My first roadie, Trek Domane
Old 09-25-18, 01:05 PM
SkepTeach
Quoted: 12 Post(s)
Liked 13 Times in 6 Posts
Happy to join the roadie community! I've been a cyclist off and on but had almost no experience with road bikes. I decided it was time and struck a (what I consider) great deal with my local bike shop on a 2018 Trek Domane SL8 Disc they could order for me. The bike came in 4 days after ordering, and I've had it now for almost two weeks.
I've ridden it for maybe 75-80 miles so far and I love it. I'm not comfy with cleats yet so I put on hybrid pedals with flats on one side and clips on the other. They aren't great, but I think they'll make it convenient whenever I do get cleats, I'll be able to ride regardless of the shoes I happen to have available.
One thing I am finding unexpected, despite buying padded bike shorts, is the...uhh....chafing. I have been having to lotion that area just about nightly and am about to test out some chamois cream the bike shop gave me. Guess that result never crossed my mind.
Anyway, I'm loving Obsidian! I know it's ridiculous to name a bike, but I figure if I'm going to spend this much on it and ride it this often, I might as well. I'm a biology teacher at nearby high school and usually go biking from the school most afternoons when the weather is decent. I just try to sneak out the back of the building with my spandex shorts without any lingering kids seeing me...ha! I'm actually hoping to help start a faculty bike club and get some of my colleagues to go on rides once a month or so.
SkepTeach is offline
Old 09-25-18, 01:37 PM
dennis336
Bikes: Trek Domane, Surly Disc Trucker
Quoted: 170 Post(s)
Liked 103 Times in 68 Posts
Congrats on the new Domane! Hope you get lots of miles and years of good riding (well, until n+1). I'm in my third season with my Domane and love it!
dennis336 is offline
Old 09-25-18, 02:02 PM
Steve B.
Quoted: 3242 Post(s)
Liked 2,087 Times in 1,182 Posts
Angle on the sea looks like the nose is tipped down. Put a level on it and then ride for a while.
Good shorts a must, but likely the cause of your chafing is your butt needs to get broken in to saddle time. A good lubricant is Glide, a persistent anti-chafing ointment used by triathletes, apply before the ride.
Very nice bike, as BTW. Somebody gave you good advice. I lust after the SL7 with Di2.
Steve B. is offline
Old 09-25-18, 02:04 PM
SkepTeach
Quoted: 12 Post(s)
Good shorts a must, but likely the cause of your chafing is your butt needs to get broken in to saddle time. A good lubricant is Glide, a persistent anti-chafing ointment used by triathletes.
Thank you for the advice! I'll check the angle this afternoon. Sorry for the totally noob question, but do you suggest the saddle be perfectly level?
Old 09-25-18, 02:08 PM
Campag4life
Voice of the Industry
Campag4life's Avatar
Quoted: 1188 Post(s)
Liked 8 Times in 8 Posts
Handsome bike. Lots of love for the Domane on this forum.
Congrats.
Campag4life is offline
Old 09-25-18, 02:16 PM
Steve B.
It’s a trial and error process, but level is the starting point. Nose down tends to drive upper body weight onto your hands and arms. That’s tiring. You want to find a balanced position with some of the weight on the bar but be able to ride with your elbows slightly bent, which helps absorb shock and reduces your upper body movement input to the bike handling. A buddy rides with elbows locked and tends to weave a bit due to the pedaling motion getting induced thru his upper body.
I’d maybe have the shop stick you on the bike, on a trainer and have them look at your position. They should have experience fitting riders and can suggest improvements.
Steve B. is offline
Old 09-25-18, 03:09 PM
rubiksoval
Bikes: bikes
Quoted: 2622 Post(s)
Liked 1,429 Times in 711 Posts
Nothing wrong with that.
rubiksoval is offline
rubiksoval
Bikes: bikes
That's how it used to be. Now common sense is beginning to prevail a lot more and comfort is the key.
Mine's angled down a bit, too.
Old 09-25-18, 03:27 PM
ptempel
Bikes: 2007 Ridley Excalibur, 2003 Orbea Orca, 199? Cannondale Headshock MTB hardtail
Quoted: 520 Post(s)
Liked 10 Times in 10 Posts
I also angle my saddle down just a little. Never would have known if I didn’t have a bubble level on it last time before removing it. Having said that, I would recommend you do your own minor adjustments to see what works for you. I would also recommend a good bike fit. They should look at your flexibility, pedal stroke and position. Many might charge over $100 for it. But its money well spent to help guide you toward the best position for you.
ptempel is offline
Old 09-25-18, 03:28 PM
Steve B.
Maybe for a newbie it’s not a good starting point.
Good article here
https://roadcyclinguk.com/how-to/tec...gle-road-bike/
Steve B. is offline
Old 09-25-18, 03:56 PM
rubiksoval
Bikes: bikes
So it's only good if you've been riding for a while? That doesn't make sense.
This goes back to the archaic "fit advice" of yesteryear. Get your knee over the pedal spindle, make sure the front hub is hidden by the handlebars, level seat, blah blah.
Bunch of silliness. Might work for some people. Just as likely won't work for others.
Old 09-25-18, 05:22 PM
Steve B.
As opposed to what ?. Pretty much everything you mention are generalizations as to what *most* people find works for them and as such are just starting points. Nothing much has changed in road bike fit over 30 years or, excepting a trend to a higher handle bar relative to the seat, thus all you’ve mentioned are still valid STARTING POINTS. Nobody’s recommending that the OP not change the saddle tilt, just that nose down can cause issues as noted. Might end up not causing issues, but what the OP really needs is to have the shop look at how he/she sits on the bike.
Just curious if your saddle nose nose is tipped down ?
Steve B. is offline
Old 09-25-18, 05:30 PM
rubiksoval
Bikes: bikes
You're suggesting a solution based off a photo when no problem has been reported.
Yes, my saddle nose is tipped down. It's a tremendous improvement for my position.
Old 09-25-18, 05:41 PM
Campag4life
For every rule or convention there is a counterpoint but 'saddle level' paradigm exists for reason. But...contrast a trend for example in pro cycling which is really extreme aero fit...saddle forward, handlebar slammed...very light rider and big pedal force unweighting the rider. This is tolerable nose down and promotes more pelvis rotation forward which affords greater torso rotation and more aero position and why pros do it...some, not all.
As a guy who helps people with their fit I can tell you, one size doesn't fit all. But it somewhat follows not only rider strength or power to weight but also handlebar height relative to the saddle. Too low a handlebar relative too level or nose up saddle will typically promote unwanted perineal pressure.
In the case of this rider with bike shown which looks to be almost a French fit with saddle equivalent height to handlebar...what many choose with a Domane depending on frame sizing relative to body size, I would generally agree with you, I would start with a more level saddle, what you suggest.
But, many riders choose to not precisely adhere to convention. I will tell in the drops I sometimes think about a more nose down saddle. Saddle shape and perineal load distribution is another factor which affects tilt.
If you don't know this fitter on youtube, he is one of the smartest guys on the web about fit and worth a look:
Old 09-25-18, 05:59 PM
voyager1
voyager1's Avatar
Bikes: 2018 Trek Domane SL5
Quoted: 81 Post(s)
Liked 5 Times in 5 Posts
Nice looking bike!
voyager1 is offline
Old 09-25-18, 09:02 PM
colnago62
Quoted: 741 Post(s)
Liked 412 Times in 230 Posts
I teach music for a living. When starting students on instruments, I always start with what has worked for the majority of players. From that point, adjustments can be made to a position that might make better sense for that person. Starting with what works for most usually means the adjustments, if any, will hopefully be slight.
colnago62 is offline
Old 09-25-18, 09:25 PM
GailT
Quoted: 107 Post(s)
Liked 22 Times in 14 Posts
A problem has been reported. Chaffing.
GailT is offline
Old 09-25-18, 10:16 PM
wingless
wingless's Avatar
Bikes: 2011 Trek 1.2 + 2016 Trek 1.1 H2
Quoted: 132 Post(s)
Liked 20 Times in 16 Posts
Wow the 2018 Trek Domane SL8 Disc is an amazing bicycle.
Enjoy your new ride.
+1 on letting the saddle break in your butt.
wingless is offline
Old 09-25-18, 10:48 PM
carlton
Bikes: canondale silk trail--92 schwinn criss cross--sun atlas x type--fugi odessa--2018 trek domane ALR5 disc
Quoted: 47 Post(s)
Nice bike. I love my Domane. Not as fancy as yours. I went through the same problems with shorts as you. Best advice on padded shorts I found was here. htthttps://www.pearlizumi.com/US/en/Pearl_Izumi_Chamoisps://www.pearlizumi.com/US/en/Pearl_Izumi_Chamois Chamois school 101, 201,301.
Followed their guidelines and have had zero problems since. BTW they recommend no cream with their chamois.
carlton is offline
Old 09-26-18, 04:12 AM
jpescatore
Bikes: Trek Domane SL6 Disc, Jamis Renegade
Quoted: 365 Post(s)
Liked 305 Times in 217 Posts
Almost two seasons and over 4000 miles in on my Domane SL6 and loving it. Give it some more miles and see if your butt just gets used to it definitely makes the most sense.
My bike came with a discounted fitting session, using the Retul system. I had always tilted my bike seats down and the recommendation for me was to go level, along with moving my cleats back in my shoes and raising the seat more than .5 inches - all changes in what I thought had been working fine for the previous 40 years or so (no chafing problems.) Those changes made immediate noticeable improvements, though I at first thought it was psychological... But, I changed the seat angle and height on my previous bike (Trek 520) and it felt better there, too -
Seat tilting: that seemed to work for me early on in my biking career but over the years I have moved to more narrow seats, with less padding and more cutouts. Compared to when I first did the tilting, there is less material in the nose of the saddle to press on anything sensitive and the tilting definitely puts more pressure on my arms and changes leg angles a tiny bit. With the more narrow saddles I use now, I don't think tilting has any advantage.
So, I'm now a believer in professional fitting.
jpescatore is offline
Old 09-26-18, 07:39 AM
drewguy
Bikes: Trek Domane 4.3
Quoted: 193 Post(s)
Liked 50 Times in 35 Posts
Agree, although another thing to consider is whether the (I assume stock) saddle is the right one for you. My experience with Trek is they don't exactly include the best saddles on their bikes, as they (rightly) figure most people will swap it out for something that actually works for them (kind of like pedals). See if your bike shop has some demo saddles you can try - maybe those will chafe less.
drewguy is offline
Old 09-26-18, 07:47 AM
Pizzaiolo Americano
Pizzaiolo Americano
Bikes: 2021 Trek Domane, Bianchi Intenso, Specialized Epic Evo, Surly Ice Cream Truck, Some other stuff
Quoted: 287 Post(s)
Liked 140 Times in 69 Posts
The saddle that came on my 19 Domane SL6 was not good...The low cost Montrose on my Emonda was way better. I just put a Selle Italia SLR on the Domane. It fits me well.
Pizzaiolo Americano is offline
Old 09-26-18, 08:24 AM
DomaneS5
Fredly Fredster
DomaneS5's Avatar
Bikes: Trek Domane S5, Trek 1.1c, Motobecane Omni Strada Comp, Trek X-Caliber 6
Quoted: 207 Post(s)
Liked 18 Times in 14 Posts
That's a great looking Domane. I'm in my 3rd year with a much cheaper version of the Domane... the S5 with 105 components. I was skeptical at first by spending over $2K on a bike, but now after many miles it's been worth every dime I paid for it. Domanes are like wine and get better with age. I like mine better now than I did when it was new.
DomaneS5 is offline
Old 09-26-18, 08:28 AM
WhyFi
WhyFi's Avatar
Quoted: 20810 Post(s)
Way to do it up right for the first roadie. Now get rid of those warning stickers and ride the hell out of it.
WhyFi is offline
Old 09-26-18, 11:19 AM
Adonis72
Quoted: 11 Post(s)
Liked 8 Times in 6 Posts
Nice choice! I love my domane!
Adonis72 is offline
