Sure, 23mm may not be hot now, but are they dead-dead?
I’m bike shopping. I love my current bike. It only has one drawback in my opinion - super narrow chainstays that will only accommodate 23mm rubber (inflates out to about 25). If not for that I would put R8000 on it and be on my way. I plan to keep it regardless, but is shopping for 23mm tires quickly going to become like finding Bigfoot? I had HED trispokes back in the day optimized for 19mm tires, and by the time I sold them I was running 22s because narrower was so hard to find. Wondering how long I’ll be able to keep rubber on this bike if I hold on to it (and still be able to buy mainstream tires like Contis and the like). Anyone predicting the future?
Bikes: Moseman with Campy NR circa 1979, Merlin Titanium from1993 with newly installed Campy Chorus 12, Raleigh Tamland II gravel grinder, Tommassini XFire with Campy Record
Quoted: 30 Post(s)
Liked 104 Times
Well, at least two of will be shopping for 23s.
just another gosling
Quoted: 3886 Post(s)
Liked 1,938 Times
As it is said, "God may have created the world in 7 days, but he didn't have to worry about backward compatibility." 23s will be around. I run them on all my single bikes. There a lot of 23mm outside rims in use, and as a percentage, not a heckuva lot of wider ones.
Results matter
Results matter
Likes For Carbonfiberboy:
vespertine member
Bikes: Yes
Quoted: 687 Post(s)
Liked 220 Times
Nah - 23s aren't completely dead.
As long as there are older frames that don't fit 25s out on the road, 23s will hang around. I've seen some awfully nice TI frames out there without clearance for wider tires, along with their riders - often smaller ex-racer women - not complaining.
Quoted: 338 Post(s)
Liked 408 Times
There's no indication of 23 being discontinued. The top shelf tires are available as 23s (except Specialized Turbo Cottons in 24s). If you buy one of the Canyon aero or triathlon bikes, they come with 23mm in front and 25mm in rear, and I run that combo myself and I rather like it. On relatively modern wheels 23s aren't so narrow, anyway, and unless you're heavier rider you can really use comfortable enough pressures on 23s.
I expect that they will not be discontinued, because when it comes to racing disciplines where you don't get to hang in someone's draft such as TT and triathlon, at least the front tire being a 23mm gives a slight aero advantage which is basically free. I'm not seeing that being thrown away.
Likes For Branko D:
Likes For Dean V:
Oh damn i didnt even know this was a thing. I thought 23mm was standard road bike tire. I know i see 25 all the time, but I always believed 23 was the go to for optimal balance of speed and road handling. Arent 25's much slower/heavier?
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Quoted: 270 Post(s)
Liked 447 Times
I hope 23mm stays around. My old Madone won’t fit a 25mm with the wider fancy carbon wheel I bought.
I eat carbide.
Bikes: Lots. Van Dessel and Squid Dealer
Quoted: 1325 Post(s)
Liked 1,306 Times
As a shop - 23's are like toxic waste. I don't stock any except for super cheap tires because they just don't move. Anyone actually riding them tends to be on the cheaper side (maybe that's why they're riding an older bike as well ) so they'll just buy what they need online anyway. If pressed I can easily source 23's in just about any major tire. This will not always be the case.
PSIMET Wheels, PSIMET Racing, PSIMET Neutral Race Support, and 11 Jackson Coffee
Podcast - YouTube Channel
Video about PSIMET Wheels
Asleep at the bars
Quoted: 234 Post(s)
Liked 203 Times
Selection may be reduced, but as long as there are people buying them there will be 23mm tires made.
"This 7:48 cycling session burned 5933 calories. Speed up recovery by replacing them with a healthy snack." - Whoop
Bikes: Trek Domane SL7 Disc, Cannondale F29
Quoted: 387 Post(s)
Liked 323 Times
Will 23C be around for a long time? Yes
Would I purchase a new bike that is limited to 23C tires? No.. no matter how good the price
Likes For PoorInRichfield:
Bikes: 1988 Bottecchia Professional (for Eroica), 2011 Ridley Noah ISP (retired), 2020 Soma Fog Cutter (daily commuter), 2021 Ridley Kanzo Adventure (gravel), 2022 Tideace Aero (main road bike).
Quoted: 77 Post(s)
Liked 76 Times
23mm tires better not be dead anytime soon -- my 2011 Ridley Noah can't run most 25s. That is, if they actually measure 25mm I can run them, but many brands are usually closer to 26mm and wider at pressure. 25mm Continental GP 5000s seem to be OK (25.6 on my caliper at 7 bar), but I sometimes get a bit of rub on the seat stays when climbing out of the saddle.
Super Modest
Quoted: 10963 Post(s)
Liked 4,620 Times
Keep the chain tight!
Quoted: 4246 Post(s)
Liked 1,351 Times
I suppose one idea would be to try to sell it before it becomes "impossible" to buy tires for it.
I eat carbide.
Liked 1,306 Times
25's are today's 23's. That said just as many people come in and ask for 28's or larger.
It all goes in cycles.
Likes For Psimet2001:
cowboy, steel horse, etc
Bikes: everywhere
Quoted: 12762 Post(s)
Liked 7,675 Times
Still plenty of 23s as of this writing. Michelin Power, Schwalbe Pro One, Conti GP5000, etc.
Mail order will probably be the way to go unless your in a hot vintage market.
Bikes: everywhere
Liked 7,675 Times
If you think 23s are hard to find, imagine wanting 21s.
These are on closeout, so get em while you can
Ad copy says 21", so might wanna confirm
https://www.eriksbikeshop.com/specia...re-pr3e10148/p
Likes For LesterOfPuppets:
serious cyclist
Bikes: S1, R2, P2
Quoted: 9334 Post(s)
Liked 3,679 Times
I doubt you'll be unable to get 23s, but you may likely be unable to get the 23s you want.
Personally, I just wish road bike manufacturers would stop making them tight to exactly what's currently popular, with no overhead. They've gone from tight clearance for 23s to tight clearance for 25s to tight clearance for 28s (with a few exceptions). Why not design in a little overhead?
Likes For Bah Humbug:
Zoom zoom zoom zoom bonk
Bikes: Giant Defy, Trek 1.7c, BMC GF02, Fuji Tahoe, Scott Sub 35, Kona Rove, Trek Verve+2
Quoted: 551 Post(s)
Liked 722 Times
Are your potholes getting smaller and further apart?
No.
23 will be the new 20.
No.
Likes For Branko D:
Quoted: 1456 Post(s)
Liked 1,477 Times
The fastest road bikes will always be designed around minimal gaps though, to maintain the most aerodynamic design. The challenge for manufacturers is to design bikes to what they think is a reasonable max tire size, which seems to be getting larger every few years. The current Cannondale SystemSix can run 28mm tires and the SuperSix Evo is advertised to fit 30mm and I've heard of people running 32mm on them.
At some point, the line between "endurance" or "adventure road" and CX bikes starts to blur, although I suppose most CX bikes now fit tires way larger than the UCI legal 33mm.
The dropped
Bikes: Pake C'Mute Touring/Commuter Build, 1989 Kona Cinder Cone, 1995 Trek 5200, 1973 Raleigh Super Course FG, 1960/61 Montgomery Ward Hawthorne "thrift" 3 speed, by Hercules (sold) : 1966 Schwinn Deluxe Racer (sold)
Quoted: 1739 Post(s)
Liked 1,014 Times
Bikes: 2020 T-Lab X-3 w/GRX Di2, 2018 Trek FX-5S with GRX/Xt 1x drive train
Quoted: 44 Post(s)
Liked 41 Times
Yeah I switched to a disc fork and got up to a 25 up front on my 2003 Airborne Ti, swapped the rear rim brake to current gen 105 and managed to get a 28 out back, but that was a lot of work for 2mm up front and 5mm out back. The ride is nicer, but was it worth the effort? 🤷♀️
(I was already thinking about width, so apologies on the thread highjack) So are the UCI rules the limiting factor? Is there any reason Specialized couldn't design a Tarmac to be aero with 32mm or 38mm tires provided the rims were designed to ideally accommodate them? Where is the tipping point between rolling resistance, weight, aero (in many cases bike has to be designed around a width), ride quality, etc.?
Most manufacturers do make road bikes with room to expand. There's an entire category of "endurance" or "adventure" bikes that are designed with this in mind. Something like a Cannondale Synapse or Specialized Roubaix will easily fit 32mm tires, but is sold with smaller sizes. The Trek Domane can fit up to 38mm tires, but most models are sold with 28mm installed.
Last edited by SCTinkering; 09-22-20 at 09:48 AM. Reason: added multi-quote on wider tires
