Flattened Oval Top Tube ? 1986 ALAN Record
Bikes: Too, too many....
Quoted: 126 Post(s)
Liked 130 Times
I noticed that my new-to-me 1986 ALAN Record has a slightly flattened oval top tube.
At the front and rear of the bike, where it fits into the seat post lug and head tube lug the top tube is round, and about 1 inch in diameter.
In the middle of the tube the top tube is slightly flattened, and measures about an inch and an eighth wide ( looking down from the top ) and about seven eighths of an inch ( when seen from the side ) at the middle cable guide.
The way the reflected light hits the frame makes the difference obvious. (See picture).
I'm wondering if this is of structural benefit and if it is why isn'y it a more common design feature ?
Bink
Bink
Quoted: 2953 Post(s)
Liked 3,106 Times
I don't know if it provides any structural benefits, but my cyclocross bike has an ovalized top tube that makes it a bit more comfortable when shouldering.
Quoted: 126 Post(s)
Liked 130 Times
Just curious.
Bink
Quoted: 4230 Post(s)
Liked 3,935 Times
Alan did offer a CX frame which, IIRC, had a flattened top tube. perhaps for some reason that model's TT was used on the OP's frame. Andy
AndrewRStewart
AndrewRStewart
Quoted: 581 Post(s)
Liked 921 Times
There haven't been many aluminum frames made with round cross-section tubes for a long time. Most new bikes have some type of 3D or complicated profile done by 'hydroforming', while old bikes always started with round tubes, and flattening along one axis was the primary strategy to 'tune' tubes for whatever purpose. By the early 90s, most chromoly bikes had similar shaping done to their downtubes, usually flattened width-wise at the head tube and height-wise at the bottom bracket.
Likes For ClydeClydeson:
Liked 3,935 Times
"I'm wondering if this is of structural benefit and if it is why isn'y it a more common design feature" Bink
In theory a non round tube can have greater bending resistance in the long axis, of an ovalized section of tube, and less so along the short or less wide axis. But remember that the main triangle tubes see a lot of twisting forces, not so much mere bending. The torsional stiffness of an ovalized tube is substantially limited to what a virtual tube would have that has a diameter equal to the shorter axis. (Put another way if a tube is ovalized so it's small axis is half that of the starting round diameter the rotational stiffness will be about 1/4 of the original round tube had. Torsional stiffness has a geometrical relationship with diameter). So ovalizing a main triangle tube has more drawbacks then only the added cost.
Now another reason to ovalize at the ends is to be able to use a larger diameter tube then would fully contact the joining tube. Ovalizing the large tube will allow the joint (welded or brazed)to have complete tube to tube contact and increase the amount of the weld or fillet. As example is a 1.25" top rube joined to a 1.125" seat tube. The sides (or ears of the miter) of the TT will not be touching the ST. By ovalizing the TT vertically the entire TT miter will touch the ST and thus have theoretically more weld/fillet length.
But in real life the differences are fairly minor and the actual welding/filleting skills can be far larger an amount of "change".
It's my opinion that many shaping of tubes is more about branding and marketing then realized strength or stiffness gains. Andy
AndrewRStewart
AndrewRStewart
Liked 3,106 Times
Quoted: 1594 Post(s)
Liked 1,771 Times
Some bikes in the 80's had tubes which were ovalized in the middle for aerodynamics. Like the Nishiki Aero II I have:
But they were ovalized in the horizontal direction. ie. it's skinny in the horizontal direction and tall in the vertical direction. Your ALAN looks to be opposite of that.
Are you sure it didn't just get squished by a careless mechanic on the bike stand? Are there any other ALAN frames like that?
Bikes: 2001 Tommasini Sintesi w/ Campagnolo Daytona 10 Speed
Quoted: 145 Post(s)
Liked 35 Times
Bink
Bink
Just curious...
=8-|
5000+ wheels built since 1984...
Disclaimer:
1. I do not claim to be an expert in bicycle mechanics despite my experience.
2. I like anyone will comment in other areas.
3. I do not own the preexisting concepts of DISH and ERD.
4. I will provide information as I always have to others that I believe will help them protect themselves from unscrupulous mechanics.
5. My all time favorite book is:
Kahane, Howard. Logic and Contemporary Rhetoric: The Use of Reason in Everyday Life
Disclaimer:
Quoted: 126 Post(s)
Liked 130 Times
I cannot imagine a bike mechanic reefing down on ANY kind of a bike stand clamp with enough force to flatten a bike tube.
Anyway, I found pictures of other ALAN Record frames, as new, on the internet.
Some, but not all, appear to have a flattened top tube. See attached picture from a catalog of some sort.
Bink
Likes For Binky:
Quoted: 126 Post(s)
Liked 130 Times
Wow !! Now I'm curious too.
How would I be able to tell ?
Its a ALAN Record made in May, 1986 if that helps.
I traded a Raleigh Grand Prix for this bike to a guy who bought the ALAN second hand off a guy on CraigsList, so the history is a mystery to me.
How can i tell if the forks are, as you call them, the "original recall forks" ?
Does the fork crown appear to be any different from the forks they replaced ?
Bink
Quoted: 571 Post(s)
Liked 604 Times
In the old days Park Tools and other stands had levers that could get some serious torque and at a spring setting that worked fine on a gas pipe 1" top tube but could crush a carbon top tube especially a larger diameter if you did not back off the spring tension. To have smashed that Alan tube so beautifully the mechanic would have to have been an artist.
Quoted: 126 Post(s)
Liked 130 Times
I just sent off an email to ALAN in Italy with the model and date of manufacture of my bike (May, 1986) and a picture of the frame with a request for information about possible issues or recalls.
Its Sunday so it may be a while before I hear back from them... but I will let you know what (and if) they reply.
I also scoured the internet and the Bike Forums archives to see it it has been an issue. I could find nothing there of note.
What info do you have to share ?
Back soon - I'm off for a ride on the ALAN before it gets too hot.
Bink
Bink
Likes For Binky:
I bought an Alan frame, new, back in '88. I don't know when it was manufactured (frame is long gone...cracked seat lug). Anyhow. the top tube was definitely round. I noticed in the pic from the catalogue that the frame shown only has two cable guides on the top tube. Your frame has three and so did mine. Wondering if that matters? As far as the recalled fork, I was told by other riders that the forks with alloy steerers were prone to fail. This was hearsay and I never got any real proof. BTW. Mine had an alloy steerer and I rode it for 45,000+ miles before I noticed the seat lug crack.
Bink
Bink
I just found an Alan like yours, “Record” model, flattened top tube.
Seller lists it as 130mm between dropouts.
I am wondering what your frame measures? 1986 seems early for 130mm, right?
Best,
Robyn
Quoted: 126 Post(s)
Liked 130 Times
Bink
Likes For Binky:
Quoted: 188 Post(s)
Liked 997 Times
I got a Super Record, a Record and multiple CX with flattened top tubes.
See part of a catalog from 1983 on the so-called model Sprint (the same as the Super Record) those days.
And far as I know is trouble/recall with Alan frames a myth. The real story was about the Viscount/Lambert fork.
The fork on Binky's Record is the correct fork.
Likes For Surfer77:
Quoted: 6300 Post(s)
Liked 4,897 Times
Might be the builder/designer was more interested in what they thought was creating a more aesthetic look and appeal for their customers than a truly beneficial structural design or aerodynamic consideration.
Likes For Iride01:
Likes For fabiofarelli:
-Robyn
Likes For Surfer77:
-Robyn
Likes For Surfer77:
Quoted: 188 Post(s)
Liked 997 Times
Drenthe is nice, since a few years we do a ride there, small group, great fun. Nearby the Vam-berg.
