Reynolds 501 v. 531?
Bikes: '85 Nishiki Tri-A, early '90's Nishiki Tange Prestige, '84 Trek 610, mid-'80's Miele (unknown), '72 all chrome Raleigh International, '81 Trek 412, 84 Specialized StumpJumper
Can someone explain the difference? Is the 531 simply the current steel? Any substantative differences (weight, strength)?
Quoted: 4722 Post(s)
Liked 3,036 Times
Reynolds 531 is a manganese-molybdenum (MnMo) steel, seamless tubeset that has been available since the 1930s in both plain and butted tubesets. The butted tubesets were avaible in several different wall thicknesses. Reynolds 501 was a chromium-molybdendum (CrMo) steel, seamed, butted tubest that made it's debut about 1983 and was available in two different thicknesses. Both tubesets have long been superceded by more advanced steel tubesets, but Reynolds still makes 531 to special order.
Reynolds used to tout manganese-molybdenum as superior to the chromium-molybdenum used by their major competitors, but eventually produced the 501 tubes using chromium-molybdenum. Both are very good steels.
The 531 sets were seamless, which is theoretically stronger, but is expensive to manufacturer, particularly for butted tubing with varying wall thickness. The 501 set was less expensive to produce because the the material was rolled to the varying wall thickness as a flat sheet, which was then fomed into a tube and welded along its length. While purists prefer the seamless tubes, I have yet to see a seamed, 501 tube fail and have no qualms about riding it.
Reynolds 531 was available in several wall thickness, but the baseline 531(c) tubeset had slightly thinner walls than the baseline 501 tubeset. As a result, the 531 tubeset was about 225g lighter.
In general, 501 was aimed at the mid-range market. Hence the slightly thicker and heavier tubes, seamed construction and in Reynolds' opinion, inferior CrMo steel. 531 was aimed at higher models, though it could be found on mid-range models by using plain gauge tubes or combining a 531 butted main triangle with lesser grade stays and/or forks,
Wow. Thanks for the info. I learned something today.
www.theheadbadge.com
Quoted: 2422 Post(s)
Liked 4,395 Times
T-Mar, you sound like the fellow who could probably answer this question:
Is Raleigh's 555 tubing, as used on the post-'84 U.S.A. Competition model and a few others, equivilant to Reynolds 501, or 531? I've heard both as answers.
As it's marked "Double-Butted Tubes & Stays, All Tubes Cromoly" on the decal, I assume it's equal to 501, however, I thought I'd clarify with the expert.
P.S.: Is there any particular reason why a Columbus-tubing equipped Basso with Campy Victory components and Mafac G40s should weigh 2.5 pounds more (22.5 lbs) then a Raleigh U.S.A. Competition, with supposed Reynolds 501 frame, Suntour Cyclone & Sugino components, and Araya 700C 1W rims (20 lbs)? I also have what's sometimes considered a hefty saddle (in terms of weight), on the Competition - a Brooks Professional.
I have yet to figure this one out. Beats the heck out of me why Campy is such a big-to-do name, yet, a near-completely Japanese equipped Raleigh beats it in weight.
Take care,
-Kurt
Take care,
-Kurt
i think thats just a mystery. i have a 88 trek 1000 with 6061 aluminum that is heavier than a 1970 Raleigh International with 531.
and i like all these people going to target and buying a 200 dollar "aluminum" schwinn that ways more than a steel schwinn from the 70's and 60's that they can pick up for like 20-30 bucks!
Liked 3,036 Times
Kurt,
I've always suspected Raleigh 555 to be the equivalent of Reynolds 501 for the reasons you've stated and more (see my post https://www.bikeforums.net/showthread...ht=Raleigh+555 ), however I do not have any objective evidence to make a defintive statement that they are the same. Given that 531 is MnMo and 501 is CrMo, they can't be the same.
Regarding the weight disparity between the Basso and Competition, I need some more info. For instance, what is the tubeset on the Basso? Is there a frame size difference? And I'd need a complete list of the components. Even if the tubests are basically equivalent, there can be quite a difference due to the lugs, bottom bracket shell and other fittings selected by the framebuilder. The Canpagnolo Victory parts were not exactly lightweights. I would not be surprised if the major components on the Competition are substantially lighter. The derailleurs are definitely lighter! Also, people also forget to consider the difference in tires and tubes, which can add up to quite a bit.
Perhaps this is a good excuse to dis-assemble the bicycles for their overhaul? Keep the digital scale handy and log the weights of the individual components. That is the only way that you will know for sure. It can even be enjoyable.
Liked 4,395 Times
Originally Posted by T-Mar
Kurt,
Well, considering what we know about 555 and 501, I'd say that whatever the differences in the two tubesets are...it can't be too much. My Competition has 555SL, and is hellishly light, so I'm not complaining!
I won't bore you with all the fittings and such of each bike - although I do know the BB and dropouts on the Basso are from Basso - as for the variant of Columbus tubing on it, I couldn't tell you. I'll write it down sometime and do some internet searches on that particular tubeset.
Both the Basso and the Competition are 23" frames - my favorite size for riding.
Incedentally, I did take off the original Suntour Cyclone derailer in favor of a short-cage Shimano Light Action, which I mated to a pair of SIS 7-speed downtube shifters.
Tyres are another spot where the Competition probably comes in lighter - it's running cheap Kenda Kampaign 700X20Cs (which are so darn thin, they weigh nothing), while the Basso is running 700X25C Continental Sport 1000s.
Guess I answered my own question here.
Incedentally, I'm fixing up an old 24"-frame Nishiki Prestiege for rental. So happens that this frame is Tange 2, and the old Suntour Cyclone parts from the Competition seem to be finding themselves onto this bike, along with whatever very lightweight parts I can dig out of my parts bin to get it running. Even though it's running a pair of cheap 27" rims, I have a suspicion that it'll ultimately weigh around the same as the Competition...so long as I put a light chainwheel and BB on it.
Take care,
-Kurt
Liked 4,395 Times
-Kurt
Liked 3,036 Times
Liked 4,395 Times
I'm pretty sure the Basso's decal isn't marked SL.
Let me go down to the shed and check...
...Ok, I'm back.
Decal is gold with a blue outline, has the dove logo centered above the writing:
Left side of the decal reads:
"Tubi Speciali
Rinforzati"
(at least, that's what I can make out when comparing other Colubus decals, and what's LEFT of the one on my Basso)
...and on the right side in large letters:
"Tretubi"
(Which is probably Italian for Gaspipe Tubing)
And on the bottom, in the blue border, is, of course, "Columbus."
Take care,
-Kurt
...Ok, I'm back.
"Tubi Speciali
Rinforzati"
"Tretubi"
Take care,
-Kurt
Liked 3,036 Times
...Ok, I'm back.
"Tubi Speciali
Rinforzati"
"Tretubi"
Take care,
-Kurt
...Ok, I'm back.
"Tubi Speciali
Rinforzati"
"Tretubi"
Take care,
-Kurt
The other factor is that your frame size. At about 58-60cm most Italian builders started switching from Columbus SL to the heavier Columbus SP tubing. Your frame is at the transisition point and since the decal does not indicate SL or SP, the main triangle may be either, depending on the builder's preference. It may even be a combination, such as SL with an SP downtube, which was a popular solution for some extra rigidity without adding too much weight.
Señor Member
Quoted: 1491 Post(s)
Liked 1,090 Times
fwiw - I have a reference that shows (based on average weight - whatever that means), Reynolds 501 is 225 grams heavier than 531C, 325 grams heavier than 531P, 375 grams heavier than 753, and 95 grams heavier than SL. Unfortunately, my reference makes no mention of Raleigh 555.
Tretubi actually means that only the three main tubes are made of the Columbus tubing indicated by the sticker. Your Basso's sounds like it is comparable to my 1978 SuperCourse - which was made with Reynolds 531 (as opposed to Columbus) in the three main tubes.
Uff Da!
Quoted: 68 Post(s)
Liked 180 Times
Likes For Sierra:
Señor Member
Liked 1,090 Times
Originally Posted by Sierra
Doesn't the "Tubi Speciali Rinforzati" indicate that the tubes are butted? If I'm not mistaken I think the main tubes on the Super Course were straight guage 531.
The Drive Side is Within
Hey Y'all. This is the first thread that comes up in Google for "Reynolds 501" and also comes up for 555. I found some new info that doesn't seem to be on BF.
I have a Raleigh Alyeska on the way from ebay and I've been doing some research on "Raleigh 555" steel. AA,SHTA:
On the road sport spread from the '85 catalog:
"All our frames are built of Reynolds 753 double-butted Chromoly or Raleigh 555T Mangenese Molybdenum steel tubing."
https://sheldonbrown.com/retroraleigh...5/pages/1.html
So Raleigh 555 is Double Butted Mn Molybdenum, which certainly makes it different from 501's CrMo. Could it be re-branded 531? I've read it was only produced for sale in the US. Or could it be some kind of seamed MnMo? I'd guess the former. So my new Alyeska's tubing is a bit more like my Trek 620 than my Trek 520.
Now I'm going to go be annoying and cross post this info into the 555 threads.
The bicycle, the bicycle surely, should always be the vehicle of novelists and poets. Christopher Morley
Likes For Standalone:
The mystery deepens: another page on the same catalog contradicts, and says CrMo:
https://sheldonbrown.com/retroraleigh...gh-kodiak.html
Says Cr-mo. Dang, and here I thought I was on to something... but which is right??
Quoted: 28 Post(s)
Liked 60 Times
Renyolds 753 is definitly Mangenese Molybdenum, I would guess that in the $40K bike add they just just messed up and switched the tubeset metalugy descriptions. Remember that during the 80's, Raleigh USA was actually owned by Huffy when they licesned the rights to sell bikes in USA under that name from the original Birmingham company. The 555 tubing was probably just Huffys attempt to keep cost down in comparison to using a name-brand tubing supplier (like renyolds). For a touring bike, a bit heavier & stiffer frame is a good thing! A noodly 753 touring bike would be a disaster for carrying any sort of load.
Extraordinary Magnitude
Quoted: 2608 Post(s)
Liked 1,703 Times
So where does Tange Mangaloy 2001 fit into the mix?
I've heard it referred to as 'reclaimed trash metal' on one hand and "pretty good stuff" on the other.
I had a Trek 420 with the Mangaloy frame- it was a great riding bike.
Commence to jigglin’ huh?!?!
My 86 Blue Ridge frame has the regular Columbus decal on the seatpost tube, but also has the dove on the top of the chrome seat stays on each side and the word Columbus on the chrome fork crown, each side... and the same decal on the fork sides, I'm assuming it's a butted all Columbus SL tube frame.
Liked 4,395 Times
Only 555RSL was magmoly, for it was rebadged 531.
555SL and 555T are cromoly, and I'm pretty sure we've established it's seamed too. Even though the catalog made a mistake, the tubing decals were executed correctly:
Also note the slight variance in the decal on the Taiwanese-built frame.
-Kurt
-Kurt
Likes For cudak888:
Wrench Savant
Liked 4,395 Times
Liked 4,395 Times
Bikes: '02 Litespeed, '99 Bianchi Alfana. '91 Fuji Saratoga, '84 Peugeot Canyon Express, '82 Moto GR, '81 Fuji America, '81 Fuji Royale; '78 Bridgestone Diamond Touring, '76 Fuji America, plus many more!
Quoted: 181 Post(s)
Liked 224 Times
My '84 Raleigh Touring 18 (basicly an older version of the "Alyeska"..similar to the way the '85 Schwinn Le Tour Luxe became the '86 Passage) has Raleigh 555T tubing that is labeled chrome molybdenum. If it's Reynolds tubing...I'm a "happy camper". I'm still OK with Tange. Didn't think much of Huffy until I got this bike...very nice indeed...didn't know they had it in them. This Raleigh/Reynolds thing reminds me of Schwinn using Columbus tubing rebranded as Tenax, and about the same time as the Raleigh rebranding in the '80s.
