2020 Canondale Supersix?
- Soli Deo Gloria -
Quoted: 6844 Post(s)
Liked 736 Times
What do you guys think of the new Supersix?
Ultegra and Dura Ace builds don't include rim brake versions and it looks like the High Modulus frame is disk only as well.
The Ultegra version above has 160 mm rotors in the front. My impression is that most road bikes come with 140's, no?
Seems like the thing is all Canondale branded components apart from the gearset and brakes. Anyone know if this is available as a frameset?
The older generation Supersix was getting a little long in the tooth but there should be some really good deals in the near future.
-Tim-
-Tim-
Bikes: 2019 CAAD12, 2015 Specialized Sirrus Comp
Quoted: 562 Post(s)
Liked 64 Times
It looks interesting but I'll reserve judgement until I read some reviews. The problem for US customers is that it will cost >$4k to get Ultegra. That's out of my range.
- Soli Deo Gloria -
Liked 736 Times
Yep, no rim brakes for the High Mod version. Only disks if you want the lighter frame. That doesn't make weight weenie sense but there it is.
https://cyclingtips.com/2019/06/2020...t-ride-review/
Re: good deals on older models. I just got my 2018 Supersix evo disc Ultegra Di2 for 25% off msrp at my LBS (official dealer). I couldn’t pass up the Di2 at that price (literally the next lowest priced Di2 bike was $1K more) even though I wish this bike had better wheels and a thru axle in the rear. Not that I have anything against QRs, it’s just easier for me to line up a TA. Other than those two things I’m thrilled with everything else.
Liked 10 Times
The bike has a ton of potential in my opinion. The data published by C'dale shows it to be a considerable watt savings at 30mph and a moderate savings at a more modest pace of 20mph.
I'm a fan, and looking for a racier bike. My disappointment? No Ultegra Di2 kit for men, if/when they do the price will mirror the woman's bike at $6,700, that's a lot of coin. The existing Ultegra option doesn't have an Ultegra crank which will make fitting a power meter more difficult. That's super disappointing. Maybe I look at the 105kit and swap the crankset? Seems like unnecessary added cost but many mfg's are now spec'ing their own cranksets.
I don't like the new trend towards integration, with proprietary stems/ handlebars, etc.
I love my 2013 Evo and was seriously ready to consider the 2020 Evo until I realized I probably wouldn't be able to swap out the handlebars, stem and possibly seat post too, to be able to dial in the same fit I have with my current bike.
FF to 5:50 of this video where the guy pretty much summed up my feelings towards integration using their own proprietary stuff that can't be swapped out. Not just on the Evo, but on a bunch of new bikes that have recently come out.
Likes For BarryJo:
Quoted: 20810 Post(s)
Liked 9,456 Times
Liked 9,456 Times
Quoted: 562 Post(s)
Liked 64 Times
A review will tell you everything you want to know about the new frame -- handling, cornering, stability, responsiveness, comfort. And most importantly, how the bike compares to the predecessor and to other bikes.
We really don't know how the new SuperSix (and eventual CAAD13) compare to the prior gen.
I considered paint jobs, from Celeste green to whatever color the 2019 Domane was painted, but I felt that after test riding three different bikes I liked how my Synapse felt the best. There were, I learned, differences other than paint jobs...
Quoted: 1067 Post(s)
Liked 259 Times
Yes, they will rave about this and that and fill up their "column inches" but it is really just a load of hot air.
I saw one of these yesterday actually. Looks nice.
Quoted: 562 Post(s)
Liked 64 Times
Disagree. Last year when I was deciding between the CAAD12 and SuperSix, the reviews I read helped nail down the subtle differences between the two bikes. Yes, reviewers rave because bikes are "so good" these days, but important information can be derived from them.
No it won't. Bikes at this level now are all very good and a "bike test" is purely subjective and isn't really going tell you anything meaningful.
Bikes: 1979 Raleigh Team 753
Quoted: 3375 Post(s)
Liked 371 Times
I mentioned I'm re-building his somewhat normal MASI with steel spindle cranks and pedals to about 12#. That would be 14# with discs and rotating steel with a center of mass ~70mm from the hub adds to the whole centripetal acceleration thing (v^2/r where r is the center of mass). I get it is closer to the hub than the rim. But we still need thick rim tracks for clinchers (and tubulars are already strong) so why not use them for brakes too. That is is you ride is nice dry areas, and I do.
Quoted: 1851 Post(s)
Liked 679 Times
It's not uncommon for companies to make special versions for pro riders, so it is quite plausible that they are on hi-mod versions with rim brakes. (And in some cases, manufacturers are selling rim-brake versions as framesets only.)
At the same time, equipment has gotten so light that many pro teams need to add weight to their bikes to meet the minimum weight standard. (Doge can speak to this as he has had to add weights to his kid's bikes when he was racing in Europe.) As such, they might opt for the heavier non-hi-mod version to help meet that minimum.
Quoted: 18883 Post(s)
Liked 10,646 Times
- Soli Deo Gloria -
Liked 736 Times
Weightweenie that I am, cycling value that you don't want to spend energy to reach speed you then have to reduce, and that rotating mass matters for acceleration, I won't be buying discs if I can help it. My kid may insist and I have a grad present. But I hope to talk him out of it.
I mentioned I'm re-building his somewhat normal MASI with steel spindle cranks and pedals to about 12#. That would be 14# with discs and rotating steel with a center of mass ~70mm from the hub adds to the who centripetal acceleration thing (v^2/r where r is the center of mass). I get it is closer to the hub than the rim. But we still need thick rim tracks for clinchers (and tubulars are already strong) so why not use them for brakes too. That is is you ride is nice dry areas, and I do.
This and some of the proprietary/integration issues brought up rule out the Canaondale.
-Tim-
Liked 10,646 Times
Disc brakes are like derailleurs, not strictly necessary, be definitely an improvement.
Likes For Seattle Forrest:
Quoted: 20 Post(s)
I agree about the value of reviews, but there are differences between bikes because riders have different tastes. You aren't going to get a bad bike at this level, but do you prefer it to respond immediately to steering input or more slowly and dileberately, etc.
Liked 371 Times
This to me is not about quality, but focus and fit. I think most on this post are pretty experienced.
If living in the PNW then discs might be a big consideration, while if living in SoCal - or racing the TdF they are for marketing.
Advocatus Diaboli
Quoted: 4737 Post(s)
Liked 1,533 Times
