Slipping boas in shoes
Geosynchronous Falconeer
Bikes: 2006 Raleigh Rush Hour, Campy Habanero Team Ti, Soma Double Cross
I went down to the LBS to try out some new road shoes. I tried the s works boa shoes. (they have a little cable that tightens instead of a ratchet or velcro strap) They fit nicely and everything, and I like the idea, but they seemed to have a major problem. When I put the shoes on and flexed my feet, it would cause the boa to loosen. You can see the dial turning backwards as I did it. I would tighten the dial and flex again and they would just slip backwards. How does anyone keep them tight? Was I doing it wrong?
Bring the pain.
Bring the pain.
Maybe they changed the s-works shoe this year, but last year's model didn't click into a locking position (it's basically always 'locked' via a friction ratchet). To release it, you just turned it the other way. This allows you to make small adjustments either way, but can loosen itself if the drag isn't set right. Most of the boa's I've seen on other shoes have you pull the knob out to release completely, I think it's a better design because it can't slip.
Bikes: All City Nature Boy, Salsa Ti Fargo, Kona Electric Ute
The boa is a great idea that hasnt yet reached its optimum efficency. Im a golfer and Footjoy has been using the Boa system on their golf shoes for years and they have all sorts of issues with them
Administrator
Bikes: Cervelo C5, Guru Photon, Waterford, Specialized CX
Quoted: 1106 Post(s)
Liked 2,180 Times
I'm not sure it's even a great idea. I don't see the benefits are better than a typical ratchet and the drawbacks are big
I do most of my shoe adjustment with the top buckle/ratchet...mostly leaving the two other velcro straps pretty slack. Does the boa system prevent you from doing that and pretty much provide even tension?
2014 Specialized Roubaix2003 Interloc Impala2007 ParkPre Image C6 (RIP)
Bikes: Roubaix / Shiv
Quoted: 12 Post(s)
IMO boas are far better than velcro or buckles. I dunno who is having problems with Specialized boas. It's certainly a good idea and is way easier for me to adjust during the ride. I can also adjust the tension *through* my shoe covers...try that with a buckle. Ratchets also weigh a bit more, and don't provide as even a tension as the wire in the boa system does. Velcro on the other hand, is harder to dial in that perfect tension, especially while riding. With the boa system its easy to go one click tighter or looser if its *almost* perfect. Of course all 3 systems (4 if you include laces) are fine, and we're being nitpicky here, but if you objectively compare them all I really do think the BOA is the best.
DStrong, specialized boa shoes will have 1 boa and 1 velcro, 2 boas, or 2 boas and 1 velcro. You can leave the toe-end stuff slack if you want, and just adjust the ankle-end one to be tight if you wish.
As for the OP's original post, the shoes will do exactly what he described when they are wound the wrong way. It is not something somebody will encounter after they buy the shoe and figure out which way to turn the dial.
I love my boa's on my MTB shoes, as well as my Road shoes. 6000 miles and I've had no issues.
Bikes: LOOK 595 & Cannondale CAAD9
DStrong, specialized boa shoes will either 1 boa and 1 velcro, 2 boas, or 2 boas and 1 velcro. You can leave the toe-end stuff slack if you want, and just adjust the ankle-end one to be tight if you wish.
Super Moderator
Quoted: 1173 Post(s)
Liked 929 Times
I'm leery of using boa, because I like my toes loose and my ankles tight. velcro straps or buckles can be set independantly.
Quoted: 10 Post(s)
You are doing it wrong, they don't slip. You push the dial down to snap it into place. Then lift up on it to release/loosen them.
Had mine for a year, no problems with slipping. 10x better design and though than 40yr old velcro straps. One simple mechanism, one velcro strap at the toe, which I never touch.
Bring the pain.
Bring the pain.
