Bontrager Race Light hardcase - This is weird
Picture of what happened to my rear Bontrager Race Light hardcase 700x32mm tire after only 1600 miles. I thought it strange and wondered if anyone else has seen this?
Bikes: Lemond Chambery/Cannondale R-900/Trek 8000 MTB/Burley Duet tandem
Not hardcase but Racelights. Matter of fact, every Bonti I've riddine has blown or split.
Stock Bonti's on my Lemond blew the sidewall nearly after 1000 miles. Second one went about 2 weeks later, big splits in the side.
Racelights flatted after 500 miles or so. The punture was BIG! I just don't like Bonti's. Replaced the Bonti's of my wife's bike even before the bike left the showroom floor. I tired to use them as training tires but didn't get much out of them.
Quoted: 761 Post(s)
Liked 1,720 Times
Never seen that before. I got some mileage on mine, 2500+ and they still look good. Will need to inspect real close before my next ride. Might want to throw some super glue on it until you get a new tire.
Bikes: Old Bike: 1975 Raleigh Delta, New Bike: 2004 Norco Bushpilot
Liked 5 Times
You need a new tire, it's probably a defect in the production process, of getting the tread, armour layer and thread layers all bound together. You may have also run over something that cut the tread. I would replace with a different brand, you should check with your LBS. Some Trek dealers will only have Bonti tires, others will order from an online suppler like Cycles Lambert in Canada or Quality Bicycle Products in the US and can get several different brands. I think you will find most manufacturers have armoured tires now, but you may need to look under city or urban class tires to find them online. I found Michelin, CST, IRC, Maxxis, Schwalbe, Specialized, Pannaracer all have armoured tires available, so pick another brand and go for it. Nice thing about tires, if you don't like one, your investment is minimal, so go with a different one.
I picked up a new tire on the way home, but unfortunately the only thing they had available at the LBS in the size and price range was another Bontrager made tire, but it's not a Race light Hardcase, it's a Satellite plus Aramid tire. I'll have to see if it holds up.
I'll have to look around online and get some backup tires that I like so I don't have to settle for whatever is available at the LBS's.
However, I really like the reflective strip that comes on this new tire, as you can see in the picture.
The camera flash shows the reflective strip really well.
Quoted: 761 Post(s)
Liked 1,720 Times
They used to have a race lite with the stripe. I had a 700-38 set with the reflection stripe. Came in handy when I rode more late night rides.
ut then, my race light hardcase 32c's were a bear to get on, and off as well. So bad I decided I'm never putting them on a wheel again.
Draft Producer
Bikes: fuji CCR 1.0 carbon,Surley Pacer,02 norco shore freeride MTB, cannondale rigid MTB, Fuji aloha 1.0, Monty trials bike
people get a thousand miles out of a go fast tire OMG
wish i knew what that felt like (rear tire of course)
My recommendation goes with the continental ultra sport. Not the most flat-proof tire out there, but better than most, and for $15 per tire it's great value. Only downside is the beads are hell to get on the rim the first time. But if you just want to have some spares ready, it's worth a try. B
The Continentals were a real pain to get on my Sun Mammoth rim, but worth the trouble.
With my 700C rims, tires are far easier to remove and put back on, especially on the Velocity Dyad rim.
Next time I'll probably get some Continental, or maybe also try Schwalbe tires.
Triathlon in my future???
Bikes: Junk, that is why I am here. :-)
I tried the more expensive tires and found that I went through the tread really quickly and it didn't handle any different for me. But, I am not a racer, just a bike rider for exercise and fun.
I bought the cheap tires from nashbar. Time for me to swap the front to the rear at 2500+ miles. I have had one flat that I can remember, and it was going down hill at about 30, and I actually don't know what caused the flat. I am assuming a hit a sharp small rock, because the mark in the tube was very small. I am staying with the cheap tires as they are working for me. When I start having problems, I will switch to something else. A guy I bought a set of rollers from that used to work for a TREK dealer doesn't use Bontrager tires at all. He told me to stay away from them.
2007 Jamis Ventura Comp
2006 Jamis Explorer 2.0
2000 Specialized Hardrock (bought used)
Swim, Bike, Run and sounds like fun
Bikes: 2006 Giant OCR Limited
That kind of damage can be expected when you ride like this:
https://www.youtube.com/watch?v=yX4nUhURAJg&NR=1
Guest
Posts: n/a
Quoted: Post(s)
Liked 5 Times
That was my plan. Put my 2500 mile front tire that looks great, on the back, put the new tire on the front, and then ride until the back tire looks iffy, and switch front to back and put new on the front.
These are 23's for my road bike. I know that doesn't mean anything, but just in case you were wondering.
