Bike Trainer for SS Bike?
Old 04-03-11, 03:19 PM
rbpanaligan
Hey everyone,
I'm planning on getting a bike trainer on my local craigslist to be used during nights where i come home from work late.
Will bike trainers work with track bikes (Dawes SST AL)? The two models i'm looking at are the 2007 Cycleops Mag and the 2007 Blackburn Trakstand Mag. Would these two models work with our 15mm rear bolts? Both of the trainers have adjustable resistance which is a plus.
Thanks.
rbpanaligan is offline
Old 04-03-11, 03:43 PM
carleton
Elitist
carleton's Avatar
Quoted: 1386 Post(s)
Liked 92 Times in 77 Posts
I think the Cycleops will work because you can unscrew the lever arm and move it effectively spacing the clamp closer to accommodate your track/SS wheel.
The Trackstand looks like it will work, too. But, with both, it would be best if you took your rear wheel with you when you buy to make sure the trainer will clamp on it.
They should both work.
carleton is offline
Old 04-03-11, 09:55 PM
rbpanaligan
Thanks for the info Carleton
Old 04-04-11, 01:17 AM
Retem
Paste Taster
Retem's Avatar
Bikes: , Jury Bike, Moto Outcast 29, Spicer standard track frame and spicer custom steel sprint frame.
i have had success with most mag trainers and well rollers but of course they will work
Retem is offline
Old 04-04-11, 01:23 AM
liberalswine
ganja mon
Bikes: affinity marta
Was also lookin into a stationary trainer. But not quite sure if they'll work with my rear wheel given I'm using fat allan bolts for my chub hub. I think it uses a 16mm allen wrench
liberalswine is offline
Old 04-13-11, 02:13 PM
rbpanaligan
Which trainers will definitely work with 15mm bolts? I went to the Performance store and they said that most trainers won't work because the trainers use a skewer of some sort.
Sorry for bringing up a dead thread but i thought it would be better to post here than start another one.
Old 04-13-11, 02:22 PM
carleton
Elitist
carleton's Avatar
I know that the following will work with track bolts:
- TACX Satori magnetic (Awesome trainer)
- Kurt Kinetic Road Pro fluid (Awesome as well. Great road feel when using a road bike. FG riding is sort of tough when using bigger gears.)
- Cycleops Magnetic
- There are many more, but that's what I've used or tried personally.
Yeah, a lot of those trainers in Performance won't work with 15mm bolts. But, all you have to do is pull a bike off the rack and check and see.
carleton is offline
Old 04-16-11, 01:21 PM
rbpanaligan
Thanks for the list.
I saw this older model Cycleops mag trainer. Do you think this will work since it's one of the trainers you mentioned?
https://cgi.ebay.com/ws/eBayISAPI.dll...=STRK:MEWAX:IT
Old 04-16-11, 01:50 PM
carleton
Elitist
carleton's Avatar
I'm not sure.
BTW, newer trainers feel better. They evolve. I suggest that you try before you buy. It would suck for you to buy a trainer and it feels like crap. I've been on plenty that felt like crap. The TACX Satori magnetic is probably the least expensive one that feels good.
As low as $213
https://www.chainreactioncycles.com/M...?ModelID=15805
carleton is offline
sisterpine
General Cycling Discussion
15
07-27-17 05:40 PM
hoyc
Road Cycling
6
02-02-16 07:15 PM
nutcase
Singlespeed & Fixed Gear
11
11-26-11 03:57 AM
budha1300
Training & Nutrition
2
04-19-11 01:10 PM
xizangstan
Fifty Plus (50+)
16
01-16-11 07:14 PM
