(New Bike Shopping) Carbon Frame - Pushing weight limit
First the question, then some background below:
Current weight has been between 235lb-240lb, I'm in good riding shape, just haven't been as focused on weight loss as I should be. Plan to change that and drop weight gradually throughout the year.How risky is it to push max weight on a carbon frame? At current weight plus gear, I'd be pushing the 120kg, 265lb max weight published on the Canyon website, but [probably] not going over it. I'm more concerned about the frame/fork integrity with an aggressive riding style, plan to stay on Aluminum wheels.
___________________________________________________________________________________________________
Just a little bit of background on where I'm at today. Like many, purchased a bike during COVID. Was my first drop bar bike (experienced MTBer), a 2021 Kona Jake the Snake (AL frame, CF fork), with plans on putting gravel slicks on it to ride casually on the road and some gravel. Total success, loved it, especially pushing myself on road rides, going fast, corning, climbing, high tempo, bombing hills, etc.
Anyway, things escalated and I made some more road geared modifications, kept the 1x 11 speed but widened gear ratio to help with climbs, swapped out wheels for DT Swiss Spline P1800s 33m depth, Zipp SC aero bars, a longer flatter Zipp SC stem, etc.
This was the beginning of last season, and I'm at a stage now where looking for an upgrade for best road riding experience possible. I really love the Canyon brand and eying up a Canyon Ultimate CF SL 7 eTap. I do enjoy longer rides was was thinking about an Endurace, but I think the Ultimate would suite my riding style more. Just concerned on the weight limit on the carbon as described in question above.
There is some caution built into the weight limits, but they are there for a reason. Riding style has a lot to do with it as well. Some people can just float through all the rough stuff and are really easy on bikes and wheels. Others seem to hit every hazard out there and go through parts and wheels like a hot knife through butter. Which one are you?
Liked 529 Times
That is a good question. Will be amazed if you find a good answer.
I'm close to your weight. Pisses me off when I look at ladders.
My guess is there will be no consistency from maker to maker, doubt there is some sort of commonly accepted standard, and that the limits are more to prevent lawsuits than anything else.
What I do know is I gave up on rear wheels with less than 36 spokes some decades ago. Every time I get the itch for a super light bike I hesitate when I see the 24 spoke wheels. Big riders, especially if they push heavy gears, really stress wheels.
Klaatu..Verata..Necktie?
Liked 12,387 Times
I have been where you are now. I have weighed as much as 240, though I did get down to 200 about 2 years ago and I'm currently in the 205-210 range. I already had bikes when the Pandemic hit, but with no commute and a need to get the hell out of the house and burn off some anxiety, I started riding a LOT more. In July of 2020 I got a Canyon Endurace. I was at least 220 lbs then, maybe higher. It was not a problem.
Regarding Endurace vs Ultimate, the first thing I'm mention is that the Endurace already has more aggressive geometry than most other "Endurance" bikes. With the Ultimate, you get about about an inch lower stack and half an inch more reach. You should assess your flexibility before choosing. I'm fairly inflexible myself - can't get much past mid calf when trying to touch my toes. I run my Endurace with about 3" of saddle-bar drop. I could go lower - most of my bikes have more drop. But for me there'd be little point in getting an Ultimate because I'm still running 7mm of spacers under the stem. If you haven't ridden a road bike much, you may find the Ultimate puts the bar too low for you, or too far away.
Liked 1,981 Times
Same here. I had prowheelbuilder make me a 28 spoke front and 32 spoke rear wheelset after destroying a set of Fulcrums.
I'm 210 lbs but not the most nimble rider and rough on bikes.
Bikes: Schwinn Broadway, Specialized Secteur Sport(crashed) Spec. Roubaix Sport, Spec. Crux
Liked 179 Times
I'm at 265 pounds, have been more, have been less. MY Specialized Roubaix has 35268.1 miles as of my last ride on Saturday. My 32 spoke Velocity Fusion rims with Ultegra hubs have broke exactly one spoke in about 25K miles. I wouldn't say I am hard on bikes or wheels but I do bunny hop cracks, manhole covers and such on a regular basis so maybe I am. I have had more saddle rail failures than anything. YMMV
Sir Mark, Knight of Sufferlandria
I like the Canyon bike designs but realized that with any problems I would likely need to ship the bike back to Canyon. I decided to stick with local bike shop supported bikes and have bought Specialized (road and full suspension MTB) and Scott (hardtail) bikes with new bikes purchased in the past several years. I also like as much as possible to have my money kept in the local community by supporting local bike shops. When I wanted to add a dropper seat post to my hardtail bike it was very convenient to take it to a bike shop and pay $50 labor to have an experienced mechanic do the installation. By supporting the shops I help them keep their doors open for myself and for others.
Liked 12,387 Times
Another thought on Endurace vs Ultimate - if your happy with your position on your Kona, spend some time determining which of the Canyons would allow you to duplicate your position best. Also, take Canyon's recommended sizing with a grain of salt. They'd have had me on a Medium, which would have meant running the full stack of spacers and getting a longer stem, whereas the Large fits great with 7mm of spacers and the original stem.
It's worth noting that the Canyon weight limits seem to be a combined weight of rider + kit + luggage + bike.
You need to consider the weight of full water bottles + flat kit + phone/wallet/keys + shoes/gloves/helmet , etc. It seems likely that 240lb rider + bike + everything else would exceed 265lbs. This seems risky to me.
That said, I'm sure Canyon's weight limits are conservative and developed in consultation with legal.
Thread Killer
Liked 1,820 Times
Yeah, no one can say anything definitively, but there are-- and have been for years-- lots of heavy riders on carbon frames, so in response to the OP's question I'd say that it is generally *not* very risky to push frame weight limits. The only person I've ever known to have a carbon fiber fail is a woman-- typical sized, so maybe 140-150?-- who had the head/downtube junction fail on a bonded Colnago frame. Every Clyde I know is on carbon fiber these days, including me.
I've been pushing hard on this carbon Dedaccai for 6 years on MI's notoriously bad roads, all while weighing between 230lbs and 245lbs. I don't remember if there was a weight limit, but the bike is 17.1lbs/7.7kg as pictured (i.e. including cages, out front computer/camera mount, Assioma pedals, mini-pump, full emergency kit with tube, multitool, 2 levers, patches, and CO2 inflator & cartridge) on the size XL frame, so it's pretty light. Until this season, the wheels were the amazing 18f/24r steel aero spoked, 30mm deep, 19.4mm IW, alu rimmed, 1395g American Classic Argents; bulletproof, and still doing backup duty for this bike, while another bike still wears a set of Argents 10 years on. I was harangued on the Clydesdale/Athena forum for daring to ride fewer than 36 spoke wheels; apostasy! The new Lun Hyper R45s, which are 46mm/54mm deep and 1322g (claimed) with 21mm IW and 16f/21r carbon spokes, have already proved their mettle, offering excellent snap and stability when stomped on, and handily hauling my corpulent carcass to stop in the rain from downhill speeds approaching 50mph while at spring camp in Bloomington this year (it rained all three days we rode!). I took the Argents with me because I was worried about braking, but never even thought about 'em.
The short of it is, there's always risk, there's always fear-mongering, and there are always folks proving otherwise. You can choose your gear wisely, choose not to let a bunch of rando dudes on the internet cause you to live in fear, and choose to follow the examples of those doing what others say is impossible. Or you can choose not to, but either way, you pay your money and take risks.
![](https://cimg4.ibsrv.net/gimg/bikeforums.net-vbulletin/1500x2000/dedacciai_gladiatore_1145cd45efd723d6fb4c7fe3779a96576fcc4ca9.jpg)
Likes For chaadster:
Safest to buy a bike with an aluminum frame and forkset. It will weigh up to 2 lbs more but be stronger and less subject to fatigue and sudden catastrophic failure.
A Specialized Allez Sprint alloy framset weighs 3.3 lb as compared to their carbon fiber Aethos frameset at 1.88 lb. The alloy frameset is 1.4 lbs heavier but the weight of the components and the wheels and the tires is going to be the same. A water bottle weighs more than 1.5 lbs for a frame of reference.
Likes For Calsun:
Their weight limit is pretty conservative as they have the same 120 kg limit on all their road and gravel bikes. The margins are going to be a little tighter on their lightest road frames. If I was pushing the weight limit I would seriously consider choosing a gravel bike and fit road tyres. The carbon layup on their gravel bike frames is probably a little stronger.
Bikes: 2022 Fuel EX 8, 2021 Domane SL6, Black Beta (Nashbar frame), 2004 Trek 1000C for the trainer
Liked 463 Times
Check out Salsa. A few years ago I checked with them while looking at a WarRoad.
Answer:
“As an ASTM Condition 2 bicycle the Warroad is rated for a 300lb rider and 55lbs of luggage!”
![](https://ecp.yusercontent.com/mail?url=http%3A%2F%2Fd1vwge3ak2z6qm.cloudfront.net%2Fstable%2Femail-graphics%2Fanswer-email-logo-placeholder-1px.gif&t=1689043597&ymreqid=bebe2434-ef7f-10f1-2161-c10042010a00&sig=b.s0h4lYWeqq7qPUkHi83A--~D)
Liked 3,700 Times
Check out any bike you like. They all will work fine.
My son races carbon frame and wheels. He weighs in most days around 245lbs. Has zero issues. In fact I weigh in at 230-235 depending upon what's for breakfast, lunch and dinner, and have owned 2 carbon frames. It is much stronger and resists cycle fatigue much better than most understand.
As for wheels, go carbon. I am constantly impressed with the durability of carbon rims on mountain bikes, and my son's road/gravel bike. I have considered them for myself, but who am I kidding. I am old, fat, and slow. Alloy does just fine for my needs.
Likes For TiHabanero:
