Tubeless tire with hand pump?
The Idler
Bikes: Tour Easy/Mukluk
Quoted: 16 Post(s)
I was looking at getting a surly karate monkey that has tubeless maxxis tires. I'm heading down to Mexico to some very remote areas. I did some reading and saw that you need a air compressor to remount tubeless tires after a flat, is this the case? I plan on just having a patch kit and hand pump like usual. I also read tubeless tires can be patched with the automotive style plugs that look like licorice sticks? If I plugged it that way I'd avoid taking the tire off and could just pump it with a regular hand pump? It's a bike off Craigslist, i might pass it up, I'm not sure tubeless would be a good idea in Mexico. I know the small towns I'll be in won't have tubeless tires in the bike shops.
Bikes: Road Bike, Mountain Bike, Commuter Bike, Gravel bike
Quoted: 19 Post(s)
Since no one else has responded...if you have to break the bead it’d be a nightmare re-seating a tubeless Mtn bike tire with a hand pump. I can barely do it with a floor pump. You need a BIG shot of air to make it catch the rim and hook up so you can inflate. The plug kits work. Tubeless tires rarely flat though. You might want to ask on the touring forum of those guys would run tubeless in the kind of places you’re going o.
May or may not be able to inflate.
Might need to carry a bottle of tube sealant too.
If you Go with tubeless
Just
Carry a couple tubes
Just
No expert, but apparently if you wrap/build up a few layers of rim tape when initially setting up your rims tubeless, those layers of tape raise the seat which the tyre bead sits on, making it less effort to get the tire bead in good position to hand pump from.
However, I've only one wrap on my setups. I put a tube in, then inflate with the hand pump until I hear both beads 'pop'. The carefully push in one side of the tyre, releasing the bead. Remove the tube. Get the one side of the tyre back in the well, then carefully lift the edges up into the edge of the rim.
This is usually enough to get enough of an air seal for me to then pump up the tubeless tyre by hand.
If I see the tyre is not inflating/there's air getting out one side of the tyre, then I grab half-a-dozen clothes pegs (which weigh nothing) to grab the sidewalls/keep the bead up against the rim. When I then inflate the tyre, the clothespegs jump off.
Another option -similar to the clothes pegs- is to wrap a length of string/wire around the tyre circumference. Wrap it over close to the side of the loose bead, restricting the possibility for air to escape. Pump up the tire.
Good tools for when you're out in the sticks.
Quoted: 136 Post(s)
Liked 57 Times
My friend has a 12v compressor he uses in his car. It has a small tank, unlike the cheap ones for inflating sleeping mats, car tires. The tank provides the burst needed to seat a bead. There are also a few hand pumps with a reservoir that does the same thing.
Quoted: 175 Post(s)
If you ride tubeless, you take a tube with you and use it if you get a flat. Then when you are back home you try to fix the tire and reseat it. Some times you may be able to field fix a flat if you didn't unseat the tire. But most often, you just put a tube in it.
If you are dead-set on trying to field seat tubeless tires CO2 cartridges (The big ones) are your best option.
Quoted: 136 Post(s)
Liked 57 Times
I've seen floor pumps with a tank to seat tubeless tires -I actually own the Bontrager one. But never a handump.
Quoted: 13 Post(s)
I run tubeless in my mountain bikes. To seat a new tubeless setup it is best to use a compressor because you need a quit burst of air to almost seat the bead and then let it fill up and totally seat. It is almost or totally impossible with a normal handpump because the air just keeps leaking out so you cannot seat it.
I have hardly ever had any serious flats out on the trail other than like burp flats and then I just fill it back up. But I always, always carry tubes with me in case of a true flat. Just throw in a tube and pump it up and make it back home and then re-setup your tubeless setup.
Quoted: 590 Post(s)
Liked 445 Times
Search for "ghetto tubeless inflator"
Bikes: Vivente Deccan XXXL Slightly modified
Quoted: 116 Post(s)
Hope that helps and I hope you have a good time. You're wise to go off the beaten track as the main routes are very heavily traveled and noisy/dangerous with speed bumps and giant potholes everywhere.
Advanced Slacker
Quoted: 2761 Post(s)
Liked 2,534 Times
Not really on the market yet, this is a kickstarter webpage, but looks like the answer. https://www.kickstarter.com/projects...beless-booster
pbass
Bicycle Mechanics
16
11-05-18 09:29 PM
Barrettscv
10
01-14-17 11:23 AM
