Cleveland size I (I as in the letter I). They can be had for around 30 bucks on Ebay if you're patient. Easier than messing with a shop. Easy tools to use, just set the blades to get a snug fit and then put an adjustable wrench on and turn. Drip some oil in there too. Watch a youtube video on reaming if you're feeling nervous. Remember we all did this our first time once and we all lived through it. Even René Herse had a first seat tube reaming experience. How do you get good at something if you don't do it? Metalworking is fun and empowering! Skills build upon other skills and your skillset will become more than the sum of its parts. And I'm guessing it's less work and money to buy a reamer and do it yourself than it is to go to a shop. You can barely get someone to look at a bike these days for the cost of a good used adjustable reamer.
You start down this road, though, you know you'll end up like me and Gugie and TenGrainBread and others on this forum. Bull goose loony. Plum crazy. Bonkers. One day, you'll wake up and your partner will have left you because of your stack of obscure bike tools you bought "because it's cheaper than going to the shop" and you'll be all alone with all the weirdos your newfound skills attract to your place.
It'll be worth it.
Is your username a reference to Twin Peaks?
scarlson is offline
Likes For scarlson:
Old 09-20-20, 08:40 PM
coffeecherrypie
Quoted: 37 Post(s)
Wow Bilenky wrote me right back and said they’d ream out the tube for 100 bucks. A little more than I was expecting but I suppose one pays for expertise and the time of a busy place. Confirms that if done right it’s an unproblematic alteration at least.
Old 09-20-20, 08:54 PM
Aladin
Aladin's Avatar
Bikes: 2000 Litespeed Appalachian, 1998 Litespeed BlueRidge.. 1977? Schwinn LeTour 12.2 'Rain Daze'
Quoted: 64 Post(s)
Liked 17 Times in 14 Posts
WHY.. not just have the 27.2 post turned to 27.0.............? That route only potentially ruins something of much less value.
As I am sure you know... sh*t happens.. that way it aint your frame.
Aladin is offline
Likes For Aladin:
