Crashed my BMC ALR01 2019
Hello all,
Have very recently got in to road cycling and love it! (2 months) however have had a silly fall and wanted to know if my left shifter can be fixed or it has to be replaced. As I fell the left shifter took most of the brunt and has angled inwards slightly. No other damage to handlebars.
The groupset set is Shimano 105 R7000 and am not quite sure if a new lever is required?
image attached.
image attached.
Does it still work? If so loosen of the clamp, turn it straight, tighten the clamp. and go riding.
go to google and search for a drawing of the shifter, schematic type one, and you will see where the tightening bolt is and how to access it.
If you aren't interested in the mechanical stuff and or dont have long hex keys, get thee to a nunnery and a bike shop.
If your bars are carbon, if you do the loosening and tightening yourself, inform yourself about the torque suggestions, to avoid any "crunch" boo-boos going on.
Quoted: 1438 Post(s)
Liked 1,092 Times
I would suggest not tightening them too much. I set mine up "race tight"; tight enough to stay put under normal operation but loose enough to move with firm hand pressure so as to (hopefully) twist around the bar rather than breaking during an incident..
Someone smarter than me on here suggested this once and I remembered it when I set up a drop bar bike a few years back. Had a slow speed accident with it, but being loaded up touring, it puts more force on stuff when a bike goes down, and so while the hood got moved over, I was able to bang it back with my hand, and was glad it wasnt super tight, as being able to move certainly puts less force into the hood than if its on super super tight.
Liked 1,092 Times
absolutely.
I personally want tighter than just a firm grip to move them, but I figure the main thing is that they rotate with a good whack. I sprint for lights and stuff, so don't want them to move under any of those situations.
