Wout Van Art Rode Rim Brakes
Quoted: 741 Post(s)
Liked 412 Times
In Strada Bianchi. Certainly a rider who knows the advantages of disc brakes did not use them and placed third. Brake choice, at least at the UCI pro level, is not as simple as these many discussions here would imply. Julian Anaphilpe won on discs. Honestly, Julian was riding so strong, brakes and bike brand did not matter. He would have won on any setup.
Quoted: 4806 Post(s)
Liked 3,933 Times
Ben
Quoted: 18883 Post(s)
Liked 10,646 Times
Disc brakes work the way I want my bike's brakes to work. Whatever other cyclists ride doesn't change that.
Quoted: 741 Post(s)
Liked 412 Times
They get paid to ride the bikes provided by their sponsors. Very few of the top pros get much choice here. (Yes, they can speak up in private to their managers and mechanics, but come race day, they suit up, ride the bikes they've been given and say good things about them after the race if they are interviewed.) I wouldn't read too much into this.
Ben
Ben
https://www.cyclingweekly.com/news/p...s-guide-152997
Quoted: 18382 Post(s)
Liked 4,513 Times
I was watching some of the Omloop Het Nieuwsblad (Men's & Women's). It looks like the riders are on a mix of Disc & rim brakes.
The wheel change is apparently quicker for rim brakes if they should choose to change wheels rather than swapping bikes.
Quoted: 65 Post(s)
Liked 60 Times
If you were to put accelerometers on the bikes and strain gages on the brake levers to monitor braking force, I guarantee no rider would come close to 100% except in a crash. Even on a closed course criterium with slow speed corners. Cyclist simply do not ride the same way as racecar driver or motorcyclists would around a track. Cyclist prefer longer gradual braking than short maximum braking. In reality, it didn't really matter which brakes you have if you never use the full capabilities.
The one exception would be carbon rims in the wet where discs are more consistent.
NYC
Quoted: 1169 Post(s)
Liked 107 Times
Serious Cyclist
Bikes: Emonda SL6
Quoted: 5721 Post(s)
Liked 261 Times
Quoted: 65 Post(s)
Liked 60 Times
If there is someone that brakes that hard, corner after corner, I would like to see a video of that.
Why is this such a touchy subject anyway? Disc brakes are great, but rim brakes definitely have their place as well.
Ben
Ben
- Often, some riders of a certain team for a certain race will be on disc brakes, while others are on rim brakes.
- Some will ride a mechanical groupset while others ride Etap or Di2. (Contador preferred mechanical)
- Some will ride 50mm deep wheels, others 30mm, etc.
- Obviously they get a choice of width of handlebars, length of stem, length of crankset, etc. etc.
And when it comes to personal fit choices, it goes even further: it is common for riders to ride a brand of saddle that is NOT their sponsor. In that case they will take off the logos. This is because the rider comfort goes above all else.
NYC
Liked 107 Times
Nope, nowhere near the maximum. You have to look at the kinematics involved in braking. As you decelerate, your high center of gravity will pivot about the front contact patch. As the weight transfers forward, your rear brakes lose its effectiveness as the normal force reaches zero in the friction equation. If you continue to increase the rate of deceleration your rear wheel will just come off the ground. That's the point where you reached maximum braking force when the rider is the limitation. On low grip surfaces, the front wheel will skid first.
Liked 10,646 Times
Hydraulic discs aren't about stopping power. They're about modulation, consistency in all weather, rim longevity for some people, lever force for some people, and just feel too for some people.
From a service perspective I love disc brakes. Flush and bleed at least every 2 years means more service business. Warped rotors mean more service business. Replacing cheap stock rotors with good rotors means more service business. Lost pads mean more service business. Seriously, they are better for the service department.
FLIR Kitten to 0.05C
Quoted: 2349 Post(s)
Liked 406 Times
Any who lift rear wheel on level ground are simply sitting too high and too forward. Standard configuration of a bicycle puts center of gravity where it is not possible to exit over handlebars. Were this not so bicycles would be too dangerous to use. Of course many will set up their bikes to make them dangerous.
You have it correct that limit on braking power is braking traction. Same for discs and rim brakes. Many simply prefer the feel of discs. Even if it is demonstrated to them that their wonderful super duper discs stop not one bit shorter than the guy next to them on rim brakes they still like the feel of discs.
