Converting Downtube shifters into a a brake lever
Quoted: 835 Post(s)
Liked 2,153 Times
I don't think I understand your question, but I'm going to say no anyway. Do you mean run a cable from your DT shifter to a brake caliper? Most shift cables are thinner than brake cables, so a brake cable may not fit in the shifter and/or a shift cable would slip in the brake caliper. Plus, the direction of the cables leaving the shifters would cause some routing issues, especially having to make a 180 toward the front brake caliper. You wouldn't want indexed shifters, obviously. Most friction shifters rely on tension holding the shifter in place and working against the tension in the derailleur springs. If you loosened the tension bold on the shifters to allow the spring in the brake caliper to reset the shift lever, it would likely give you a wobbly shifter. Plus, I doubt you would be able to put adequate force into the shifters to create sufficient braking force. Last but not least, do you want to be reaching for the down tube when you need to brake? But I'd love to see it, so don't let any of this stop you from trying!
Chainstay Brake Mafia
Quoted: 16 Post(s)
Liked 11 Times
besides for a chainstay ubrake the cable routing would have to be pretty bizarre. and shifter cables are thin. so even if are able to pull it off i wouldn't rely on it
Quoted: 792 Post(s)
Liked 1,789 Times
Don't realy understand the question but in every likely interpretation I can think of the answer is no, hell no or or for love of god please don't. If you want to run a suicide lever most ss/fg or bmx levers will mount on the downtube definetly not recomeded. Most of the idiots run a BMX lever inverted on the top tube still a very bad setup.
Quoted: 16 Post(s)
Liked 11 Times
in the SSFG forum someone came up with the idea of a brake lever on the seat post connected to a rear brake. cause brakes on the handlebars are just lame
I would add to his but I don't want to be chastised by the admin (again) for having a opinion of the mental aptitude of the op. Even though I see others posting in similar fashion all across the forums.
spondylitis.org
Bikes: '84 Colnago Super; '90 Bridgestone MB-1; '81 Trek 930; '01 Cinelli Supercorsa; '62 Ideor Asso; '87 Tommasini Super Prestige; '13 Lynskey R2300; '84 Serotta Nova Special; '94 Litespeed Catalyst; etc.
Quoted: 121 Post(s)
Liked 97 Times
This sounds like a FGSS lurker trolling. /b is that way. ------>
If the OP is serious about this and you're correct, frantik, then this is the stupidest ****ing dumbass hipster idea I've heard in forever - the latest in a long list. A true candidate for the Darwin Awards if I've ever heard one.
Downtube shifters were designed to do a specific job - shifting and holding gears. They were not designed with the travel requirements of braking in mind. The cables are thinner, and more likely to snap under severe tension of braking. Even in friction mode, one introduces something very bad into the braking system - e.g. friction - unless one runs with the left and right shifters so completely loose that Loctite is required to keep the mounting bolts in place.
And the brake goes where, exactly? The fork (the only logical place)? How does one route the cabling, given the recesses for the cable stops are in the complete opposite direction?
Or perhaps the brake is to be mounted on the chainstay... Doesn't that Dan's Comp brake mount add weight to the bike? If it's the seatstay bridge, how exactly does one route the cabling for proper tension? Or is it that the brake cable housing extends from the derailleur cable stop up to the brake itself? The thing is inevitably going to be a bungee cord. And then that does what to the so-called "clean" brakeless look they're aiming for?
I have a fixed gear bike, too. It has brakes, with levers mounted on the handlebars, where they belong. There are two of them, in fact, one for each brake. And the cables are in the normal places. Friction is low, as it should be - and there's more-than-adequate spring tension to return the brake levers to original positions. But then I use the bike for training on road, and not as some kind of fashion statement to show everyone how ironic I can be.
Quoted: 792 Post(s)
Liked 1,789 Times
Maybe I'm old school but what's wrong with running proper brakes and bars on SS/FG about 2lbs extra dead wieght actual increase in perfomance if used correctly for street use and no real decrease in dependabilty maintnence it just seems silly not too.
Zip tie Karen
Quoted: 1465 Post(s)
Liked 1,542 Times
okay, so trying to be cooperative here, I'm guessing that it's possible to fashion a slotted steel clamp similar to the DiaCompe non-aero lever clamp, but larger for the 28.6mm downtube diameter. Then, one could mount a brake lever in a centered SunTour symmetric type location, with the cable running downward to a rear brake by making an S-turn, like with older womens frames. It would be a poor braking solution, to be sure...
OP, what is the origin of the question? Why?
Another option is to rig up an anchor to the DT shifters. Move the DT lever and drop the anchor. Works well on my steampunk fixie.
Zip tie Karen
Liked 1,542 Times
Follow-Up on Post #10
Giving it more thought, I'm sure that I could fashion an older Dia-Compe style non aero lever to a downtube. But follow this...if one used the right lever WITH the turkey lever, and positioned it low enough, one could make a sort of food brake. The rider would place the left food on the lever and press away and slightly upward. Although I wouldn't vouch for the strength of that alloy lever in a critical situation...
Although I could rig one of these in an hour in my shop, I'm certain that I would never ride one. Even if one lived above a dispensary in Colorado...
multimodal commuter
Quoted: 1908 Post(s)
Liked 574 Times
The thoughts that come to my mind are,
Yes, you could; but
shift levers are short and provide insufficient leverage,
the down tube is the wrong place for a brake lever, and
cable routing would be inelegant,
But it would be a good way to rig a drag brake for a tandem.
Yes, you could; but
www.rhmsaddles.com.
www.rhmsaddles.com.
Quoted: 4236 Post(s)
Liked 2,949 Times
Drag brake was the first thing that popped into my head when I saw this. I think I've most often heard of people doing that with a bar end shifter, but it probably could be done with a downtube as easily.
Bikes: 1996 Eddy Merckx Titanium EX, 1989/90 Colnago Super(issimo?) Piu(?),1990 Concorde Aquila(hit by car while riding), others in build queue "when I get the time"
Señor Member
Bikes: Bedford, IF, Hampsten, DeSalvo, Intense Carbine 27.5, Raleigh Sports, Bianchi C.u.S.S, Soma DC Disc, Bill Boston Tandem
Quoted: 1609 Post(s)
Liked 2,216 Times
I use one for my drag brake too, but for main brakes @rhm nailed it even if you used barcons on bull horns.
Yeah, bro it could work and would be amazing. Do they make anodized dt shifters to match my deep vees? My main concern is if the laces on my sneakers should MATCH the neon green deep vees, or offset it with an awesome purple or something.
Stop reading my posts!
Quoted: 1444 Post(s)
Liked 1,064 Times
don't you guys ever learn? Obviously this is an April Fools joke from somebody who's a late riser in another time zone...and of course as post number 12 proves: it not only can be done, but already has been. So, joke's on you Mr. Furbball
Quoted: 659 Post(s)
Liked 595 Times
I think it would be an exciting project especially if the rider has the levers set to index mode.
spondylitis.org
Quoted: 121 Post(s)
Liked 97 Times
I think the best approach is to just forget about the shifter and brake altogether and just jam your feet into the front spokes. If you've had enough absinthe you won't even feel the asphalt, and will have a really cool story to tell your bros afterward.
In my garage, anything is possible. I have a welder and a big ass chop saw. I've done some pretty stupid things with those tools.
Semper fi
Semper fi
Bikes: '93 Cadex CFM3, '84 Repco Nishiki Olympic 12,'87 Peugeot Montblanc, '09 Giant Trance X1, '13 De Rosa R838
Quoted: 8 Post(s)
Just a thought- being condescending might be just as bad as being 'hip'.
Quoted: 3464 Post(s)
Liked 2,831 Times
I am really surprised that the current crop of fixed gear guys have not rediscovered what was handed down to me long ago, a think palmed glove, great for brushing off potential flat debris and useful as a brake when applied to the top of the front tire.
I wore a gymnasts glove over my riding glove having stitched a heavy section of leather to it, as I did not have a sacrificial riding glove to burn up.
