Advice on sew-ups needed
Quoted: 33 Post(s)
Liked 7 Times
I haven’t ridden sew-ups for decades but my ’73 Raleigh Pro is nearing completion and I am finding myself in unfamiliar territory.
Reducing rolling resistance: it is my understanding that narrow high pressure has given way to wider lower pressure. Does this apply to tubulars as well?
Some concerns would be the fit on the rim (Super Champion record du monde, ≈20mm), resistance to rolling off the rim and puncture resistance.
Of course my favorite cement, Clement, is no longer available. The only available brand that I remember from my past is Tubasti, which I did not like so much. Opinions are welcome.
On to the tires themselves. The “Servizio Corse” from Yellow Jersey sound too good to be true at $20. Has anyone tried them? I would love not spending $200 on tires I might end up throwing away. In my stronger but poorer days I did get fairly adept at fixing flats but now I do not particularly want to renew that skill.
I should add that at 72 and +200 lbs. I will be doing little more than slow-rolling for an hour or two.
PS. No, I am not going to put clinchers on the Pro.
Quoted: 1829 Post(s)
Liked 3,377 Times
Steve in Peoria
Bikes: 57 ExpressWerke, 58 CinelliB, 62 CinelliB Altenberger, 70 Cinelli SC, 76 Masi, 77 Colin Laing, 78 Ritchey, 80 Jack Taylor, 82 Appel, 82 Davidson, 85 Ironman, 92? Andy Gilmour, 04 Peter Johnson, 91 Ed Litton, 11 Bianchi
Quoted: 96 Post(s)
Liked 451 Times
Here is another choice for tubulars. Note the font size of the branding.
https://gammisport.com/collections/tires
Likes For cinelliguy:
Glad to hear you want to use tubulars on your Pro. I am a big fan of them as well.
As to glue, I have had good luck with Vittoria Mastik. When I started out on tubulars, I used the Vittoria Rally. Even that felt like a revelation at the time. Then I tried others, like the Continental Sprinters. They seemed to last longer but did not have the same lively feel. Many here have tried the Servizio Corse and can comment on those. Others that come to mind are the Vittoria Corsas and Veloflex. I have been sitting on some Dugast silks in 27mm that might be too nice for my purposes. I will let others answer about rolling resistance . Check out the "Totally Tubular" sticky at the top of the C&V home page for more information.
How wide of a tire will fit on your Pro? If you can do a 28mm, I had some Bontrager R4s that were not bad. I wanted a tan-walled tire with unobtrusive graphics (see below). I did not put too many miles on them before I sold them with the bike, so can't comment on puncture resistance or longevity, but they seemed to do the trick. They are $50/each on ebay.
Quoted: 3015 Post(s)
Liked 3,804 Times
Unless you are willing to spend more money, I don't see much point to tubulars over clinchers.
I run 34mm Dugasts at 50 psi on modern and vintage rims, width is irrelevant and I have no issues. While tape costs more, it is easier than glue in every sense. Yellow Jersey tires are pure crap and good as spares only. Again, if you aren't willing to spend more, clinchers are the way to go.
Quoted: 1952 Post(s)
Liked 2,013 Times
Get some tubes of continental glue and three 22mm Continental Sprinters. You are only riding an hour or two. Fat tires might be faster on modern bikes but on a Raleigh Pro, 28mm Tubulars are slow😁
Likes For Classtime:
Likes For shopco43:
Quoted: 33 Post(s)
Liked 7 Times
"Unless you are willing to spend more money, I don't see much point to tubulars over clinchers.
I run 34mm Dugasts at 50 psi on modern and vintage rims, width is irrelevant and I have no issues. While tape costs more, it is easier than glue in every sense. Yellow Jersey tires are pure crap and good as spares only. Again, if you aren't willing to spend more, clinchers are the way to go"
I had hoped to avoid the morass that is that subject but I guess that was just wishful thinking.
Wheelman
Bikes: 1982 Holdsworth Avanti (531), 1961 Holdsworth Cyclone
Quoted: 298 Post(s)
Liked 676 Times
I'm new to tubulars, but I got my first set 3 months back: Tufo S33 Pro 24mm
And the red stripe version was Ł18 at Wiggle.
Fitted them to Mavic Monthlery Route (22mm) using Tufo Tape and had no problems so far (about 200 miles).
Currently I quite like tubulars.
Liked 3,804 Times
Bikes: 86' Centurion Ironman
Quoted: 628 Post(s)
Liked 316 Times
Continental Giro 700c X 22mm even a little more budget minded and if you want tan wall that is how they come . 145psi if you want , I run mine about 90psi .
Quoted: 1641 Post(s)
Liked 831 Times
Lowest rolling resistance modern tubular tires for the money I had used so far are the Vittoria Corsa G "Graphene" tires.
Definitely much faster than the mid and upper level Michelin, Continental, Veloflex and Schwalbe tubulars I had been also using in the last few years.
They are about upper mid priced, but definitely, definitely worth the extra money, and they come in tan skinwalls too, which is a plus for C&V bike apllications.
Even in narrower 23mm width, which I have on my bikes, they feel really compliant, and comfortable. It should even feel better in wider sizes.
If you want significant enough performance improvements when switching from clinchers to tubulars, try not to bother with the bargain basement models like the Vittoria Rallies or the Continintal Giros, as their quality leaves a lot to be desired with lumpy base tapes, seams and misaligned treads, most of the time..... pretty much a waste of money, unless you just use them as emergency spares....
I find Continental's tubular tire glue to be easiest to use, as it has good consistency for easy spreading on rims and tires.
I tried Vittoria's Mastik when I could not find the Continental glue and I found it a bit too thick and harder to manage.
It's MY mountain
Bikes: Klein, Merckx, Trek
Quoted: 4338 Post(s)
Liked 2,981 Times
I run 34mm Dugasts at 50 psi on modern and vintage rims, width is irrelevant and I have no issues. While tape costs more, it is easier than glue in every sense. Again, if you aren't willing to spend more, clinchers are the way to go.
@shopco43
I've got 28mm Vittorias on my Eddy Merckx and they make riding a vintage bike lots more fun.
Continental cement, because my LBS has it and it works.
If 28s or 30s will fit your frame, you will enjoy them... they will certainly fit your 20mm rims - wider rims for wide tubulars MIGHT be a little more aero, no biggie.
You probably want high thread count, latex tubes, about 80 psi, and medium flat protection maybe adding sealant.
And look at the "Totally Tubular" thread in the stickies for every pro-and-con ever discussed.
Likes For DiabloScott:
Quoted: 2333 Post(s)
Liked 2,097 Times
Vittoria Corsa G+ or Veloflex Protour gumwall
Quoted: 1372 Post(s)
Liked 1,752 Times
After trying sew-ups. I totally agree with this. I do have one bike left, fitted with sew-ups but I ride it rarely and only on the best of roads. Sew-up flats are just TOO expensive to replace, in my opinion.
Liked 2,097 Times
Flats. Try removing the valve core and putting some sealant in. Pump up a bit and see if the sealant works.
Likes For GhostRider62:
Bikes: 1975 Motobecane LeChampion (silver lilac), 1974 Motobecane Grand Jubile (red/black); 1975 Motobecane Team Champion (orange); 1982 Pinarello Professional (Exorcist Green); 1974 Raleigh Professional MkIV mink blue, 1974 Motobecane Grand Record blk/red
Quoted: 103 Post(s)
Liked 750 Times
I only ride sewups, based on the ride quality as well as historical preference (old guy here)... I really like the Yellow Jersey tires, they seem to work well for me. I have had great luck with the Challenge Elite tires, which seem like they are high quality. I used to ride Continental Giro, but these tend to have a lot of irregularities in base tape and can be lumpy. The main drawback to the Giro is the valve stem core is fixed, so you cannot add sealant easily. The Yellow Jersey and Challenge (available in a variety of widths) do have removable valve cores. I add sealant to mine, and in fact this has actually repaired small punctures from thorns. I have found tubulars to be long lasting.
Thanks,
Andy
Arvada CO
Thanks,
Andy
Arvada CO
Old fart
Quoted: 3590 Post(s)
Liked 3,401 Times
I would love not spending $200 on tires I might end up throwing away. In my stronger but poorer days I did get fairly adept at fixing flats but now I do not particularly want to renew that skill.[/quote]
I put sealant in them. It works well for most punctures.
Freewheel Medic
Quoted: 1453 Post(s)
Liked 2,196 Times
I recently installed Vittoria Rallys (because they were all I had on hand and Mrs. PB had put a hold on bike spending) on my Lotus. While cheap and often panned, I was very pleased. I used Effetto Mariposa Carogna Double Sided Tubular Gluing Tape, so easy and no mess. They look good as well.
Bob
Bob
Likes For pastorbobnlnh:
Rolling resistance: a vastly over-thought subject. First, high pressure tires have the lowest rolling resistance, except on very rough surfaces. Narrow tires and rims are more aero, and they are inherently lighter. Regardless, the difference between the very fastest clinchers and tubulars (both with latex tubes) is probably immeasurable.
For me, low rotational weight wins. I'm drafting someone 90% of the time, so aero doesn't matter. But when the fast guys decide to accelerate hard out of a corner, or try and shed folks off of the back during a short hill, that is when you need the lowest rotation mass and the lightest bike. Disc brakes for the fail here.... Sometimes a 3 foot gap at the end of a 1/4 mile grind is the difference between recovering at the back of the pack, or suffering solo into the wind for many miles.
Liked 3,377 Times
I might be the only person who has a bike fitted with tubulars just for the nostalgia factor. I don't get that many flats on tubulars, but I sorta enjoy the excuse to work on my sew-up repairs skills. I've got a Velox repair kit with plenty of thread and patches, so I might as well use it. The big disadvantage is just the time required to perform the repair. If you don't view it as an opportunity to work on a skill, sealant might be a better option.
Or maybe tubulars are just a way to relive a bit of my youth?? I can't imagine I'd be doing it if it was a new skill set that I had to pick up. That probably applies to riding a bike with a 5 speed freewheel too, I suppose.
Steve in Peoria
South Carolina Ed
Bikes: Holdsworth custom, Macario Pro, Ciocc San Cristobal, Viner Nemo, Cyfac Le Mythique, Giant TCR, Tommasso Mondial, Cyfac Etoile
Quoted: 344 Post(s)
Liked 291 Times
Another vote for the Yellow Jerseys, though the Bontrager R4s mentioned above look interesting because of the puncture protection.
Quoted: 4806 Post(s)
Liked 3,932 Times
I'm going back to tubulars when my current clinchers and rims wear out. Reason? 10 years ago I had a clincher come off at ~25 mph. I was riding on the rim, like riding on ice, and trying to stay off the outside curb. I was succeeding; holding the bars lightly ice-style when the tire came off and jammed in the seatstay. The ensuing crash was nightmare. To this day I cannot block it out on fast descents. By contrast, I blew out tubulars at least once in my racing days at 45+. Coming to a stop was so uneventful I cannot remember the wheel (or the number of times it happened).
Also I have a bike that needs the ride. A bike that is basically a 1989 high end racer. Open Pro rims and Corsa G+ tires are nice but no more that training wheels. Quality sewup wheels and G+ tubulars? I haven't ridden that yet but those silks I used to race were magic carpets. This bike deserves that carpet ride.
Quoted: 2326 Post(s)
Liked 4,995 Times
Well, even though I mainly run clincher on all my bikes I do have around 1/2 running modern tubulars. I usually go now with Veloflex branded tubulars bought cheaper from one of the UK sites. I've yet to experience a flat on any of them. I don't prep them with sealant when I install but my "flat plan" involves carrying sealent and Co2 (as well as my normal frame pump) just in case.
I've used EFFETTO MARIPOSA CAROGNA TUB TAPE on some of the rims and Mastik One glue on the others. I prefer the tape to be honest. It's so fast, holds well and allows me to get a tire on perfectly positioned. The downside to tape may be removing a flat tire on the road if I have to. That said. I've about to tape up another set of brand new rims this week.
I don't normally experience many flats whether clincher or tubular so that experience makes me more comfortable about using tape over glue.
If there's not a real rush, the Veloflex tubulars seem to go on sale at Merlin or PBK pretty often so if you can catch a sell you'll get some really nice riding tubulars at an great price.
Modern Veloflex Roubaix tubulars on some 1981 Arc En Ceil rims. The ride on the road is magnificent.
Steel is real...and comfy.
Likes For jamesdak:
Quoted: 1609 Post(s)
Liked 2,216 Times
I ran the 3/50 on my Colnago. They were a step up from the clinchers.
Now that I have run a couple of other higher priced tubies, I am sold on the value they bring. Thread count being one of the significant criteria for selection. My favorite right now are the Vittoria G+ in 23. I was sold with the clincher version on the Pinarello. It is being upgraded to Challenger Roubaix. The De Rosa has the G+ on it and the clincher version will likely go on the Bottecchia or Langster. I am converting the fleet over to sew-ups.
P1030570 on Flickr
P1030570 on Flickr
