Looking for high quality, but quiet ss freewheel.
Bikes: Novara Safari, CAAD9, WABI Classic, WABI Thunder
Quoted: 366 Post(s)
Liked 458 Times
Title says it. Looking for 17 or 18t freewheel that is quiet while coasting, but higher quality than Shimano sf1200. White is quality, though loud. Any suggestions?
Be watchful, stand firm in the faith, act like men, be strong. Let all that you do be done in love.
Clark W. Griswold
Quoted: 4392 Post(s)
Liked 4,029 Times
Quiet, unsure? Most of the quality ones are going to be louder because of how they work. More points of engagement generally leads to a higher quality freewheel but those extra points of engagement tend to add some noise. I would have to say White Industries is the way to go.
Likes For veganbikes:
Hmmmm,
I have a Suntour Winner Pro 6 speed cluster that is super quiet as I presume the PO stuffed it full of grease.
This is despite Suntour warning specifically not to do this.
Works fine however and is a real 'stealth mode' bit of kit.
I have no intention of doing this to any more freewheels.
Likes For 1970bikes:
Tinker-er
Bikes: 1956 Rudge Sports; 1983 Univega Alpina Uno; 1981 Miyata 610; 1973 Raleigh Twenty; 1994 Breezer Lightning XTR; V4 Yuba Mundo aka "The Schlepper"; 1987 Raleigh "The Edge" Mountain Trials; 1952 R.O. Harrison "Madison"
Quoted: 166 Post(s)
Liked 269 Times
Keeping a freewheel lubed with the correct oil will help keep the noise down both from the pawls and wear over time. They should only have a good thick oil in them like a hypoid gear oil or Phil Wood Tenacious. A loud freewheel tends to indicate a dry freewheel, regardless of brand name. Shimano have seemed to be stingy on the lubricants in recent years, I've seen a couple brand new hubs with nearly dry balls. A good bit of thick oil might calm that Shimano down.
Likes For PhilFo:
Old fart
Quoted: 3594 Post(s)
Liked 3,404 Times
What I've done to quiet freewheels is to run oil into the body until it comes out the other side. Wipe off the excess, and then seal the gap between the inner and outer freewheel body with a heavy grease. You're not packing the grease into the freewheel, just working it into the gap to seal the oil inside. Seal both sides of the freewheel this way. It's not permanent, but you can get several weeks or even months of silent running, after which you just repeat the process.
Likes For JohnDThompson:
Quoted: 4813 Post(s)
Liked 3,941 Times
Likes For 79pmooney:
